Old 03-06-2009, 08:34 PM   #1
DrPimper
DrPimper is on a distinguished road
DrPimper's Avatar
2009 Outlook XR
Default Door Dinger
After I turn the car off and remove the keys from the ignigtion when I open my driver door the door dinger will be ringing
as if I left my lights on bu the light are off and the keys are outta ignition.
I will be willing just to disconect the ringer of fuse for the car.
any suggestions
My Saturn is a 1997 SC-2 Manual. Power locks & windows.
Add to DrPimper's Reputation
Rate the quality of this post and help DrPimper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DrPimper is offline   Reply With Quote
Old 03-06-2009, 08:46 PM   #2
skii33
skii33 is on a distinguished road
Default Re: Door Dinger
sometimes the ignition button sticks in even after you take the key out, this will cause it to ding...try lubing it with powdered grafite . or wd40 (i know i will get bashed for this)
Add to skii33's Reputation
Rate the quality of this post and help skii33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skii33 is offline   Reply With Quote
Old 03-06-2009, 09:18 PM   #3
SaturnTech122
SaturnTech122 is on a distinguished road
the keyminder you mean, you remove the key and it still chimes, usually its the ignition switch the spring for the keyminder plunger breaks and it wont release, causing it to chime like the key is still in, sometimes its the actual ignition housing but usually the switch.
Certified Saturn Technician
Add to SaturnTech122's Reputation
Rate the quality of this post and help SaturnTech122 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech122 is offline   Reply With Quote
Old 03-06-2009, 09:31 PM   #4
andysouza3235
andysouza3235 is on a distinguished road
andysouza3235's Avatar
yea mine does that sometimes. i usually just push on the lock and it pops into place.
-Andy
Add to andysouza3235's Reputation
Rate the quality of this post and help andysouza3235 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andysouza3235 is offline   Reply With Quote
Old 03-07-2009, 09:03 AM   #5
DrPimper
DrPimper's Avatar
2009 Outlook XR
OK I will give the lube a shot first. I am glad that these first posts all relate to you guys having relations to the Ignigtion, I was dreading it was the reminder ding for the headlights, Not a switch I think would be fun to change, Even if the lube dosent work I have changed Ignigtion switch before and I know thats easy. (somewhat).
Thanks I will let u know how it goes
Jammed door lock Rear door 2003 L200 bobgroh L-Series Tech 0 07-16-2009 11:30 PM
ADVICE? - Screwed up door latch installing door speaker greasemonkey26 S-Series Tech 4 01-07-2008 03:26 PM
What's holding in the power door lock buttons in the door handle? Smokey S-Series Tech 2 09-22-2006 05:52 PM
Inside door panel removal? '93 SC2 -- specifically the door handle... benson500 S-Series Tech 5 12-06-2004 08:48 PM
Door detent or door check link (S series) skijay S-Series Tech 9 02-25-2003 09:33 AM
