Old 05-21-2019, 03:17 PM   #1
rubberband man
rubberband man is on a distinguished road
Default engine cover removal
removal of engine cover on a 4cylinder 2008 vue
Add to rubberband man's Reputation
Rate the quality of this post and help rubberband man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rubberband man is offline   Reply With Quote
Old 08-05-2019, 12:17 AM   #2
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
2008 VUE 2.4L
Default Re: engine cover removal
There are 3 pieces:
1. Ecotec shield piece. Pop off in front, then rotate to clear from the hinge things in back.
2. Air Intake. Use 8mm socket driver or flat head screwdriver to loosen both connections, one at the throttle body and the other by the air filter box. Use wrench to loosen and slid back clip on the PCV hosť (left side, I usually just slide the clip back able 2 inches and leave it on the hose, then gently pull the hose of the fitting. be gentle, the fitting rips very easily on the inside of the elbow). there are 4 snap in points, 2 in front and 2 in back. Lift, unsnap them, being sure the flexible tube is off the air filter housing.
3. Engine cover. unscrew oil cap, then pop off. It is one held in place by 3 snap in fittings.
Peter
CURRENT:
08 Vue XE Black 2.4L
07 Ion 3 Savannah Green Metallic 2.4L
04 Ion 2 Berry Red 2.2
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
95 SL2 Lilac Metallic
94 SW2 White
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
3.5L Vue Door Sills Black Onyx Wing CAI Honda Manifold Cover Acura Engine Cover +More Veo-VUE Classifieds 23 04-03-2016 07:20 PM
Timing Cover Removal - 2000 DOHC engine Aysle S-Series General 20 03-12-2013 12:28 AM
cargo cover removal Casper271 L-Series General 4 06-24-2012 03:22 PM
plastic engine cover removal 2007 outlook giatime Outlook General 2 10-10-2008 11:34 AM
top pan cover removal???? jcurrieirocz S-Series Tech 8 11-16-2002 09:05 PM
