Old 08-11-2019, 04:56 PM   #1
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
2008 VUE 2.4L
Default 2.4L Ecotec: Same camshaft position sensors?
Are both the intake and exhaust camshaft position sensors the same on a 2008 Vue 2.4L XE (gas)?
Rockauto only lists 1 part under camshaft position sensor.
Peter
CURRENT:
08 Vue XE Black 2.4L
07 Ion 3 Savannah Green Metallic 2.4L
04 Ion 2 Berry Red 2.2
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
95 SL2 Lilac Metallic
94 SW2 White
hudypete1 is offline   Reply With Quote
Old 08-11-2019, 05:41 PM   #2
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Default Re: 2.4L Ecotec: Same camshaft position sensors?
it is not likely the sensors that are bad, but more likely the actuator control solenoids that bad. test for high resistance hot. check oil level. ACDELCO 12679100 and 12679099
Old 08-12-2019, 09:02 AM   #3
hudypete1
2007 ION-3 Sedan
2008 VUE 2.4L
The deal was that I bought a rebuilt head off eB**. A previous owner had drilled out an exhaust bolt and drilled into the oil channels. My existing head was leaking oil which was burning up and the smell of burning oil was getting into the cabin.
The rebuilt head from eB** had different cam shafts than the existing head. I only realized this after I reinstalled the head.
The car does not start now.
In my mad, frenetic, rushed internet searches I was going off wild rabbit chases into the different cam shaft configurations. That is where my question came from.
I believe the original head and all original equipment is good, including the actuator control solenoids. I do not believe that I need to change any of those pieces.
What I think I need to do is work with the seller and figure out how to get the proper cam shafts into the rebuilt head. In the worst case, I will use the old cam shafts.
Advice, comments, jokes, and teasing are appreciated.
Peter
CURRENT:
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
94 SW2 White
P0016-18 Camshaft position Correlation Sensors Sky3000 Aura General 1 12-12-2015 05:06 PM
Camshaft position sensor? nickbrit16 S-Series Tech 4 10-19-2014 10:26 PM
Clean camshaft sensors - 2.4 L golftango Aura General 8 09-02-2014 05:17 PM
Camshaft Position Sensor on a 96 SC2... DJboozeAlot S-Series Tech 15 12-06-2006 08:38 PM
Camshaft Sensors musicman2005 S-Series General 7 03-12-2005 07:24 AM
