Old 01-14-2019, 11:46 AM   #5721
Default Re: What did you do to your S-Series today...
Originally Posted by jpags729 View Post
Decided to do an oil change today....and what a mess it became. This is the first oil change I've done on the car, but had a receipt from Valvoline that did the last one. Look what the jack wagons had in my car!
What . . . what is that?
That's what they were using instead of an oil drain bolt?
It's, uh, different. And one of the reasons why I will never use a quick oil change place. I'm sure 80% of the time, everything is fine.
Old 01-15-2019, 02:06 PM   #5722
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
Originally Posted by Waiex191 View Post
Put an electric heater inside the car.
It is plugged into a switch controlled outlet.
BWHAHAHAHA I thought about doing that last week, it's been freezing over and the saturn is always parked outside. Timer at 5am, get in and drive at 6am nice and toasty.
Well done.
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 01-15-2019, 11:16 PM   #5723
bumpdraft
bumpdraft's Avatar
1998 SW2
Tracking down a front-end vibration from 60 to 70mph in 5th gear.
Comp Test
All good.
I checked the mounts a couple days ago. All good.
By grabbing the tire at 12 & 6 olclock, the driver’s wheel bearing felt loose. ...so today I installed a new one.
The old one shows a “change” in wear-pattern on the race at 6 o’clock...so it needed changing regardless...but not in January
Here is one of the threads I’m following: http://www.saturnfans.com/forums/sho...d.php?t=103624
Next suspect, after verifying tires again, is the driver’s AC Delco control arm ball joint. CA was installed 17,000 miles ago. If I only replace one CA, I might get away with just adjusting Toe until the steering wheel is in the straight-ahead when traveling in a straight line.
Add to bumpdraft's Reputation
Old 01-16-2019, 09:12 PM   #5724
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Checking the oil today, I happened to notice the fresh air intake screen was just sitting over the hole completely loose. Gluing it back down shortly
1999 SL2 A4 -85k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 01-17-2019, 09:24 AM   #5725
trottida
trottida's Avatar
I found acoustic caulk to work well.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 01-17-2019, 12:42 PM   #5726
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
I STRIPPED out a few small things, speakers, stereo, hitch, battery.
2000 SL1 in bronze, lots of good stuff, good drivetrain complete with subframe.
Still drives, just no brakes (rear lines)
She is now ready to be hauled away. Would like to keep it around for parts for other projects, but that might cause some tension with the better 3/4's!
So if anyone needs anything or would like to have it for scrap value let me know.
Oh, just a thought. It is a half year gen 3 with no factory air injection. Can you say different exhaust manifold? Rare?
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
Add to mattelderca's Reputation
Rate the quality of this post and help mattelderca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattelderca is offline   Reply With Quote
Old 01-19-2019, 03:31 PM   #5727
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Replaced most fuses with Bussmann EasyID versions...
They have an LED that lights up when they blow...
ATM-ID-SK
Bottom of page, assorted pack of ATM fuses...
https://www.rockauto.com/en/tools/el...blade+fuse,120
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 01-21-2019, 08:49 AM   #5728
Waiex191
Waiex191's Avatar
I did my first real cold soak start in the $500 SC2. It was -5F overnight. Started fine, power steering pump did not sound happy! Just like the '99 SL2. Cabin was warm and windows clear due to my electric heater in the timer.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-21-2019, 09:06 AM   #5729
trottida
trottida's Avatar
Yes, power steering pumps get very angry in the cold. We're in a deep freeze here too; -25.6 F this morning and the Saturn started well enough without a block heater. Power steering pump whined for about 20 minutes before it settled down. Every S Series I've owned has this characteristic.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 01-21-2019, 10:21 AM   #5730
Remove the old GM power steering goo and replace with Amsoil full synthetic universal ATF or Torque-Drive. That usually takes care of the excessively high pump discharge pressure due to the high viscosity. The old GM fluid is not viscosity stable, low Viscosity Index.
Old 01-21-2019, 10:37 AM   #5731
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Was -19 where I am this morning and the car was not happy about it. It started just fine but wow did it feel like it was struggling to turn over.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-21-2019, 02:30 PM   #5732
Any oil gets rather thick at those temperatures.
Old 01-21-2019, 02:52 PM   #5733
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Just ordered a bunch of parts from Rock Auto, including control arms, trailing arms, headlights, upper and lower radiator hoses, brake hydraulic hoses, drum brake hardware, disc brake hardware etc. A lot of this stuff was on wholesale closeout anyways so I figured, why not?
I previously ordered a stabilizer bar so when everything shows up, the control arms and stabilizer bar will be mounted onto the subframe that will eventually be swapped into the SL.
Add to Goggles Pisano's Reputation
Rate the quality of this post and help Goggles Pisano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Goggles Pisano is offline   Reply With Quote
Old 01-26-2019, 12:35 AM   #5734
Goggles Pisano
1999 SL1
Well, all the stuff I ordered a few days ago showed up between yesterday and today, so I got to finally swap the SL's headlights.
The car was a bit lazy-eyed due to an unfortunate incident with a Ford Escape that damaged the adjustment of the driver's side headlight, so it was nice to actually have lights that focus properly rather than two bulbs highlighting the exact same spot.
Old 01-28-2019, 08:59 AM   #5735
trottida
trottida's Avatar
Really cold start this morning at -33 celcius with a -47 windchill! Listen to that power steering pump scream in my 99 SL2. I really need to find a block heater someday.
https://youtu.be/RSG4KWBr4rk
File Type: jpg E1C8FA3E-2FF8-4B24-8227-85C42E3D262C.jpg (67.5 KB, 10 views)
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 01-28-2019, 09:20 AM   #5736
Waiex191
Waiex191's Avatar
Meanwhile my SC2 is in the hangar to clear the driveway from today's snowfall. I keep it at 40f over there.
Bryan Cotton
Old 01-28-2019, 09:26 AM   #5737
SLfun
SLfun will become famous soon enough
2006 ION Red Line
Wow, that's cold! Do you have a trickle charger on the battery?
What oil are you running?
I'm impressed that it started.
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is offline   Reply With Quote
Old 01-28-2019, 09:58 AM   #5738
trottida
trottida's Avatar
No trickle charger, no block or battery heater. I'm running Penzoil SAE 5W-30.
My other Saturn, the 2001 SL1, has been struggling this winter but I think it may be due for a battery. My daughter couldn't get it started without the block heater twice so far this winter and the temperatures were only around -28 Celsius. I made sure she plugged it in last night and I assume she got it running this morning as I haven't heard from her.
Did you eventually find a block heater?
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 01-28-2019, 10:13 AM   #5739
Really cold start this morning at -33 celcius.
That's -27.4F, for us metrically-challenged south of the border
Yesterday, cleaned up the contacts /connector on my 6~7 week old TPS to see if that would help. Did not, so I will be exchanging it with Rockauto as it is still under mfr warranty.
Old 01-28-2019, 10:30 AM   #5740
Waiex191
Waiex191's Avatar
I am rooting for trottida to have a -40 event so we can have some Celsius and Fahrenheit unity.
Bryan Cotton
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
