#6261 | ||||
![]() Last time I had to drain mine I just removed the one bolt holding it on and dumped it into a bucket. I know 3rd gen has a different bottle shape though and I'm not sure if it's mounted differently. Should be similar though as long as the air pump doesn't get in the way.
... 97 SL2, auto, 116K miles Powered by Plastic
#6262 | ||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
1997 SL1
![]() Buy a bottle of 70% or 91% rubbing alcohol and put in the whole bottle. It will not freeze and then add winter mix.
1995 SL1 236,300 2005>2018 1997 SL1 79,081 2014>???? CHECK YOUR OIL!!
#6263 | ||||
![]() ![]() ![]() Join Date: Aug 2010
2000 SW2
![]() Swapped the rear doors with inoperable rear windows (and glued shut and still fell, looked nasty) with working and great shape rear manual crank doors!! I left the tan panels on the inside even with the rest of the interior is gray!!
Then had the near new tires swapped from the parts cars steel rims to the wagons aluminum rims!! Then got an alignment on the wagon!! ... Ryan 97 SL2 Mack Charcoal 5 speed, 238k miles, bought 11/18/15 98 SL2 Pearl White auto, 190k miles, 11/7/15 RIP S-series Shop Manual: http://www.saturnfans.com/forums/showthread.php?t=177672
#6264 | |||||
2000 SW2
Or grab the condensed rainX brand that you add to a gallon of regular stuff. Because that is all they sell out here, no regular winter stuff (San Diego)... ... Ryan 97 SL2 Mack Charcoal 5 speed, 238k miles, bought 11/18/15 98 SL2 Pearl White auto, 190k miles, 11/7/15 RIP S-series Shop Manual: http://www.saturnfans.com/forums/showthread.php?t=177672
#6265 | ||||
![]() ![]() ![]() Join Date: Apr 2008
![]() ^ Turkey Baster or long shampoo bottle hose & nozzle.
![]() ... Proud Owner of an Invincible '98 SC2 Rare "Red Hot" 5-Speed. Castrol Edge EP + M1 Ext Perf. Oil Filter. Owned 4 other S-Series.
#6266 | ||||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
![]() It would probably be easiest just to use a siphon. A piece of rubber hose would do the trick, fill it with water or washer fluid, keep your thumb on one end and drop the other end to the bottom of the tank and lower the free end to a point below the tank and release your thumb and drain back into a container.
... 1999 SL2 MT (287,130 km @ 10/2019) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada:
#6267 | ||||
![]() ![]() ![]() Join Date: Oct 2016
![]() I siphoned out my washer reservoir in my $200 Buick Century when I had to replace the pump. Worked great.
... Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018
#6268 | |||||
http://www.saturnfans.com/forums/sho...d.php?t=145117 Kaervak's post indicates there is a bottom bolt close to the side light, which sounds about right. The washer tank is very long. Though, if you get down there, I suspect you could just pull the hose or pump out to drain it. Again, it's been several years and I don't recall the setup down there. Been several years since I pulled a 3rd gen washer tank; probably 6 years ago. I think I was planning of trying to fit it into my 2nd gen SL2 to increase capacity ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
#6269 | ||||
![]() ![]() ![]() Join Date: May 2019
![]() A turkey baster sounds really easy, and I've got one for garage use. I've actually got the wheel well liner out, so I'm sure it won't be too hard to do. That reminds me, I need to get that liner back in before winter. I broke the screws removing it, so I need to get hardware.
I would like to clean that screen too. ... 2000 SL2 Automatic (back on the road) 17X,XXX miles. 1999 Chevy K3500
#6270 | |||||
https://www.amazon.com/stores/node/8...web_8379091011 You can get 100 8mm clips for a little over $8.00, plus they throw in a tool to remove the clips. I also used 5/16" Neoprene washers (under the liner next to the fender) with the clips so the liners were more secure. ... Saturn 1998 - SL2 Singer 1952 - 301A
#6271 | |||||
#6272 | ||||
![]() Added 4 ounces of MMO in a full tank of non-ethanol gas 😊
#6273 | ||||
![]() Nahn Ethan All? What is that? I've never heard of it. What's it do?
#6274 | |||||
Excellent upper cylinder lube, protects the valves, and cylinders. Sludge control & helps with compression. Been used almost forever. Start here: http://www.marvelmysteryoil.com/prod...l-mystery-oil/ ... Proud Owner of an Invincible '98 SC2 Rare "Red Hot" 5-Speed. Castrol Edge EP + M1 Ext Perf. Oil Filter. Owned 4 other S-Series.
#6275 | ||||
![]() Leather creme on the seats, moldings & rubber door/trunk seals.
#6276 | ||||
![]() For the SW2, I changed the engine oil, the coolant and the brake fluid....aaannd, put it back into storage.
... Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it). Oil use is 1 ounce per 100 miles with ~230,000 miles on the engine
#6277 | ||||
![]() I plugged my space heater in, and set the timer to go off at 3 am.
#6278 | ||||
![]() Join Date: Sep 2019
![]() I have covered some scratches
#6279 | ||||
2000 SW2
![]() The $400, 78k mile, 00 SL2 went to LKQ scrap for $125.
Really hated to see it go when the interior and exterior were an 8 out of 10, the only issues I know of were a bad ignition cylinder and a leaky rack and pinion. But hey, it was sacrificed to save a 00 SW2 and the shocks to the 97 SL2 that has 295k miles. Good parts I used: Motor, shocks, rear doors, main cat, driver-side mirror, BCM/ECU, throttle cable, all fuses/relays, arm rest, cluster, near new tires, a tie rod, a 1yo battery, and I am sure a few more things. So my cost of all those excellent parts was now adjusted to $275!! I put most of the old/bad parts back on, including a 97 DOHC motor in the trunk. ... Ryan 97 SL2 Mack Charcoal 5 speed, 238k miles, bought 11/18/15 98 SL2 Pearl White auto, 190k miles, 11/7/15 RIP S-series Shop Manual: http://www.saturnfans.com/forums/showthread.php?t=177672
#6280 | ||||
![]() Now, that is some true American ingenuity!
![]() ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
Anyone see the "Judge Judy" episode with the 96 S series today? | dave.sl | S-Series General | 23 | 02-20-2014 04:56 AM |
The S Series would be a great car for the lineup today | VTHokie00SL2 | S-Series General | 46 | 10-01-2012 08:26 AM |
Got the L series recall letter today for rear lights | Garciavision | L-Series General | 27 | 12-22-2005 02:29 PM |
REDLINE Series Announced Today | D C | Vue Red Line | 6 | 04-10-2003 08:14 PM |
Saw the L series DVD system today | Jeff P | L-Series General | 1 | 11-09-2001 09:03 PM |
