Old 10-29-2019, 07:00 PM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default Torque for Saturn aluminum rims?
I just switched out my steelies for stock aluminum Saturn rims made by Enkei.
I generally torque my lug nuts to 103 foot pounds, per the manual.
Now whenever I remove a lug nut, slivers of aluminum fall out. So I wonder if the torque spec for the aluminum rims is different?
What is the proper torque spec when using Saturn aluminum rims?
Add to TwoFistedJustic's Reputation
Rate the quality of this post and help TwoFistedJustic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwoFistedJustic is offline   Reply With Quote
Old 10-29-2019, 07:28 PM   #2
trottida
trottida's Avatar
Default Re: Torque for Saturn aluminum rims?
103 ft-lbs...same as steel wheels
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-29-2019, 11:39 PM   #3
Should have gotten new lug nuts too, steel rim lug nuts have a different beveled area from the aluminum wheels and nearly every steel rim lug nut I've looked at was 100% ruined anyway.
Old 10-30-2019, 06:22 PM   #4
454cid
I didn't think of that.... I grabbed a steel fullsize to use as a spare. I did grab the lug nuts too, but I don't think they're in the car. I just took them instead of leaving them on the ground, or in the salvage yard car.
1999 Chevy K3500
Add to 454cid's Reputation
454cid is online now   Reply With Quote
14 Inch Steel Rims vs. 15 Inch Aluminum Rims PaineTrain04 S-Series General 3 03-19-2019 02:52 PM
aluminum rims leak scalemechanic S-Series General 8 04-21-2011 10:15 AM
Torque on factory aluminum 18" rims Vue in Ontario Vue Red Line 6 08-18-2010 08:24 PM
aluminum vs steel rims dnwoody S-Series General 32 01-31-2010 01:32 AM
Aluminum Rims on SL1 92SL1Mann S-Series Mods 21 06-15-2007 09:32 PM
