Old 05-20-2014, 01:09 PM   #1
djcrisco
djcrisco is on a distinguished road
2005 VUE 3.0L
Default 2001 Saturn SL1 Fuel Pump Relay Not Switching Over
I have a 2001 Saturn SL1 (manual 5 speed) with like 170k miles on it. The other day I was driving home and after a left turn through an intersection it died. I had thought I stalled it out so I just let the clutch out and it jump started. It drove the rest of the way home (about 12 miles) before dying in the parking lot of my apt complex. I tried to jump start it again but it wouldn’t go.
Using Youtube user “richpin06a”'s videos to diagnose the fuel system we determined the fuel pump still turns on by jumping across the relay. When we turn the ignition on we don’t hear the relay click but are able to switch the HVAC relay and the fuel pump relay and the blower still comes on so therefore we can conclude the relay is still good. When the car is off we have 5.5V coming from the green/white wire from the ECC under the hood. This voltage jumps to 12V as you start the car for 2-3 seconds like it should and then goes back down to 5.5V. We tried to probe a test light at the output of the ECC on the green/white wire and nothing lights up which leads me to believe there is not enough current getting through. Under the steering column I hooked up a DMM in parallel to the green/white wire coming from the computer into the junction box and this didn’t show any current when cycling the car.
Add to djcrisco's Reputation
Rate the quality of this post and help djcrisco reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djcrisco is offline   Reply With Quote
Old 05-20-2014, 01:35 PM   #2
billr
Default Re: 2001 Saturn SL1 Fuel Pump Relay Not Switching Over
Is this the same car as in the similar "crank no start help!" thread?
Add to billr's Reputation
Old 05-20-2014, 01:40 PM   #3
djcrisco
2005 VUE 3.0L
no, this is my first thread on the forum
Old 05-20-2014, 03:32 PM   #4
djcrisco
2005 VUE 3.0L
oh i guess my brother posted on this same forum! so yes its the same car
Fuel pump relay? Nuclearwaffles L-Series Tech 5 02-15-2014 11:08 AM
1995 Saturn TC not getting power to fuel pump relay Petesshop S-Series Tech 5 06-19-2012 03:08 PM
92 SC - Where is the Fuel Pump Relay? iamj6g S-Series Tech 6 11-30-2011 09:58 PM
Fuel Pump, Relay? Old95SL2 S-Series Tech 5 04-03-2007 11:34 PM
Fuel Pump Relay Vendetta S-Series Tech 1 03-14-2005 06:25 PM
