Old 11-22-2007, 04:49 AM   #1
wchiro
wchiro is on a distinguished road
Default 95 SL1 L24 No compression
Just bought a 95 Saturn SL1 with a L24 engine. It has no compression while cranking. I removed the valve cover and found all the intake valves stuck open. What would cause this? Anyone have this problem? Previous owner said that it was gradually losing power and just died.
Add to wchiro's Reputation
Rate the quality of this post and help wchiro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wchiro is offline   Reply With Quote
Old 11-22-2007, 06:15 AM   #2
bobfather99
bobfather99 is on a distinguished road
1994 SL1
Default Re: 95 SL1 L24 No compression
If all intake valves are stuck open, you may have 4 bent intake valves.
Did the timing chain/sprockets give way???
You may have to further tear down the engine to get a better diagnosis.
Bob
Add to bobfather99's Reputation
Rate the quality of this post and help bobfather99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobfather99 is offline   Reply With Quote
Old 11-22-2007, 07:38 AM   #3
oseberg
oseberg is on a distinguished road
I believe you should take a look at this thread:
http://www.saturnfans.com/forums/sho...d.php?t=108245
Do the SL1's have hydraulic valve lifters?
Add to oseberg's Reputation
Rate the quality of this post and help oseberg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oseberg is offline   Reply With Quote
96 SL1 Compression IMDM S-Series Tech 8 06-05-2008 11:18 AM
LKO to L24 gnalan S-Series Tech 10 03-23-2008 11:57 AM
95 Saturn SL1 Cylinder Compression lentinman S-Series General 5 08-06-2005 04:50 PM
Compression test results for a 95 SL1 Av8r S-Series Tech 2 03-16-2005 11:39 AM
Odd Compression Test Results - 93 SL1 GmG S-Series Tech 12 01-04-2004 11:01 AM
