Old 03-09-2010, 11:22 AM   #1
92SC2
92SC2 is on a distinguished road
Default clunk and steering wheel turns left when I hit the gas
I just noticed that when putzing down the road and I give the accelerator a quick jab with my right foot there's an audible clunk and the steering wheel makes a sharp jerk to the left. It's not enough to cause a wreck, but it's noticeable. It is there to a lesser degree when shifting normally and letting the clutch out. What is causing that? It's a 95 SL2 5 speed FWIW
Add to 92SC2's Reputation
Rate the quality of this post and help 92SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92SC2 is offline   Reply With Quote
Old 03-10-2010, 02:41 PM   #2
92SC2
Default Re: clunk and steering wheel turns left when I hit the gas
Bueller?
Old 03-10-2010, 03:02 PM   #3
RobertGary1
If its in the steering you will be able to reproduce the problem sitting in the driveway. Start the car and turn the wheel back and forth and see if you feel any type of clunking in the wheel. If so its probably an outer tie rod end.
If you feel it mostly when you accelerate in a turn (and not in the driveway) you may be due for a driveshaft; although those seem to be pretty reliable in the S series vehicles.
-Robert
Old 03-10-2010, 03:53 PM   #4
92SC2
it occurs when driving in a straight line. Push the pedal and CLUNK & turn. The steering is otherwise fine with no shake, shimmy, or wobble. I've replaced both lower control arms.
Old 04-22-2015, 12:15 PM   #5
Difficilus
Difficilus is on a distinguished road
Check struts.
Add to Difficilus's Reputation
Rate the quality of this post and help Difficilus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Difficilus is offline   Reply With Quote
Old 04-22-2015, 03:05 PM   #6
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
outer tie rod end(s) most likely. If you hear a clunk BTW QUIT DRIVING IT!
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
Add to underthehood's Reputation
Rate the quality of this post and help underthehood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
underthehood is offline   Reply With Quote
Steering shudder (not clunk) on slow turns ArizonaAura Aura General 9 07-13-2009 05:18 PM
Strut clunk/brakes/steering wheel update LONG POST! bue05 Aura General 3 03-17-2009 06:45 PM
Rubbing noise when turning the steering wheel left or right. turbobuick33 S-Series General 7 09-07-2005 10:56 PM
Grinding noise when turning steering wheel left and/or right rtaylor Vue General 4 01-18-2004 11:27 PM
rythmic metalic squealing on left-hand turns on accel; tire noise on normal left turn rtfm17 S-Series Tech 4 08-25-2003 09:37 AM
