Old 05-15-2013, 05:06 PM   #1
macbox
macbox will become famous soon enough
macbox's Avatar
Default Stuck rear brake caliper to knuckle lower bolt
95 SC2, new rear calipers were put on four years ago, now they are seized. I'm in the process of removing the calipers, and the bolts holding the caliper to the knuckle are now rust-welded to the rest of the assembly. I've let them soak for 5 days with kroil and PB blaster, and tried heating them with a map/propane torch (not the real Mapp, the substitute for Mapp), but no luck.
Looking for a little advice. How long should I be heating the bolt, or the metal surrounding the bolt, in order to break them free? Will the map/propane do it if held long enough, or do I need to break down and find a way to get oxyacetylene to these buggers to break them loose? On the passenger side both bolts are 10mm head, and I have the lower bolt out. On the drivers side it is 10mm on the bottom and 17mm on the top, and the 10mm is rounded, and the 17mm I haven't started on yet.
What would be the prevailing wisdom in this situation?
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 05-15-2013, 06:49 PM   #2
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
Default Re: Stuck rear brake caliper to knuckle lower bolt
Red hot and find an impact wrench
Add to johnny95sl2's Reputation
Rate the quality of this post and help johnny95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnny95sl2 is offline   Reply With Quote
Old 05-16-2013, 12:36 AM   #3
macbox
macbox's Avatar
I was afraid there wasn't a simple solution, I guess I'm either finding someone with an oxyacetylene setup or finding one on craigslist.
"The Twins"
Old 05-16-2013, 08:44 PM   #4
85HP
85HP is on a distinguished road
1993 SW1
1998 SW2
I've found a few occasions where propane was sufficient. Biggest drawback with propane is, if the part is massive, it takes forever to heat. The goal of heating is to break the chemical (rust) bond, so you don't want to heat the two stuck parts uniformly, you want to heat one of them to get max. movement due to thermal expansion. It's that movement that breaks the bond. That's my opinion, anyway.
Yep. Let the part cool before hitting it with the impact gun.
6 point impact socket will not damage the bolt heads, and impact will gently drive out the most "impossible" bolts. If you don't own an impact, get one - makes things go very quickly.
Add to 85HP's Reputation
Rate the quality of this post and help 85HP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
85HP is offline   Reply With Quote
Old 05-17-2013, 02:40 AM   #5
^ I agree. ^ Without an impact tool a hammer and steel rod will work. If the heads round off then use bolt extractors.
Old 05-27-2013, 12:16 AM   #6
macbox
macbox's Avatar
I picked up an oxyacetylene torch off of craigslist, and it is my new favorite tool. The 6000˚ heat got the stuck bolts out that all the hardware I had, plus the bolt extractors I bought, could not get out. The rotors were rusted on solid as well.
All my impact did was round off one of the heads, it took the heat to break it loose.
"The Twins"
Old 05-27-2013, 01:50 AM   #7
Nice.
Old 05-27-2013, 09:33 AM   #8
S3aturnR
S3aturnR's Avatar
1999 SL1
you should be spending exactly ZERO seconds trying to separate them. break the bolt head off, buy a new or used caliper bracket and a new set of slides and install them on your car.
time is money and you will literally spend hours and hours trying to get those apart and still probably break them anyway. if you value your time, get new parts...
s3aturnr
Add to S3aturnR's Reputation
Old 05-27-2013, 11:28 AM   #9
^ You're right of course.......... if you're in business but I don't recall the OP mentioning this brake repair related to a business repair. ^ I do agree that it can be aggravating to almost no end when dealing with seized fasteners unless some experience is shared to reduce the time for unusual situations.
On a belated note, if the rotors were seized after only four years (that bolt doesn't look rusted at all) then it may be worth using blue loctite. Loctite serves a dual purpose - to lock fasteners against loosening from heat/cold/vibration and provide a seal against moisture that accelerates corrosion.
Old 05-27-2013, 12:00 PM   #10
Nels
Nels is on a distinguished road
Nels's Avatar
1996 SL
I know that in my own humble opinion, I will just buy complete rebuilt calipers and new rotors for the next disc brake job I do. After all the putzing around with the sticky calipers on my recent front brake job on my Saturn I still ended up replacing one of the calipers anyway. NAPA has rebuilt caliper assemblies with pads included for under $50 each (after exchange). Two bolts, one hose connection, and a quick bleed, and you're done. Well worth it!
And this is also my opinion only --
I see the OP is in MN. I see nothing but bad things happen to rear wheel disc brake setups in this climate next to the Great White North. Rear calipers and rotors do not get enough heat and friction from normal use to be self-cleaning. The few cars I have had with rear wheel disc brakes have always seemed to need the rears changed out due to corrosion rather than wear, and at shorter intervals than the front brakes. Extra maintenance for not much benefit, but they look cool . . . . . ;-)
Nels
Manitowoc WI
1996 SL, 5 Speed manual ╠╬╝
Add to Nels's Reputation
Rate the quality of this post and help Nels reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nels is offline   Reply With Quote
Old 05-28-2013, 12:11 AM   #11
macbox
macbox's Avatar
Nels, you are probably right about rear disc brakes in the north and having to be replaced due to corrosion rather than wear. I actually have some nice calipers from the JY, they were painted and had good hardware, so they are replacing the rusted units.
As far as the "time is money" argument, I'm a hobbyist and do this to learn, to have a working car, to relax, and to preserve the old saturn. Also no need to bust the head of the bolt off when you have an oxyacetylene torch, it works like a charm breaking the rust bond.
fdryer, locktite = yes, I'll be using it for the assembly.
"The Twins"
SW2 front caliper bracket to knuckle bolt? thewanderer S-Series Tech 10 01-17-2014 06:30 PM
Lower Control Arm Bolt STUCK nibowin S-Series Tech 10 10-11-2013 02:13 PM
97 sc2, cant get drivers rear lower caliper bolt off. demoncamber S-Series Tech 6 03-12-2012 05:50 PM
HELP! Fatty caliper bolt stuck and stripped! demoncamber S-Series Tech 8 09-20-2009 01:40 PM
stuck brake caliper Jim Waibel S-Series Tech 9 09-13-2004 01:33 PM
