Old 03-24-2019, 06:37 AM   #5821
cityhawk
cityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to beholdcityhawk is a splendid one to behold
cityhawk's Avatar
1993 SW2
Default Re: What did you do to your S-Series today...
Yesterday, I replaced my alternator. Rozzie is now on its 4th alternator. They seem to last in the ballpark of 60-70k miles. I have an extra-long Purolator oil filter on my car, so getting the alternator out and the new one in was pretty special.
Saturns:
1993 SW2 MT 204,000 hard Boston city miles ("Rozzie")
Gone but not forgotten:
2001 LW300 ("Elle")
1999 SW2 MT
Project cars:
1966 Corvair Monza convertible
1928 Ford Model A Tudor Sedan
Add to cityhawk's Reputation
Rate the quality of this post and help cityhawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cityhawk is offline   Reply With Quote
Old 03-24-2019, 04:28 PM   #5822
Originally Posted by Pitcher View Post
Tires, on the Al. Teardrop II, were only inflated to 22-26.
Inflated to 36 front & 33 back, then fine tuned so they're exact on each axle.
Drives better now, so, check & fill the air in your tires!
Pressure changes markedly with temperature.
Old 03-24-2019, 04:30 PM   #5823
What alternator are you buying?
Old 03-25-2019, 05:44 AM   #5824
Pitcher
Pitcher's Avatar
Rolled down the driveway, key on,in 2nd gear & popped the clutch to start it.
LOVE starting my car that way, lol.....
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-25-2019, 07:20 PM   #5825
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Finally got around to doing my odometer bulbs. Did end up following richpin's video and dropping the steering column to get a bit more room to work. All in all a fairly simple job with the right tools and a splash of patience. Also washed and waxed her Saturday.
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 03-26-2019, 04:15 AM   #5826
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Sway bar links in the rear were clunking...
Installed a press in grease fitting on the back, 4 total...
Put a little grease in, no more clunking...
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 03-30-2019, 07:02 PM   #5827
Waiex191
Waiex191's Avatar
The '99 had the stumbles and threw a P1404 for EGR position. Slapped the body panels and wheel back on the '98 to back it out of the hangar. After dinner we'll pull the EGR and clean it. I thought we did when we rebuilt it. Do they wear out?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 03-30-2019, 07:42 PM   #5828
The carbon can hold the pintle off the seat enough that it get hot gas cut and then it leaks all the time eventually causing rough idle and odd carbon buildup. The screen gasket takes care of the carbon flakes holding it open though.
You can leak test it if you have one of those rubber tipped blow guns and an air pressure regulator that you can set for 30 psi. Turn over fill area around closed valve pintle and pressurize through the other port. Bubbles or violent oil ejection is a leaking valve that is no good.
Old 03-31-2019, 10:31 AM   #5829
Signmaster
At some point they do fail, clean or not. Our original was dirty when it first acted up, but after cleaning it still acted up some. Pulling it shows it clean as can be, and it had free movement and such as well.
Old 03-31-2019, 10:47 AM   #5830
Waiex191
Waiex191's Avatar
Thanks. It had a small amount of carbon and we cleaned it. If it fails again we will replace it. For now it is good.
Bryan Cotton
Old 04-01-2019, 11:51 AM   #5831
EGR cleaning used to be on my yearly maintenance list.
With the EGR filter, I do it maybe every other year or three now.
Old 04-02-2019, 04:30 PM   #5832
PaineTrain04
PaineTrain04 is on a distinguished road
Default Please move to proper thread.
Hey y'all.
I couldn't find a thread for this, but I am sure there is one.
New RockAuto 5% discount code.
Your RockAuto discount code 10225047197248015 will expire on April 14, 2019.
Add to PaineTrain04's Reputation
Rate the quality of this post and help PaineTrain04 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PaineTrain04 is offline   Reply With Quote
Old 04-02-2019, 07:59 PM   #5833
bumpdraft
bumpdraft's Avatar
1998 SW2
Cleaned-up a spare driverís seat belt.
The one in the car now doesnlt retract well. So, I watched a video: https://youtu.be/NH3EVut9GXQ
...and fearlessly removed one cover, and then the other cover** . Relizing I was not wounded, I decided to rewind the spring after wiping off the old lube. It can be re-wound. I wound it tighter than it was in hopes of getting better retraction action. It is just a clock spring and not a constant-tension spring.
** wear eye protection
Add to bumpdraft's Reputation
Old 04-05-2019, 06:29 PM   #5834
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Finally cleaned the windshield, inside and out. I also waxed the outside of the windshield. Haven't been out with it yet but it looks a lot clearer than before. Hopefully it helps some with glare at night.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-05-2019, 07:40 PM   #5835
It will do wonders.
Old 04-06-2019, 04:16 AM   #5836
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
Sanding sanding sanding on the 00' SC2 I bought for my kid. He's been no help so down the road it goes after paint and I think a pass side CV axle.
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 04-06-2019, 04:09 PM   #5837
Waiex191
Waiex191's Avatar
Dropped my battery. Plastic strap broke. Was not very high, hopefully no damage done.
Bryan Cotton
Old 04-06-2019, 06:44 PM   #5838
Age related failure or design defect?
Old 04-06-2019, 07:32 PM   #5839
Waiex191
Waiex191's Avatar
I think the battery is newish. It started the car after a -24F cold soak. Looks like the cheapest battery money could buy at Blaine's Farm and Fleet.
Bryan Cotton
Old 04-06-2019, 07:49 PM   #5840
They should upgrade that handle as a battery on the foot could be real expensive.
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
