#21 | |||||
![]() Quote:
#22 | ||||
![]() Join Date: Apr 2009
![]() Thanks for the tip, looks like after 3 years I am on the right track. Glad to found this site.
#23 | ||||
![]() It's weird what can affect idle. I notice, even when in neutral the engine will idle high until I come to a complete stop. And when I had the wheels off the ground when changing my intake manifold gasket, I could turn the front wheel by hand and the idle speed would change slightly. Not sure if it's a friction thing in the trans or if it's a software thing.
#24 | ||||
![]() I’ve had time to change the ECTS over the holidays, the old one was cracked, not split open but cracks were visible. New one went in without a problem, reset the PCM by pulling out fuse B for about a minute. The new ECTS is registering higher temperatures, before at the quarter mark the engine was warmed up, now it climbs all the way to the 3/8 mark for warm-up. I can now see how a faulty ECTS can underreport operating temperature causing high idle and excessive fuel consumption. My fuel mileage shot back up to where it should be so I am very happy with this minor fix.
Second observation is that the cooling fan should kick on sooner, as the old ECTS was under reporting operational temperatures, I can see how the engine had to be hotter than normal to turn on the fan. I was careful not to over tighten the new ECTS, but it was hard to determine whether the pressure came from the thread sealant or the ECTS being completely in. I did feel resistance all the way through and stopped when I started to feel more resistance. Nothing is leaking as I’ve checked, and I will keep an eye on the water level for the next few days. Say you over tighten the ECTS, would you only damage it, since it is made out of brass, or would the head threads be damaged as well. I’ll try to report back if my “summer only” high idle returns. ![]()
#25 | ||||
![]() Join Date: May 2007
![]() hi thanks for the great tip changed ects sensor with the help of the youtube video, car is running great i have an 94 sc2 with over 300k
#26 | ||||
![]() ***SOHC Intake Manifold Gasket Repair Guide*** This guide was provided by RC1488.
http://www.saturnfans.com/forums/sho...d.php?t=115925 ... Saturnless...
#27 | ||||
![]() *bump for people who don't use search*
... Saturnless...
#28 | ||||
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011
![]() Has anyone that had these high idle problems, also had intermittent rough shifting problems with the transmission, 1-2 and 2-3 forward, and switching from forward to reverse?
Has anyone found an alternative source, reasonable cost new connector for the coolant temperature sensor?
#29 | ||||
1997 SL1
![]() Silly question, but what is considered high Idle? When I'm just sitting there with the car running the rpm is at 1. Is that ok?
#30 | ||||
![]() PM Low Saturn for a replacement connector. He is a member here.
Transmission repair http://www.saturnfans.com/forums/sho...nput+shaft+nut http://www.saturnfans.com/forums/sho...d.php?t=112858 Read these threads and see how your symptoms fit into these descriptions. If you have a bad ECTS the trans will not be real happy and that may be most of your problem. You may also have an intake manifold vacuum leak, it is a common problem on your year. Welcome to the Forums! ![]()
#31 | |||||
![]() Quote:
Warm engine in neutral should be about 800. If you are at 1000 that will be a bit high.
#32 | |||||
1997 SL1
![]() Quote:
(you can tell I don't know much... but I'm a learning! ![]()
#33 | |||||
![]() Quote:
If you aren't cranking the heat and the car is fully warmed up there is a chance either the ECTS is bad or the thermostat is bad. One causes the car to think it's not up to temp and tries to get it up to temp (the ECTS). The thermostat often sticks open when it fails, causing the car to take longer to get up to temp. That causes a proper working ECTS to try and correct the problem. Either condition can also cause a drop in MPG. On the up side, both are cheap and easy fixes.
#34 | |||||
![]() Thanks!
My daughter bought an 01 SL1 from a friend of mine, our first. I am a jeep guy myself, with four 85-89's, but her new jobs is boocoup gobs of miles, and and the SL1 is 31 mpg around here. I hope the random high idle is TPS and ECTS and that it is causing the tranny problem now, other wise this new vehicle is going to be an early pain. Quote:
#35 | ||||
![]() TPS is not usually the cause of a high idle condition that is consistent. This is real easy to check. When the high idle condition is occurring when the car is in park or neutral just turn it of and restart it without touching the gas. If that cures the high idle then it is a TPS issue and if not then it is something else. A consistent high idle is the 2001 SL-1 intake gasket leak problem and you fix it by replacing the intake gasket. The intake gasket leak is also found on some 99, 2000, and 2002 cars. A DIY job that takes the inexperienced about 4 hours. There is a detailed how to posted here. http://www.saturnfans.com/forums/sho...ghlight=gasket
#36 | ||||
![]() Join Date: Jun 2010
![]() Thanks for the write up. Im just confused as to how i would check for vacuum leaks for a DOHC engine because in your post it says SOHC and not DOHC. Can i use the same method on a DOHC 94 sl2 engine? Thanks
... Prince
#37 | ||||
![]() Join Date: May 2009
![]() The same method SHOULD work.
... Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014 I learn from my experiences. If I screw up, I'm sorry.
#38 | ||||
![]() Coo imma try it tomorrow. Thanks guys
... Prince
#39 | |||||
1997 SL1
![]() Quote:
#40 | ||||||
![]() Quote:
Either the ECTS is sending a bad signal that your engine is colder than it really is, or (due to failed thermostat) the engine really is colder than it should be. This tells the engine to add a little gas and idle a little faster to help your engine warm up to normal temps. Normal gauge reading for 96-02 should be around 3/8 Quote:
... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
High Idle AND now High RPMs 1995 SC2 | randibou | S-Series Tech | 3 | 03-20-2009 05:52 PM |
98 SL2 High Idle Issues | SovereignDragon | S-Series Tech | 2 | 12-17-2008 01:33 PM |
high "park" idle and suspension issues | caspervue | Vue Tech | 0 | 10-27-2008 09:55 AM |
High Idle and Other Issues | liubhs02 | Ion General | 3 | 01-31-2007 01:50 PM |
High Idle, Low Idle, Hesitation | Shawn | S-Series Tech | 11 | 04-26-2004 01:29 PM |
