Old 10-15-2015, 07:29 AM   #81
KDulcimer
KDulcimer is on a distinguished road
1996 SW2
Default Re: Used Oil Analysis Thread for Our Engines.
I always use Mobil 1 or Pennzoil Platinum. I believe this one was Mobil 1.
SaturnFans helper map: http://bit.ly/1uDorVF
1998 SW2 & 2002 SL sold, but I still see them around!
Purchased automatic 1996 SW2 September 2018.
Add to KDulcimer's Reputation
Rate the quality of this post and help KDulcimer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KDulcimer is offline   Reply With Quote
Old 10-31-2015, 08:35 PM   #82
KDulcimer
1996 SW2
For the record, I think I found the source of my above issue. The air filter is fine, but the last time I cleaned the throttle body, I forgot to tighten a hose clamp.
Old 02-13-2016, 11:23 AM   #83
Sid
Sid will become famous soon enough
Sid's Avatar
1996 SW2
Previous oil and filter: Mobil 1 Extended Performance 5w30, WIX 51348XP filter.
Last oil and filter: Amsoil signature series 0w30, WIX 51348Xp changed after 1 year (recommended by Amsoil)
New oil and filter: Amsoil 0w30 and WIX 51348XP filter.
Oil use for both oils was my typical 1/2 Qt per 1,500 miles. The 0w30 oil use may have been a tad less than the M1 5w30.
Less shearing with the Amsoil than the M1 oil as expected.
96 SW2 5MT
Add to Sid's Reputation
Rate the quality of this post and help Sid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sid is offline   Reply With Quote
Old 08-30-2016, 09:23 PM   #84
saturnsctwo
out of curiosity has anybody gotten an oil analysis who uses an oil filter magnet? if so did it make a difference with the iron particles in the oil?
Add to saturnsctwo's Reputation
Rate the quality of this post and help saturnsctwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-03-2016, 09:25 PM   #85
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default 2002 Saurn SL2, Mobil 1 AFE UOA
Mobil 1 Advanced Fuel Economy, 0W-30
Purolator Synthetic PSL 20195
2500 miles, 2 years
Changed due to time
Mostly long highway drives, 2 hours+
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 03-29-2017, 09:57 PM   #86
RB97SL1
RB97SL1 is on a distinguished road
I bought a 1997 SL1 new. I changed the oil every 3,000 miles with Valvoline 5W30. The car has 330,000 miles on it and still runs good. I have to add a 1/2 quart of oil per week.
Add to RB97SL1's Reputation
Rate the quality of this post and help RB97SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RB97SL1 is offline   Reply With Quote
Old 10-06-2017, 10:15 PM   #87
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
My first analysis
1999 SL2 A4 -85k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 10-06-2017, 11:54 PM   #88
Eiron
Eiron will become famous soon enoughEiron will become famous soon enough
Eiron's Avatar
1999 SW2
So, your sig says Valvoline HM 5W-30 + LM2009, but the report says Mobil 1 5W-30. Was this UOA M1 w/o LM? And was it the HM M1? Also, are you using the larger 20195 filter shown in your sig?
Some interval questions:
How long did it take you to reach 5544 miles?
How much make-up oil did you have to add?
What kind of air filter are you using?
That's all I got for now.
He's dead Jim!
You grab his tricorder, I'll get his wallet.
Add to Eiron's Reputation
Rate the quality of this post and help Eiron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eiron is offline   Reply With Quote
Old 10-07-2017, 01:36 AM   #89
NWSaturn247
Oil used in OCI
Initial:
1 quart Mobil 1 HM 5w-20
3 quarts Mobil 1 5w-30
15 ounce bottle of STP High Mileage Oil treatment
Bosch Distance Plus D3422
2 additional quarts of Mobil 1 used for top-off during OCI
OCI duration, ~2.5 months
Purolator Classic air filter installed
Cleaned throttle body just a couple hundred miles before oil change and installed a fresh Purolator air filter
I add 2 cycle oil to nearly every fuel fill-up
My emissions are very low when tested by my Department of Motor Vehicles
Currently I am using the Valvoline with LiquiMoly and Purolator Synthetic filter. I did not use it in the oil analyzed.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 10-07-2017, 12:41 PM   #90
Eiron
Eiron's Avatar
1999 SW2
Cool, thanks! A few more questions:
Why are you adding the STP?
Do you add the 2 cycle oil to the fuel? And if so, how does it benefit?
2 qts in 5,500 miles sounds relatively low for top-up (around here), and your numbers look reasonably good. Combined with your short amount of time (lots of highway miles?), why wouldn't you top up with M1 HM and extend out to 10,000 miles?
He's dead Jim!
Old 10-08-2017, 12:07 AM   #91
NWSaturn247
I stockpiled some products during the great $5 off $5 days at O'Reilly.
The 2 cycle oil seems to clean things up and help with emissions. Last test my old beast only polluted 15ppm HC. Pretty darn good. Oregon allows 220ppm. Also my car emitted zero Carbon Monoxide.
Check this site
http://www.ls1.com/forums/f48/been-testing-oil-91206/
I also have this device installed which may reduce emissions
http://nvfuelsaver.homestead.com/index.html
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 10-24-2018, 05:39 PM   #92
Dooter11
Dooter11 is on a distinguished road
2000 SL2
I love this thread, so much in depth analysis, is there anyone still using a specific oil since you last posted (3+ years ago)? I have a high mileage SL2 (280k) and I want to extend its life as much as possiblr, was wondering if anyone has been using a specific high mileage oil that works really well?
Add to Dooter11's Reputation
Rate the quality of this post and help Dooter11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dooter11 is offline   Reply With Quote
Old 11-22-2018, 10:40 PM   #93
mattwithcats
Asking what oil is best for a S Series is like asking whatís the best ice cream flavor....
If your burning oil, a diesel rated CJ or CK may help unclog the piston drain back grooves.
Shell Rotella T5 In 10W-30 is a good economy choice, if your temps donít go below 32 F regularly...
Shell Rotella T6 in 5W-40 works to 0F, and T6 in 0W-40 (Look online at Advanced Auto) for below 0...
If your not burning oil...
I use Pennzoil Ultra Platinum, 10W-30 down to 32 F, and 5W-30 below 32 F...
For below zero, or max mileage, try Mobil 1 0W-30 Advanced Fuel Economy (my choice for an automatic) or Emission System Protection (for a manual)....
Old 11-22-2018, 10:45 PM   #94
mattwithcats
NAPA Black Friday sale
Friday November 23 and Saturday November 24, 2018...
Mobil 1, all flavors, $4.99 a quart...
Going to get more 0W-30 ESP....
https://www.napaonline.com/en/search...rce=DEAL_1_CTA
Old 04-15-2019, 05:21 PM   #95
jhonky
jhonky is on a distinguished road
Here is my latest test
File Type: jpg AB0D9981-D1AD-4603-8ED5-D185D47AC2CA.jpg (157.6 KB, 12 views)
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 04-15-2019, 05:46 PM   #96
jhonky
The 2.5 quarts of makeup oil should be 1.5
98 SL2
245,000 miles
215/45 17"
Old 04-15-2019, 11:29 PM   #97
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
Oil and coolant samples were left at Blackstone Labs while in Fort Wayne last Sunday morning. Results were emailed before 5 Monday afternoon. Pulled a 30k mile coolant sample to look for oil contamination from a rebuilt head installed 2 ago. When I got it back after the rebuild, the coolant still looked like a chocolate shake. I did several flushes using TSP, start/stop/cool cycles, and gallons of distilled water as rinses to clean the system. The report came back saying it was fully serviceable coolant with zero oil contamination. Currently using Peak 150k mile anti-freeze. There's a gallon of Evans coolant on the bench for a future project to start on...
Add to A2Saturn's Reputation
Rate the quality of this post and help A2Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
A2Saturn is offline   Reply With Quote
Old 11-12-2019, 02:48 PM   #98
Mr.Squeaky
Mr.Squeaky is on a distinguished road
1996 SL1
My Oil Analysis
Original owner 96SL1 220,000 Miles
Add to Mr.Squeaky's Reputation
Rate the quality of this post and help Mr.Squeaky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mr.Squeaky is offline   Reply With Quote
Old 11-13-2019, 08:13 AM   #99
Pitcher
Pitcher's Avatar
Nice. Good oil & agree w/Blackstone.
Get a long run, hot sample next time to see if that Flashpoint increases.
Thanks for posting!
Owned 4 other S-Series.
Add to Pitcher's Reputation
Another spark plug analysis thread WarWeasel S-Series General 1 07-04-2011 05:44 PM
Oil analysis - 09 xr VUESBROTHERS Outlook General 4 06-29-2010 10:48 PM
Follow up thread to the ignition key cyl thread Scott Peterson S-Series Tech 3 06-09-2010 08:00 PM
A Look at Oil Analysis for 92 Sl2 stanleyr S-Series Tech 2 05-18-2007 09:08 AM
04 Vue V6, Oil Analysis HomeBase Vue Tech 4 01-06-2005 01:52 PM
