#21 | ||||
![]() ![]() ![]() Join Date: Oct 2019
![]() The first fuel filter was not a GM part. That was put in in 2012 and caused problems by 2014. We bought a GM fuel filter with internal regulator from GM Parts online and that solved the choking problem in 2014. This GM fuel filter from 2014 has 20K miles on it.
#22 | |||||
![]() Quote:
Yes, keeping the pedal all the way to the floor when trying to start. No pumping.
#23 | ||||
![]() Alright, here's my best attempt at an update. I'm exhausted. Been fussing with the D@#%(U&*#$ car all day.
My cousin was able to spend the day with me working on it. Long story, short; it still doesn't start. Went to 3 O'Reilly's this morning and purchased: STD PC48 Crnkshft Sen MPI 2-9386 Cool Temp Sw CTI 85137 harness MCS 8099 oil cap MIM 25324 sealing tape CHV 37378 Techron Himi DOR 645-900 pigtail Installed all of these things. Cousin and Dad are thinking the two coil packs should be changed and/or the catalytic converter as I believe it is original. I think they said only one of the new spark plugs was getting a spark. Another spark plug is black already. Trying to start it now sounds different. Cousin says it sounds like someone stuffed a potato in the tail pipe (checked, no potato). So it seems like it's closer to starting. Plan to tow it first thing tomorrow. I just don't have time to deal with all of this anymore and need a working car ASAP almost regardless of the price/cost. If you have any suggestions for my mechanic, I'll gladly pass them along. I'm sorry, I know one of you was asking for fuel pressure readings, I just don't know what they were. ![]()
#24 | ||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2013
![]() Still no compression readings? You are wandering in the weeds, strewing money in your path.
#25 | ||||
![]() There were readings I just don't know what they were. Doing the best I can with all of this. I know it's not how you would do it. Some things can't be helped.
#26 | ||||
![]() Join Date: Aug 2019
2000 SC1
![]() Have you confirmed that the fuel pump is working?
One way to check is have someone get underneath the rear of the car while the key is turned off. While they are listening, turn the key to the run position. The fuel pump should run for about three or four seconds and then shut off. If you can't hear it come on, it's dead. Care to have a few drinks with me later? ... All GM, all the time.
#27 | ||||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2010
![]() Is it possible that the cat is really clogged?
If you removed the front oxygen sensor (near the radiator fan motor area) and then tried starting, if then there is no back pressure to build up, it may start. If so, and the cat is cooked, you can always bang hard on the cat and that might collapse some of the interior honeycombed baffles and may let your exhaust pass through. Also, with the O2 sensor out, get a leaf blower running and place it into the tailpipe, it should sent air out that O2 sensor fitting.
#28 | ||||
2000 SC1
![]() Pump could have been weak and finally died.
#29 | |||||
![]() Quote:
#30 | ||||
![]() I needed my friend to help me decipher what you meant by "cat". Catalytic Converter, no?
It's been way too long of a day ![]()
#31 | |||||
2000 SC1
![]() Quote:
Next thing I'd check is the ignition control module, which is the thing that the coil packs are attached to. Since it's an $80 to $100 part, I'd recommend getting one from a junk yard if you live near one. https://www.youtube.com/watch?v=8XgHM1i5jK8 How about dinner? You like Thai? ... All GM, all the time.
#32 | |||||
![]() Quote:
#33 | ||||
![]() So, just talked to my mechanic at the shop. The battery was low from us doing stuff with it all day yesterday so he plugged it into a charger. Then he started it. Started just fine for him. AGAIN!!!! It was running in the parking lot when he called to tell me the car got dropped off from the tow just fine.
Anyone interested in a lovely, 1998 Saturn SL2 (silver plum, no rust, no cracks in plastic, 140K miles) that's been well taken care of for it's whole life and just refuses to start for its owner any longer???????? So, 2 "unnecessary" tows have cost me $260 so far in these last 2 weeks of trying to deal with the F-in car. Not counting the labor and parts and labor and parts and parts and time and . . . . . which I'd be fine with, if IT WOULD JUST START FOR ME TOO!!!!!!!!!!!!!!!!!!! Un - f-in - believable.
#34 | ||||
![]() Your's is probably not what my old 1991 Dodge Dakota had wrong with it, but the no-start-until-after-the-tow-truck-arrived was the same issue with my truck.
Replaced lots of stuff, both me and a reputable repair shop. But to no avail. I finally replace the computer and it never failed to start after that. Actually, it took 3 computer replacements to get it solved. Initial one from autozone had my alternator spiked to like 18v (not good for electronics). # 2 was the same one I turned in to autozone for the 1st replacement (looks like their "repair" shop did not find my computers exact issue so they returned it back to my same store to put on shelf for sale). #3, I convinced the store manager to get one in from Richmond Va warehouse some 3 hours away from my store, and this one worked fine for like 10 years. Last edited by toggenburg; 10-18-2019 at 01:16 PM..
#35 | ||||||
![]() That's weird. I don't see anything that would cause it to fail but did notice something about it starting again:
Most parts stores will do a free battery / alternator check. Doubt that is the issue, though. Couldn't hurt to check the battery / cable connections; sometimes being just a bit loose can cause a little weirdness but usually it is in the form of the instrument panel flickering / cutting off for a second. ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 141k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles
#36 | ||||
![]() I went through a PCM failure episode, the symptoms were very flaky but the initial and most obvious symptom was an intermittent "crank but no start". Sound familiar?
Check the 5V power at the MAP or TP sensors, or at the EGR valve; whichever is easiest for you. The 5V should come up instantly at key-on. If it is lazy, taking several seconds, or doesn't even come up to a good "5V" (4.80 to 5.20), then the PCM is suspect. Do this check many times, see if the results are consistent.
#37 | |||||
![]() Quote:
#38 | ||||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
![]() I did have a no start condition that was related to a bad cell in the battery. However, the symptoms were no crank. It sound's like you are getting crank.
I also had one experience where the car died on the street and wouldn't start. I had it towed to my mechanic and it started up right away off the tow truck. I drove that car for years after that happened and never experienced the problem again. ... 1999 SL2 MT (287,130 km @ 10/2019) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada:
#39 | |||||
![]() Quote:
The battery is new from Fleet Farm from January of this year. A 72-month one I believe because that's what I usually buy. I've always had good luck with batteries from there. I don't think it's the battery. Dad's been charging it at home after working on it, though I'm pretty sure that didn't happen last night -- everyone was just way too exhausted after the long day. Sounds like my shop is going to put in the 2 new coils and the xxx? computer thing that connects to that today. Then let it sit over the weekend in the rain and stuff (it has been wet and some very humid weather here) and see if it still starts for them on Monday. I guess I take it at that point and cross my fingers and hope that the 3 new parts fix it and I'll be able to start the car myself like I've been doing for 21+ years. God this makes me feel like an idiot.
#40 | ||||
![]() PCM = Power Control Module = car's computer. In your year, is a small silver box kind of behind the instrument panel. If you take off the top of the dash, you can see it
MAP or TP sensors, or at the EGR valve - these are all under the hood. Locations are shown here http://www.saturnfans.com/forums/sho...7&postcount=12 ... I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 141k DD 7/2010 Craigslist white 1997 SC2 project 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles Last edited by alordofchaos; 10-18-2019 at 02:57 PM..
2006 Ion will not start when parked in the sun | D.Hornung | Ion Tech | 10 | 08-14-2010 09:07 AM |
1998 saturn won't start | smote | S-Series Tech | 25 | 02-11-2010 06:01 PM |
Won't start when parked on a grade | Clickety_Clack | S-Series Tech | 1 | 10-23-2008 09:38 PM |
VTI vibration when parked on incline | sattech | Vue General | 13 | 05-05-2003 02:27 PM |
