Old 07-18-2014, 12:53 PM   #1
cantfigureitout
cantfigureitout is on a distinguished road
Default stumped
my husband has a 03 ion. the other day he drove it school it was fine. he took it to the little store for lunch and it has developed a rough idle and loss of power with a check engine light. we have it hooked up to two different code readers and neither of will work on the car. so we replaced the plugs, no change. so he checked the injectors and replaced on of them, didn't help. so I found this website. the suggestion was the from another rough idle was to replace the icm so we did and again no change. any ideas now would greatly appreciated
cantfiguritout
Add to cantfigureitout's Reputation
Rate the quality of this post and help cantfigureitout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cantfigureitout is offline   Reply With Quote
Old 07-18-2014, 01:25 PM   #2
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: stumped
have you replaced the coil pack?
the coil pack is the single large black piece that has 4 boots for the plugs. the ICM mounts on top of it.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-18-2014, 01:36 PM   #3
Mville
Mville will become famous soon enough
2003
Default Re: stumped
It would really help if you could find out what code is causing the check engine light to come on.
Auto Zone and Advance Auto Parts will usually read out the codes for free.
Add to Mville's Reputation
Rate the quality of this post and help Mville reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mville is offline   Reply With Quote
Old 07-18-2014, 01:50 PM   #4
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: stumped
that too.
suspecting spark plugs, coil pack, and ICM is ususlly a start, as its usually the case 75% of the time.
the only way to really tell, like Mville said, is to get those codes. could be anything
03 ion-2 Sedan 5sp
♕KCCO
Old 07-19-2014, 02:13 AM   #5
cantfigureitout
Default Re: stumped
thank you very much. we finally figured out why we weren't getting a code reading... FUSE, should've known. and we got cylinder number 4 not firing. so the next step is coil pack like was mentioned.
Thank you
Old 07-21-2014, 05:01 PM   #6
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: stumped
sometimes something simple like that can make a huge difference, which reminds me of something to check on my neighbors truck, which had the same issue not being able to get the OBDII software connecting to the vehicle.
the coil pack is not entirely expensive. at the time when i was changing mine, autozone had them for a touch over $100.
03 ion-2 Sedan 5sp
♕KCCO
Old 07-21-2014, 05:53 PM   #7
Default Re: stumped
When the old spark plugs were removed for replacement, did anyone 'read' the plugs? Black oily deposits = oil burning, dry black deposits = excessive fuel mixture or misfiring from that coil, tan white = normal, blistered white = excessively lean fuel mixture. Color reading is based on the center ceramic cone that's white when new.
While "new school" uses training, experience, and computers like readers to retrieve error codes, "old school" still works for the basics like checking for blown fuses first (in this case the power to the power outlet/reader-DLC connector) and relying on long established troubleshooting guides like spark plug reading. Most spark plug manufacturers still have plug charts to show the ways a plug becomes fouled. Anyone can benefit from mixing old with new school..........
Old 07-22-2014, 02:31 AM   #8
cantfigureitout
Default Re: stumped
no the plugs were definitely just "read". there was no unusual color change no build up but most important there was no little node in the center where there should of been. but hat was not the problem. the problem was the coil pack and that is fixed now. but it took a code to tell us that
Old 07-22-2014, 12:27 PM   #9
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: stumped
the codes always get you in the right direction. wasnt the case with my S10 i used to have. after getting the steering column changed, it would never throw a code anymore, which made things fun lol
03 ion-2 Sedan 5sp
♕KCCO
Stumped and need help! faithrisen2 L-Series Tech 3 03-07-2011 01:15 PM
stumped 92SL25SPD S-Series Tech 21 04-07-2010 09:44 PM
Stumped... TonyG S-Series Tech 7 01-18-2010 06:06 PM
OK, I'm stumped kknobl S-Series Tech 20 08-20-2008 11:44 PM
Stumped 1993_SL2driver S-Series Tech 10 11-08-2007 06:06 PM
