Old 11-16-2012, 06:44 PM   #81
MikeNW
MikeNW's Avatar
1997 SL
Default Re: 00-02 SOHC Intake Manifold Gasket Replacement How-to
Just removed gasket from brother in law's 2002 SC1.
125000 miles.
Yup there was that wrinkle at #1 cylinder. You could see it when you pulled the IM away. Stupid robots.
Somewhere I thought I read that you can tilt the engine forward to get more room. We removed the top engine mount (it was shot anyway- original!) and removed the lower dog bone bolt, and tried to pry the engine forward. Gained us only a half inch or so.
Thanks to all for the info and photos. This is an awkward job. Tomorrow we will install the new gasket. Small pieces of electrical tape on the end of the 13mm socket will be the ticket. Or a small telescoping magnet to install the nuts onto the studs. I can't see how to use a torque wrench, so will use the GoodenTight method.
Time to remove- about 3 hours... Oh well, the learning curve again
08 Burgman 400
Add to MikeNW's Reputation
Old 11-16-2012, 09:37 PM   #82
Unbolt the transaxle dogbone from the midrail and you can pull it forward. Both dogbones have to be unbolted if they are in good condition to get much tilt. You will only get about 2" before the exhaust becomes a problem though.
Do not over tighten, use a 1/4" drive ratchet and you will be OK, larger and an adapter runs the risk of a snapped stud.
Old 03-14-2013, 01:36 AM   #83
pfil
pfil is on a distinguished road
Wonderful information. I've been lurking on this site for years and finally decided I needed register for an account and make a post. I'm most grateful for the ECTS fix I found on here that I was able to do in a NJ parking garage while on a business trip .
My 2001 SL1 w/ 127,000 miles has been getting the misfire on cylinder 1 error code intermittently (once every month or so and usually in the rain if that makes any sense) which always clears itself the next day. In the last week or so the engine started shaking noticeably when idling after work but never when I leave for work in the morning. The shaking goes away when I put the car in neutral (the idle speed also increases in neutral). After work today it was shaking again so I left the car in drive with the parking brake on and sprayed some brake cleaner at cylinder 1's intake and the shaking went away. The idle speed went from about 1030 RPM to 1040 RPM (I expected everyone's description of the idle revving to be more than 10 RPM). I think I will also do a TPS test tomorrow assuming my scanner will display that.
So, a few questions:
Is that a high idle speed?
Is my description fairly definitive that it's the intake manifold?
Is it possible to jury rig fix it (I don't have 4 straight hours where I can go without transportation for a few weeks) with gasket maker caulk-like substance smeared externally to where the fold on that gasket likely is or is that a really bad idea?
Add to pfil's Reputation
Rate the quality of this post and help pfil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pfil is offline   Reply With Quote
Old 03-19-2013, 09:34 AM   #84
pfil
Well, I decided caulking the intake manifold was probably more trouble than it was worth and I have some free time this weekend so hopefully replacing the gasket does the trick.
Old 03-19-2013, 10:02 AM   #85
BV22
2002 SC1
Idle speed in drive with parking brake set should be 750-800 rpm. Fast idle plus P0301 code on a 3rd gen SOHC car is almost always the intake manifold gasket. If you hear a "putt-putt" sound in the exhaust when the engine is shaking at idle, that would be even more evidence.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 03-25-2013, 03:04 AM   #86
Dogismycopilot
Dogismycopilot is on a distinguished road
Happy Re: 00-02 SOHC Intake Manifold Gasket Replacement How-to
Many thanks to all who have posted on this thread. Especially Richpin for his how-to videos.
Starting Friday evening when I removed the hood, the air intake, the battery and got prepared for Saturday (and Sunday, I had to drive people around in the only other available vehicle which I also used to drive to the auto parts store several times).
It's all done. The IM gasket, the fuel filter, the ECTS, the transmission fluid/filter, the serpentine belt and the coolant.
The car drives better at 110,000 mi. than it did at 60K when I bought it!!!
I can't wait to drive to work tomorrow.
Add to Dogismycopilot's Reputation
Rate the quality of this post and help Dogismycopilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dogismycopilot is offline   Reply With Quote
Old 03-27-2013, 12:34 PM   #87
pfil
Thanks to everyone. My car runs much better now. It took me closer to 7 hours but mostly because I broke for lunch, cleaned the throttle body, IAC, and EGR while I was changing the intake manifold gasket. Plus I didn't watch Richpin's video on putting the serpentine belt on until after I did it myself and the only way I could figure out to get it on the crankshaft was to take off the passenger side wheel and go in from that direction. I'm also a bit prone to dropping bolts or sockets for my ratchet and then spending 15 minutes looking for them... I was very sore the next day but the car runs much better and I probably saved a few hundred dollars!
Old 05-27-2013, 07:36 PM   #88
Mike R
Mike R is on a distinguished road
2000 SL2
Thanks to all who have posted information in this thread. I just finished my 2001 SL1 and it runs great. It took me just over 4 hours but I also cleaned the throttle body and egr. I found it was easier to remove all the power steering pump bolts and set it aside but I also have huge gorilla hands.
Add to Mike R's Reputation
Rate the quality of this post and help Mike R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mike R is offline   Reply With Quote
Old 10-29-2013, 08:05 PM   #89
VenomMacbeth
VenomMacbeth is on a distinguished road
Hello, all. First post!
Okay, so, I have a 2000 Saturn SL1 with the SOHC engine. A few days ago, I noticed what appeared to be a misfire coming from the engine when in neutral (intermittent "bump" while idling.) The check engine light wasn't on, but the pop was still very noticeable. I googled the problem & found out about the intake manifold gasket issue. I didn't bother performing the brake cleaner test, as the gasket was pretty affordable & I had two days off from work, and I figured it would need done eventually anyway. Well, I got the car back together today & it still seems to misfire, but significantly less than before. I didn't replace the ECTS or thermostat, and I didn't reset the computer. Anyone know what else the problem could be? Thanks in advance!
[EDIT:] I have a manual transmission, also. Not sure if that's pertinent...
Add to VenomMacbeth's Reputation
Rate the quality of this post and help VenomMacbeth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VenomMacbeth is offline   Reply With Quote
Old 10-29-2013, 08:09 PM   #90
SL19302
SL19302's Avatar
2002 SL1
When was last time you performed a tune up on the car, plugs, wires?
Add to SL19302's Reputation
Old 10-29-2013, 08:17 PM   #91
VenomMacbeth
Well, I just bought the car a couple weeks ago now with 120k miles on it. The guy said he replaced the plugs & wires, and they indeed seemed very new-looking (at least the wires did).
Old 10-29-2013, 08:23 PM   #92
SL19302
SL19302's Avatar
2002 SL1
Two basic tests to do when a misfire is present and you know the plugs and wires are new is a fuel pressure test to make sure the pressure is within specs, and most of all a compression test on all four cylinders.
Old 10-29-2013, 08:28 PM   #93
What brand/type of spark plugs?
Is there a misfire CODE present?
Inspect the ECTS to see if it's the new(-ish) brass type. If not, replace it before chasing your tail.
Add to madpogue's Reputation
Old 10-29-2013, 08:31 PM   #94
SL19302
SL19302's Avatar
2002 SL1
+1^^^^ For checking and/or replacing the ECTS sensor with the brass unit.
Old 10-29-2013, 09:20 PM   #95
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
^^^The gasket and the ECTS are the reason I received my 2000 SL1 for free.
Check the plugs, make sure they are not a fine wire platinum and ensure the plug wires are in the correct order, coils 4 1 23, plugs are 1 2 3 4 starting from mamas side of the vehicle.
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
Add to mattelderca's Reputation
Rate the quality of this post and help mattelderca reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattelderca is offline   Reply With Quote
Old 10-30-2013, 01:08 AM   #96
VenomMacbeth
Would the ECTS cause it to misfire? I'm hoping it's either that or bad plugs/wiring, like what you guys said. I'm getting new tires & an alignment tomorrow, so I'll see then if either of those are the issue. I'll more than likely replace the ECTS anyway, as I'm pretty certain it's the original. Also, it's not throwing any codes at all, and the engine temperature is typically at/below the quarter mark (even though it was up to the halfway once, last week.) Thanks for the suggestions!
Old 10-30-2013, 02:13 AM   #97
If the temp gauge is that low, either the thermostat is stuck open, or the ECTS has failed, or both. ECTS will cause engine running problems, usu. running too rich, may appear to be a misfire. An actual misfire should throw a code.
Old 10-30-2013, 05:50 AM   #98
SL19302
SL19302's Avatar
2002 SL1
With temps that low, Replace the Thermostat AND the ECTS while the system is drained, This will allow the engine to get to proper operating temp once again and possibly cure any idle/performance issues you are currently having.
Old 07-27-2014, 08:48 PM   #99
FaFaFooey
FaFaFooey is on a distinguished road
2002 SC1
Did anyone else have trouble getting the fuel hose bracket to line back up to the manifold? I think it's very close to it's original position but the screw will only go back in about half way.
Add to FaFaFooey's Reputation
Rate the quality of this post and help FaFaFooey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FaFaFooey is offline   Reply With Quote
Old 07-27-2014, 10:14 PM   #100
OneBadBurb
OneBadBurb is on a distinguished road
Yeah it's funny you mention that, I just swapped the manifold gasket out on my 2001 SL today, and it was a little bit of a bear to get the fuel line bracket back on. I ended up having to take both the bracket off at the manifold, and detach the rubber part that attaches the lines to the bracket. To get it back on I put a light ratchet strap on the bracket, and ran it under the block to the front of my garage to pull it forward and down so that I could get the bolt to go in straight. I know it's not really good for it to be in a bind like that, but that's how I did.
P.S. For anyone about to do this repair, wear gloves lol. My fingers are now all cut up from all the burrs on the old gasket where I decided to slide it out without gloves on..
2001 Saturn SL1 (DD) - Magnaflow Muffler, Polyurethane Inserts/Bushings, Torrent Cluster, awaiting high compression DOHC engine (in progress).
1998 K1500 Suburban
1998 Sonoma
Add to OneBadBurb's Reputation
Rate the quality of this post and help OneBadBurb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OneBadBurb is offline   Reply With Quote
99 SOHC Intake Manifold Gasket Replacement Floggingamy S-Series Tech 0 05-21-2008 02:52 AM
Intake manifold gasket replacement? SaturnManiac S-Series Tech 9 03-15-2008 06:59 PM
another 2000 SOHC intake manifold gasket eljefino S-Series Tech 1 06-29-2006 06:48 PM
Intake manifold gasket replacement Gator S-Series General 7 11-04-2005 08:46 PM
DIY Intake Manifold Gasket for 2000-01 SL SOHC TowGuy How-To Library 0 02-25-2005 08:36 PM
