Old 10-21-2019, 10:11 PM   #6261
Zeebins
Zeebins's Avatar
Originally Posted by 454cid View Post
I need to do my oil.... it's over due, and I may need to figure out how to drain my washer fluid. I filled mine up earlier this year with the summer blend that isn't rated for low temperatures.
Last time I had to drain mine I just removed the one bolt holding it on and dumped it into a bucket. I know 3rd gen has a different bottle shape though and I'm not sure if it's mounted differently. Should be similar though as long as the air pump doesn't get in the way.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 10-21-2019, 10:34 PM   #6262
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: What did you do to your S-Series today...
Buy a bottle of 70% or 91% rubbing alcohol and put in the whole bottle. It will not freeze and then add winter mix.
1995 SL1 236,300 2005>2018
1997 SL1 79,081 2014>????
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-21-2019, 11:06 PM   #6263
Haybale
Haybale is a jewel in the roughHaybale is a jewel in the roughHaybale is a jewel in the rough
Haybale's Avatar
2000 SW2
Swapped the rear doors with inoperable rear windows (and glued shut and still fell, looked nasty) with working and great shape rear manual crank doors!! I left the tan panels on the inside even with the rest of the interior is gray!!
Then had the near new tires swapped from the parts cars steel rims to the wagons aluminum rims!!
Then got an alignment on the wagon!!
Ryan
97 SL2 Mack Charcoal 5 speed, 238k miles, bought 11/18/15
98 SL2 Pearl White auto, 190k miles, 11/7/15 RIP
S-series Shop Manual: http://www.saturnfans.com/forums/showthread.php?t=177672
Add to Haybale's Reputation
Rate the quality of this post and help Haybale reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Haybale is offline   Reply With Quote
Old 10-21-2019, 11:09 PM   #6264
Haybale
Haybale's Avatar
2000 SW2
Just pop the pump off and clean the little rubber screen while it is off!!!
Or grab the condensed rainX brand that you add to a gallon of regular stuff. Because that is all they sell out here, no regular winter stuff (San Diego)...
Ryan
Old 10-22-2019, 07:37 AM   #6265
Pitcher
Pitcher's Avatar
^ Turkey Baster or long shampoo bottle hose & nozzle.
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pitcher is online now   Reply With Quote
Old 10-22-2019, 09:01 AM   #6266
trottida
trottida's Avatar
It would probably be easiest just to use a siphon. A piece of rubber hose would do the trick, fill it with water or washer fluid, keep your thumb on one end and drop the other end to the bottom of the tank and lower the free end to a point below the tank and release your thumb and drain back into a container.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-22-2019, 09:55 AM   #6267
Waiex191
Waiex191's Avatar
I siphoned out my washer reservoir in my $200 Buick Century when I had to replace the pump. Worked great.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-22-2019, 10:56 AM   #6268
Couldn't remember if there was a 10mm-head bolt at the bottom or not, so found this:
http://www.saturnfans.com/forums/sho...d.php?t=145117
Kaervak's post indicates there is a bottom bolt close to the side light, which sounds about right. The washer tank is very long.
Though, if you get down there, I suspect you could just pull the hose or pump out to drain it. Again, it's been several years and I don't recall the setup down there.
Been several years since I pulled a 3rd gen washer tank; probably 6 years ago. I think I was planning of trying to fit it into my 2nd gen SL2 to increase capacity
Old 10-22-2019, 07:25 PM   #6269
454cid
A turkey baster sounds really easy, and I've got one for garage use. I've actually got the wheel well liner out, so I'm sure it won't be too hard to do. That reminds me, I need to get that liner back in before winter. I broke the screws removing it, so I need to get hardware.
I would like to clean that screen too.
1999 Chevy K3500
Add to 454cid's Reputation
Old 10-22-2019, 08:56 PM   #6270
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
... That reminds me, I need to get that liner back in before winter. I broke the screws removing it, so I need to get hardware...
I recently replaced my wheel well liners and found a really good deal on the clips at Amazon through a company called GOOACC.
https://www.amazon.com/stores/node/8...web_8379091011
You can get 100 8mm clips for a little over $8.00, plus they throw in a tool to remove the clips.
I also used 5/16" Neoprene washers (under the liner next to the fender) with the clips so the liners were more secure.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-23-2019, 02:18 PM   #6271
454cid
Are you talking about the plastic pins? I may have enough of those. I need to clean them up and take a count. I actually snapped screws. There are three screws and u-clip on the front most edge of the fender. I think I broke them all.... solid rust. I think I can get the clips and screws locally. Those pins would be harder to find, Though.... I need some for my truck too. Thank you for the link.
1999 Chevy K3500
Old 10-23-2019, 05:40 PM   #6272
Pitcher
Pitcher's Avatar
Added 4 ounces of MMO in a full tank of non-ethanol gas 😊
Old 10-23-2019, 06:50 PM   #6273
454cid
Nahn Ethan All? What is that? I've never heard of it. What's it do?
1999 Chevy K3500
Old 10-23-2019, 09:04 PM   #6274
Pitcher
Pitcher's Avatar
MMO = Marvel Mystery Oil
Excellent upper cylinder lube, protects the valves, and cylinders.
Sludge control & helps with compression. Been used almost forever.
Start here: http://www.marvelmysteryoil.com/prod...l-mystery-oil/
Old 10-24-2019, 12:02 PM   #6275
Pitcher
Pitcher's Avatar
Leather creme on the seats, moldings & rubber door/trunk seals.
Old 10-24-2019, 07:41 PM   #6276
bumpdraft
bumpdraft's Avatar
1998 SW2
For the SW2, I changed the engine oil, the coolant and the brake fluid....aaannd, put it back into storage.
Add to bumpdraft's Reputation
Old 10-24-2019, 08:16 PM   #6277
Waiex191
Waiex191's Avatar
I plugged my space heater in, and set the timer to go off at 3 am.
Bryan Cotton
Old 10-24-2019, 08:54 PM   #6278
Hiisi
Hiisi is on a distinguished road
Hiisi's Avatar
I have covered some scratches
Add to Hiisi's Reputation
Rate the quality of this post and help Hiisi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiisi is offline   Reply With Quote
Old 10-24-2019, 10:25 PM   #6279
Haybale
Haybale's Avatar
2000 SW2
The $400, 78k mile, 00 SL2 went to LKQ scrap for $125.
Really hated to see it go when the interior and exterior were an 8 out of 10, the only issues I know of were a bad ignition cylinder and a leaky rack and pinion. But hey, it was sacrificed to save a 00 SW2 and the shocks to the 97 SL2 that has 295k miles.
Good parts I used:
Motor, shocks, rear doors, main cat, driver-side mirror, BCM/ECU, throttle cable, all fuses/relays, arm rest, cluster, near new tires, a tie rod, a 1yo battery, and I am sure a few more things.
So my cost of all those excellent parts was now adjusted to $275!!
I put most of the old/bad parts back on, including a 97 DOHC motor in the trunk.
File Type: jpg 73249415_10157129289814215_4066959117321764864_o.jpg (156.7 KB, 13 views)
Ryan
Old 10-25-2019, 11:51 AM   #6280
Now, that is some true American ingenuity!
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
