Old 02-23-2019, 10:38 AM   #5781
Waiex191
Waiex191's Avatar
Default Re: What did you do to your S-Series today...
I washed the coupe.
Well, not really, as I don't do that sort of thing. But it is pouring out.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 02-23-2019, 12:18 PM   #5782
Pitcher
Pitcher's Avatar
Poured "Kreen" in the Gas & Engine Oil.
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-23-2019, 04:55 PM   #5783
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Was finding a spot in the spare tire well for my portable air compressor that I got for Christmas and figured I might as well check the spare tire pressure while I had it out. I last filled it over the summer and it somehow still had 60psi in it. This thing holds air pretty well, wasn't expecting that. Brought it down to about 25 though now that I have the air compressor.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-24-2019, 06:09 PM   #5784
Pitcher
Pitcher's Avatar
New Wiper Blades + Rain-X. 22" blade on the left; 21" on the right.
Old 02-25-2019, 10:49 AM   #5785
Pitcher
Pitcher's Avatar
Pulled the driver's side kick panel & seal, and cleaned out the CLOGGED Drain Tube.
Suggest everyone else with a Sunroof do as well.
Old 02-26-2019, 01:34 AM   #5786
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
Wasn't today, it was actually Friday, but close enough.
I replaced the remainder of the factory cooling system. All new hoses, water pump, thermostat, temp sender, temp sensor, and fresh Dex Cool. I replaced the radiator about 6 months ago, so I consider the cooling system to be completely rebuilt.
I had the upper radiator hose blow out, it split about 3" down the side of it. I decided that enough was enough, and replaced everything. I used gates hoses, gates water pump, stant thermostat, and some off brand for the sensor and sender. And of course, the coolant is Dex Cool.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-27-2019, 05:33 PM   #5787
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
Picked up a shiny new set of 16" wheels and snow tires from a Honda Fit off of craigslist for $300. Can't wait to throw these on the wagon.
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 02-28-2019, 04:49 AM   #5788
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
Too much stuff, to mainly the Coupe, to list but the wagon got new headliner tonight...Again....I used the right adhesive this time. Interior goes in tomorrow, Thurs. Then we start the fun stuff...body work and paint prep.
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 02-28-2019, 09:12 AM   #5789
trottida
trottida's Avatar
[QUOTE=ErikTande;2293815]Picked up a shiny new set of 16" wheels and snow tires from a Honda Fit off of craigslist for $300. Can't wait to throw these on the wagon.
Those look great! How are you going to deal with the smaller center bore size; 56.1mm vs Saturn 57.1mm?
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 02-28-2019, 10:15 AM   #5790
ErikTande
ErikTande's Avatar
I didn't realize they had a different bore size I just knew they were both 4x100 so I assumed they'd fit. I'll try bolt them on tonight and if they don't fit I guess I'll just re-sell them.
Old 02-28-2019, 11:59 AM   #5791
trottida
trottida's Avatar
The hubs won't go through; there is a very tight tolerance even with the 57.1 bore size. You can bring them to a machine shop and have them bore out to the correct size. Don't bore them oversize though as Saturns' are hub centric. You'll likely have to remove the tires.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 02-28-2019, 12:15 PM   #5792
ErikTande
ErikTande's Avatar
Ah crapbaskets. Well, guess I'll try sell them
Old 03-01-2019, 12:04 AM   #5793
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
Had my local garage install new GM/AC Delco engine and trans. mounts and dogbones. One dog bone was obliterated, and you can see the pen test on the top engine mount. What an AMAZING difference. The rattling is gone, and I can now hear how smooth the engine runs. I wish I had done this sooner...
Add to A2Saturn's Reputation
Rate the quality of this post and help A2Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
A2Saturn is offline   Reply With Quote
Old 03-01-2019, 07:31 PM   #5794
SLfun
SLfun will become famous soon enough
2006 ION Red Line
Mid winter tune up! A bit late I know....
New air filter, plugs and oil. Ran a compression test.
1-210
2-210
3-200
4-210
Pretty happy with the numbers, am a bit concerned with cyl 3 though. It got to a decent pressure, but it was a bit slower to rise than the other 3 cyls.
Will have to keep an eye on it.
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is offline   Reply With Quote
Old 03-03-2019, 08:40 PM   #5795
wizerdwolf
wizerdwolf is on a distinguished road
2001 SW2
Rendered my SW2 (temporarily) undrivable.
I started trying to install the Tein WRX coilovers ai bought, but for some reason the passenger side hub is tilted outwards and won't go back up in. I think one of the cv joints pulled out. Going to see if I can't remove the axle tomorrow when it's light out.
I also still need to slot the bottom bolt holes on the rear coilovers upwards still, as I missunderstood the instructions I saw and thought only the front ones needed that.
The driver's side coilover is installed though!!
Add to wizerdwolf's Reputation
Rate the quality of this post and help wizerdwolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wizerdwolf is offline   Reply With Quote
Old 03-04-2019, 07:48 AM   #5796
Pitcher
Pitcher's Avatar
Red Hot Jump-started a Saturn Sky.
Old 03-04-2019, 09:36 AM   #5797
Signmaster
Today? Nothing at all, haven't even seen the car.
Had a teenage driver punt into my passenger side front door leaving work about a week and a half back. At first I thought it just broke the door skin, but the door frame is all bent too, and won't seal up near the top.
So the car is sitting at a shop waiting for parts.
Old 03-04-2019, 08:07 PM   #5798
wizerdwolf
2001 SW2
Popped the CV joint back into place and got all the coilovers on. Think it needs a bit more low though. Going to wait a week to see how it settles.
That said, it's a bit sketch atm as while I was able to tighten the big hat-> damper nuts on the front with just a ratchet after jacking the knuckle upwards to compress the suspension, the same teick failed to work on the back, and the center shaft just rotates. I don't have an impact atm, and Tein cautions about the risk of damaging the inner shaft of these dampening adjustable coilovers using an impact anyway...
If anyone is curious, I'm using Tein Street Advance Z coilovers for the Subaru Impreza WRX. In addition to the normal mods rewuired to make them fit the Saturn, your front top hats will need the bottom hat opening bored out to the inner diameter of the included sleeve/collar that slips on so that it can slide all the way on, and the sleeve/collar thing will need to be omitted.
Old 03-05-2019, 09:55 AM   #5799
SLfun
2006 ION Red Line
Looks pretty cool! What's the ride like?
SL1-2.
Old 03-05-2019, 10:30 AM   #5800
Highmile
Highmile's Avatar
Big weekend for ol Highmile.
New LED headlight bulbs that I have fallen in love with. Cheapies but still love them
4-3/4qts of fresh Valvoline 5w-30 & wix 51516
new muffler
new air filter
4 new NGK spark plugs, old ones were pushing 45k.
new ac delco o2 sensor, old one was prob close to 200k on it.
Then 2 new upgrades that are almost as great as the LED headlights
1. new Wolo bad boy air horn. No more dog squeak toy sounding horn
2. added the lift struts on the hood that I saw in the mod section of the forum
She also got the once over, check front suspension, brakes, lights, cleaned out all the stuff that always seems to collect in my car, vacuumed, etc.
Highmile
'95 SL1 680k and counting
Add to Highmile's Reputation
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
