Old 10-23-2019, 11:49 AM   #1
marmitage
marmitage is just really nicemarmitage is just really nicemarmitage is just really nicemarmitage is just really nice
marmitage's Avatar
Default 97 sl2 ignition switch
So I replaced the doors on my SL2, ( bad window motors) figuring it would be easier to replace the ignition cylinder rather then the door locks. Got the old cylinder out no issues, but there was a silver part with a spring that came out with it. There was a shoulder on it so it seemed that it would only go in one way. I put it back in and it seemed right but when I put the new cylinder (from a 99) in it goes in until there is a quarter inch still sticking out. I have turned the silver part, turned the cylinder to try and line it up, no luck.
So does that silver piece need to go in farther? Is there a shaft behind it I need to get lined up with or is there a trick to getting the cylinder in? I have done this before but this car has been fighting me on virtually everything for the last 6 months.
marmitage
03 Vue Silver, Daughters
97 SL2 Back from the grave
99 Sw2 Daily driver
Add to marmitage's Reputation
Rate the quality of this post and help marmitage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marmitage is offline   Reply With Quote
Old 10-23-2019, 11:53 AM   #2
trottida
trottida's Avatar
Default Re: 97 sl2 ignition switch
Can you throw up some photos to help visualize the issue?
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-23-2019, 12:53 PM   #3
marmitage
marmitage's Avatar
Will do tonight
marmitage
99 Sw2 Daily driver
Old 10-23-2019, 08:00 PM   #4
marmitage
marmitage's Avatar
Here is a picture of the cylinder inserted
Here is picture of the cylinder, the circle with the knob is the part that came out.
I can turn it with pliers and cannot get it out
marmitage
99 Sw2 Daily driver
Old 10-23-2019, 09:10 PM   #5
Looks easier to screw with than the '94 Cavalier I had to screw with. Line up the notch with the keyway, slide the cylinder in & twist to find the path the notch wants. Once it's all back in slather the cylinder up with JB weld to keep it in the sleeve and cut a bit of flat-stock into a key shape and cut out the annoying/terrifying column lock...good to go
Old 10-24-2019, 09:49 AM   #6
trottida
trottida's Avatar
I didn't experience this when I did my cylinder. That piece stayed in place and the cylinder came out and went in clean. I think it is called a cam. Where is this spring you spoke of?
Anything in this diagram look familiar?
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-24-2019, 05:29 PM   #7
marmitage
marmitage's Avatar
The spring was attached to the piece that came out with the cylinder. Connected directly on the back extending straight out. Don't see it on your diagram.
I haven't had this issue either but it does seem to be sticking out the length of the cylinder sliding over the "cam".
I'll fiddle with it tonight and see.
marmitage
99 Sw2 Daily driver
Old 10-24-2019, 05:31 PM   #8
marmitage
marmitage's Avatar
Can you elaborate on......cut a bit of flat-stock into a key shape and cut out the annoying/terrifying column lock...good to go ?
marmitage
99 Sw2 Daily driver
Old 10-24-2019, 08:35 PM   #9
ZuluKono
ZuluKono is on a distinguished road
2000 SC1
I recently went through my own lock cylinder ordeal.
I was fighting it for a long time before I figured it out.
To get the cylinder all the way in, I had to use a small nail
to push something in on the under side of the housing as I
was pushing/turning/jiggling the cylinder with the key in it.
Mine's a 2000 SC1, don't know if yours is the same.
All GM, all the time.
Add to ZuluKono's Reputation
Rate the quality of this post and help ZuluKono reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ZuluKono is offline   Reply With Quote
Old 10-25-2019, 09:35 AM   #10
marmitage
marmitage's Avatar
Thanks for the tip. I'll give it a try. Fighting water in basement and getting wet carpet out so it might not be until Sunday.
marmitage
99 Sw2 Daily driver
Old 11-01-2019, 02:06 AM   #11
TomM96
Dunno if this matters for the key cylinder, but...
I think maybe better with a Gen2 replacement for the Gen2 lock,
because I think the Gen3 cylinder may be different due to the new security issues.
Could check the part lookup to see if the different years have same part number...
(the aftermarket part numbers would help, GM probably not)
the junkyards may list substitutions....
Add to TomM96's Reputation
Old 11-01-2019, 08:17 AM   #12
trottida
trottida's Avatar
He stated the ignition cylinder was from a 99 so that is the same as the 97 (both GEN2). Yes the GEN3 ignition cylinder is a different cylinder.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-02-2019, 10:58 AM   #13
marmitage
marmitage's Avatar
Still having no luck with this cylinder. looked at my donor car's old cylinder sleeve. It looks like part of the 97 cylinder slot is broken off. I have circled it in the attached picture. I am guessing this is why I can't get the cylinder in. Anybody have any ideas beyond moving the donor cylinder sleeve, which looks like even less fun since it snowed last night.
Compare with pics in post #4
marmitage
99 Sw2 Daily driver
Old 11-02-2019, 10:59 AM   #14
fjmg
fjmg will become famous soon enough
In the op's second pic that plate with the nub is 180 out of phase, you need to rotate it so the groove in that plate lines up with the notch at the bottom of the housing. Then the plate will slide deeper since it will be clocked properly with the ignition switch behind it. There is a pin missing in your pic that retains that plate at the proper depth, that is why the plate came out when you removed the key cylinder. Not mandatory to replace the pin, just makes it easier for reinstalling. I can email you a pic and you can post it (comp issues on my end) if you like.
Once you have the depth correct I would use needle nose and turn that plate to verify you are in the correct position.
Add to fjmg's Reputation
Rate the quality of this post and help fjmg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fjmg is offline   Reply With Quote
Old 11-02-2019, 12:33 PM   #15
marmitage
marmitage's Avatar
yes the second pic is from the donor car. the first pic is of the problem 97. Please share any and all info you can. Daughter wrecked her car last night so this has become more important than it was.
marmitage43@hotmail.com
marmitage
99 Sw2 Daily driver
Old 11-04-2019, 01:13 PM   #16
marmitage
marmitage's Avatar
Here are the Pics Robert sent me. Will try his advice.
Will continue but plan B is to pull the metal part from the donor car. Looks like two very small bolts and unplug a few things. Any advice if I have to go down that road would be appreciated
marmitage
99 Sw2 Daily driver
Old 11-04-2019, 06:34 PM   #17
fjmg
As I am looking at your pictures... I would just undo the two bottom pivot and one pinch bolt, undo a couple connectors and pull the entire column and work in the warm.
If you cannot get it to work just grab another column from the wrecker and reinstall that column.
Buchanon is out of my way for any of my future travel but if you think you might be close to the us/can border sometime soon I can bring one of my spares and meet you.
Old 11-05-2019, 09:20 AM   #18
trottida
trottida's Avatar
Did you look at this RichPin video as a reference >> https://www.youtube.com/watch?v=Yt8wnj4qHoc
It specifically mentions re-positioning the part at the bottom of the housing and at 3:29 shows the correct orientation of the piece at the bottom of the housing. Yours appears to be incorrect in comparison; rotated 180 degrees as already mentioned. Here are photos showing the difference.
As I understand it, if that plate is positioned correctly it should be able to be depressed further into the cylinder housing and then spring back into position. If it is not it will hang as you are experiencing and your cylinder will not go full depth.
File Type: jpg InkedLock cylinder housing position_LI.jpg (33.0 KB, 38 views)
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-12-2019, 05:00 PM   #19
marmitage
marmitage's Avatar
Took Roberts advice and swapped in a new steering column. Ignition cylinder swap went as it should have, new one in. Car runs and now I just have to find the stumble reason. Another post for another day.
Thanks all for help and suggestions. Will tear old unit a part and share if I find anything weird.
marmitage
99 Sw2 Daily driver
Old 11-25-2019, 05:16 PM   #20
marmitage
marmitage's Avatar
here are the pictures of the disassembled switch.
first one shows the what came out of the back when I took it apart. This is the part that came out with the cylinder, there is the spring.
the second shows how it went together in the column
the third shows the plunger part I had to depress to get the spring and plate back in
Thanks for all the help. New column quickest easiest way to fix for me.
marmitage
99 Sw2 Daily driver
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 04:30 PM
Ignition Cylinder or Ignition Switch silverslp S-Series Tech 1 01-05-2015 11:09 AM
Ignition Switch or neutral safety switch? MNGuy S-Series Tech 16 05-22-2014 12:12 PM
Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission infinitezero Ion Tech 5 11-25-2011 05:47 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 02:09 AM
