Old 11-03-2019, 09:03 PM   #1
nealt
nealt is on a distinguished road
nealt's Avatar
1997 SC2
1999 SC2
Default SC2 Side Window Gear Box Jammed
Anybody have a front side window gear box lock up on them?
I think a kid tried to lower the window too hard when it was frozen in place last week. Now the window is stuck down and the handle just spins around. The gear box that the handle is connected to is non-functioning, and I could not even pull the window up by hand.
I ended up cutting off the gear with a grinding wheel so that I could pull the window back up. Then I screwed the window in place permanently in the UP position. It's a hack, but at least it'll stay dry.
Add to nealt's Reputation
Rate the quality of this post and help nealt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nealt is offline   Reply With Quote
Old 11-03-2019, 09:42 PM   #2
Default Re: SC2 Side Window Gear Box Jammed
Sounds like the window regulator broke. Not common but common enough the part isn't unobtanium priced.
ACI 81916, $56 on Amazon ($2 more on RockAuto).
Old 11-03-2019, 10:49 PM   #3
nealt
nealt's Avatar
1997 SC2
1999 SC2
Thanks - that looks like the part. I need the passenger side. And it's $13 more on Amazon for some reason. RockAuto has them the same price.
I guess the driver side must be higher volume (and lower cost) since it's used more and thus breaks more.
It is a pain to swap those out? I didn't have much room to work with at all when I cut that gear out.
Old 11-03-2019, 11:09 PM   #4
The only way to replace it is to take the outer skin off, there's a mostly solid metal panel between the inner panel and anything useful.
With the environment here I'd rather replace the whole door rather than risk snapping every mounting point on the door skin. Total design oversight on GM's part, no way to get anything on the bolts to get them to loosen easier and no reinforcement on the panel to not rip it to shreds.
Old 11-04-2019, 08:39 AM   #5
trottida
trottida's Avatar
I would drill out the torx head on the door panel fasteners and replace them rather then trying to turn them and risk breaking the door panel tabs.
I've saved a set of them from my parts car should I ever need to access the window regulators. I'm sure you can buy them somewhere if needed.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
trottida is online now   Reply With Quote
Old 11-05-2019, 09:14 PM   #6
nealt
nealt's Avatar
1997 SC2
1999 SC2
Good advice. I wish I posted this first before trying to take the door panel off.
Those door tabs are very easy to break with a stuck door panel fastener... a few already broke the plastic tabs on the hinge side of the door. Fortunately, the door panel still seems pretty secure when I put it all back together. I'm not too sure about next time, however.
I need to find the differential side gear seal for side gear seal Saturn sl 94 Fefe Cat S-Series Tech 2 05-08-2015 01:47 PM
Passenger side seat belt jammed (97 SC2) Starlight S-Series General 3 06-15-2013 11:02 PM
Window regulator motor or gear? cottonwood S-Series General 10 11-09-2009 09:17 PM
Driver's side power window pooped out again 99SC2; other window/sunroof fine. Help? Jens99SC2 S-Series Tech 4 11-09-2005 07:40 AM
Jammed power window. Spazie Miscellaneous Tech 8 07-06-2003 02:56 AM
