Old 05-19-2019, 08:30 PM   #5881
Pitcher
Pitcher's Avatar
Default Re: What did you do to your S-Series today...
Replaced the door "Lock/Unlock" switch.
Works great now!
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-19-2019, 08:50 PM   #5882
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Father-in-law replaced the front discs and calipers... and I helped. It was last done almost six years ago. The pads still had some material left, but they were getting brittle.
Also managed to reattach the air dam to the front splash shield, because I missed hearing that scraping noise whenever I go over a speed bump.
Add to Goggles Pisano's Reputation
Rate the quality of this post and help Goggles Pisano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Goggles Pisano is offline   Reply With Quote
Old 05-19-2019, 09:28 PM   #5883
nealt
nealt is on a distinguished road
nealt's Avatar
Replaced the passenger side real trailing arm. The old one completely snapped apart. Made a horrible metal on metal clunk sound when going over bumps... especially backwards. Had to cut the nut/bolt off of the bushing/knuckle end since it was no longer attached to the frame.
I was worried about the frame bolts coming out, but they did, although one bolt I could not get up to torque when tightening... it ended up spinning in the frame around 40 to 50 ft-lbs... should be good enough with locktite on it. Not sure if I will be able to get that one out if this trailing arm ever needs to be replaced again.
Add to nealt's Reputation
Rate the quality of this post and help nealt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nealt is offline   Reply With Quote
Old 05-20-2019, 02:45 AM   #5884
StarLady
StarLady is just really niceStarLady is just really niceStarLady is just really niceStarLady is just really nice
StarLady's Avatar
1992 SC
Cleaned the interior. Well, just half. Tomorrow or the day after will do the other half and apply 303 Aerospace Protectant all over.
1992 SC - TwinCam (Automagic)
Bought it brand new, and still loving it today.
Add to StarLady's Reputation
Rate the quality of this post and help StarLady reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StarLady is offline   Reply With Quote
Old 05-20-2019, 06:37 PM   #5885
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Did an oil change: put in Castrol synthetic blend 5W-30 (high mileage) and Motorcraft 910-S filter.
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 05-21-2019, 11:19 PM   #5886
StarLady
StarLady's Avatar
1992 SC
Oil change done!
Old 05-22-2019, 12:19 AM   #5887
W1PIT
W1PIT will become famous soon enough
2001 SL2
Junked it... see my post under Mice. Good bye!
Add to W1PIT's Reputation
Rate the quality of this post and help W1PIT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
W1PIT is offline   Reply With Quote
Old 05-23-2019, 12:49 PM   #5888
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
My check engine light has been coming off and on for a couple weeks, so I checked the codes. All of them point to the front o2 sensor, so I replaced it. $23 from amazon, I was impressed it came with some copper anti-sieze which is nice.
https://amzn.to/2WljQLo
File Type: jpg Screenshot_20190517-102637_Torque (Lite).jpg (110.8 KB, 96 views)
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is online now   Reply With Quote
Old 05-24-2019, 02:42 AM   #5889
StarLady
StarLady's Avatar
1992 SC
Applied 303 Aerospace Protectant to all the exterior rubber and plastic trim.
It had gotten faded, but now it's dark again.
Old 05-24-2019, 03:11 AM   #5890
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Changed oil again 202 miles OCI due to the idle flush, this OCI was very short treated as a drive-around flush.
PSL20195
20 ounces MMO
2 quarts Mobil Super HM 10w-40
1.5 quarts Mobil Super HM 10w-30
Magnetic plug caught some debris, will cut the Classic L20195 soon.
1999 SL2 A4 -85k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 05-24-2019, 10:55 AM   #5891
Monday: listened in horror as my exhaust suddenly got really loud. Just sitting at the stop sign waiting to turn, about a lock away from work (again - last time, my axle snapped about a block from work). Thought it might be the spot I just repaired with epoxy a week ago.
Made it home but about 5 miles away from home, started hearing intermittent scraping and a few miles from home, became constant as something was hanging low enough to drag.
Looked under, looks like rust between the cat and resonator. It is hanging down forward, looks like the spot where I repaired it held on for quite a while but eventually broke under the constant swaying.
Didn't have time for more than a quick peak as we were leaving to go out of town at 4:30 am next morning and haven't had time to look at it since. Hopefully the flange is in good shape and I can just put in a new resonator and pipes past that.
Lucky that I did not hit a pothole or uneven pavement as the front edge of the resonator I was pushing with my car would have caught it and tore out the whole thing from the resonator back
Old 05-24-2019, 06:58 PM   #5892
NWSaturn247
Cut open the L20195 Classic that I used for the flush for 202 miles.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 05-25-2019, 08:53 AM   #5893
Waiex191
Waiex191's Avatar
I parked it in the garage rather than outside. The A/C in my wife's 2008 Mazda failed and it's still at the shop. To fix it will cost more than the original purchase price of my '98 SC2 and the first round of parts I bought to make it roadworthy.
For the record, Saturns are awesome.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 05-25-2019, 02:58 PM   #5894
Pitcher
Pitcher's Avatar
ESPECIALLY '98 SC2's.....
cc: OldNuc
Old 05-26-2019, 10:18 PM   #5895
Saw this very clever idea by focusofheart for renewing a rubber pedal. Pretty ingenious and it looks fantastic.
http://www.saturnfans.com/forums/sho...98#post2299398
Old 05-26-2019, 11:12 PM   #5896
Melissa_M
Melissa_M is a jewel in the roughMelissa_M is a jewel in the roughMelissa_M is a jewel in the rough
I've turned into kind of a crazysaturnlady, because I take pretty much every opportunity to slip into conversations how wonderful saturns are.
1999 SL2 MANUAL ~78K
Add to Melissa_M's Reputation
Rate the quality of this post and help Melissa_M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Melissa_M is offline   Reply With Quote
Old 05-27-2019, 09:36 PM   #5897
NWSaturn247
Look at all the carbon flushed out by the Chemtool
Purolator L20195 installed for 20 minute B-12 idle flush plus 202 miles.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 05-28-2019, 08:17 AM   #5898
454cid
Isn't B12 only supposed to be added to the fuel? I've had it sitting on top of my pistons, but I'm planning on changing the oil before I run the engine.
1999 Chevy K3500
Add to 454cid's Reputation
Rate the quality of this post and help 454cid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-28-2019, 08:21 AM   #5899
454cid
Picked up valve cover gaskets twice... the first time they gave me VS50594R instead of VS50549R... I didn't need gaskets for a V6 Chrysler/Jeep.
1999 Chevy K3500
Old 05-28-2019, 10:04 AM   #5900
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Finally had my audio replaced, last Friday, with a single-DIN Kenwood and 2-way Kenwood speakers. I need basic sound so I went with simple equipment.
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
