Old 04-19-2017, 03:50 PM   #1
Solar0987
Solar0987 is on a distinguished road
Default Aura door locks
Wife has had the car since it was new, it started with driver side rear door lock not working with keyfob, or with the interior lock switch, now it has moved to 3 of the 4 locks and the interior switch does nothing at all. Car is no longer under warranty, how expensive of a fix is this? Anyone know the part numbers?
Add to Solar0987's Reputation
Rate the quality of this post and help Solar0987 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Solar0987 is offline   Reply With Quote
Old 04-19-2017, 07:01 PM   #2
pierrot
pierrot's Avatar
Default Re: Aura door locks
It would be helpful if you'd have your Saturn vehicle information added into your profile so that it would appear underneath your login name.
It's atypical for each window control switch to fail. Obviously, power has been lost between the switches and some component forward of them. What is needed here is for someone to do a check on your window's electrical circuits. If you're good with electrical diagnosis of this sort then what you need is a wiring schematic. If you don't have a factory manual then go to AllDatadiy,
https://www.alldatadiy.com
or Mitchell Manuals,
http://www.eautorepair.net/Marketing/Default.asp
order a subscription and get the wiring information from one of them. Otherwise, this needs to go to a trained technician.
The cost for this type of repair is based on time only since it's impossible for labor to be calculated on this type of repair. I would expect a minimum of two hours for diagnosis. If all goes well, then that could even include the repair labor. Hourly labor rates vary regionally - lows around $85.00 to highs at or above $120.00. Any parts required will, of course, result in a greater cost and one cannot know what they will be. Therefore the cost of a repair like this is cannot be estimated. Anything further stated by me beyond this is merely guess work and not truly useful.
322,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 04-20-2017, 08:11 AM   #3
gpartrid
gpartrid is a jewel in the roughgpartrid is a jewel in the roughgpartrid is a jewel in the roughgpartrid is a jewel in the rough
gpartrid's Avatar
2008 AURA XR
2008 SKY Red Line
I'm not mechanically inclined but, IIRC, this a common problem AURAs suffer from and typical behavior of failed door lock actuators.
I've experienced this with my trunk. FOB worked on the doors and I heard a clicking near the trunk lock when trying to open it but the trunk would not unlatch. Dealer said it was the actuator.
https://www.yourmechanic.com/article...-lock-actuator
2008 AURA XR
Ocean Mist
Sunroof
Loaded!
Built: 07/19/07
2008 SKY RL
Silver Pearl
Black on Black
6 Disc w. Monsoon
Chrome Wheels
4 Pedals
GMPP Turbo Upgrade & CAI
Built: 09/20/07
Add to gpartrid's Reputation
Rate the quality of this post and help gpartrid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gpartrid is offline   Reply With Quote
Old 04-20-2017, 10:43 AM   #4
pierrot
pierrot's Avatar
If the actuators have gone bad then the diagnosis is still the same if one wants to be accurate regarding the repair. I have to admit that this is really surprising to me, that the actuators are failing like this in the Aura. Of course, it's possible and I have no reason to disagree with information in the previous post. The OP could, if he so chose, to buy an actuator for one door and replace it to see if it corrects the problem. While not the best option for diagnosis, one might do this.
http://www.gmpartscenter.net/auto-pa...umber=22865521 Front door lock actuators, item #7
http://www.gmpartscenter.net/auto-pa...umber=22865519 Rear door lock actuators, item #6
http://www.rockauto.com/en/catalog/s...actuator,13257
The year chosen for the application was just a guess as I don't know the year of the OP's vehicle.
difference between door locks ,2008 Saturn aura flymanansh Aura General 24 08-20-2017 08:56 PM
08 Saturn aura door locks not working properly after programming key fob sfreyler Aura General 0 09-12-2016 08:19 PM
Help! I need help with door locks APope Vue General 3 07-23-2015 03:34 PM
aura door locks - HELP! avenutolo Aura General 5 02-28-2010 08:56 PM
Door locks by itself! cam Ion General 6 04-13-2009 05:07 PM
