Old 11-09-2019, 04:38 PM   #1
aygc271
aygc271 has a spectacular aura aboutaygc271 has a spectacular aura aboutaygc271 has a spectacular aura about
Default Putting 1999 SC2 wheels on 2000 SL2
Hey guys, quick question. I have a 2000 SL2 I've had forever. My buddy's 1999 SC2 just died on him, and he has 4 nearly brand new tires on his wheels. The SL2 tires are 185-65-r15 , his SC2 has 195-60-r15 tires on it. Would this be a clean wheel swap? Seems senseless not to yank them off the car before it goes to the junk yard. I have the metal wheels, he has the crappier ones with the plastic hub caps.
Add to aygc271's Reputation
Rate the quality of this post and help aygc271 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aygc271 is offline   Reply With Quote
Old 11-09-2019, 05:36 PM   #2
Default Re: Putting 1999 SC2 wheels on 2000 SL2
Any stock S-Series wheel will fit on any S-Series.
As long as both are the same wheel size there will only be minor speed/odo-meter discrepancy (under 2.3%). Likely won't notice between the 2 stated size's.
Old 11-09-2019, 05:46 PM   #3
Waiex191
Waiex191's Avatar
From my calculations your speedo will read about 2.7% slow. That is assuming they program the sedans different from the coupes with respect to tire size.
Edit: that's not right. That is the difference in the sidewall height, overall radius change will be a lot less.
Edit 2: about 1.05% slow. Go for it.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-09-2019, 06:30 PM   #4
onlinebiker
Score the whole car if you have the real estate to keep it.
There's a bunch of parts that will interchange...
Edit to add -
Steel wheels RULE!
I would pay extra not to have to hassle with aluminum rims....
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-10-2019, 10:25 PM   #5
454cid
I thought the steel wheels were 14s?
1999 Chevy K3500
Add to 454cid's Reputation
Old 11-10-2019, 10:31 PM   #6
14's were steel only (14x5 I believe)
15's were steel or alloy on the SL2 and SW2
15's were alloy on SC2 and optional on the rest
Not sure how wide the 14's are but the 15's are all 6 inch's.
They're fully interchangeable so that is only valid for what came on the cars from the factory...not what happens to be on one now that it's 17+ years out of the factory
Old 11-10-2019, 10:49 PM   #7
Waiex191
Waiex191's Avatar
My '99 came with steel wheels from the factory.
Bryan Cotton
Old 11-11-2019, 10:38 AM   #8
454cid
Thanks for the info.... it looks like I'm going to go to the 195/60's on my SL2.... I really need tires TODAY, and no one seems to stock much in the 185/65 size. The one Discount Tire that has the tires I want.... no power, so they're closed today. If I go to the SC2 size, I can get them today/closer, so I think that's what I'm going to do.
I'm getting snow tires, so I'll be keeping my eye out for more rims.
1999 Chevy K3500
Old 11-13-2019, 05:38 PM   #9
marmitage
marmitage is just really nicemarmitage is just really nicemarmitage is just really nicemarmitage is just really nice
marmitage's Avatar
2003 VUE 3.0L
I always go for the 195-60-15 just like the ride and look better.
marmitage
03 Vue Silver, Daughters
97 SL2 Back from the grave
99 Sw2 Daily driver
Add to marmitage's Reputation
Rate the quality of this post and help marmitage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marmitage is offline   Reply With Quote
1999 SL-2 with a 2000 Engine in it Aysle S-Series Tech 16 01-13-2011 08:09 PM
Alloy wheels for 1999 SW2 halmiles S-Series General 13 12-15-2010 03:08 AM
Putting a 2001 SOHC motor in my 2000 SL1 pimpin88 S-Series Tech 7 11-27-2009 12:31 AM
1999 SL2 - Vehicle revs past 2000 RPM when putting in park. Why? 2002SaturnMan S-Series Tech 54 02-03-2009 12:06 AM
2000 motor in a 1999 succendo S-Series Tech 6 03-17-2007 04:41 AM
