#1 | ||||
![]() Join Date: Aug 2010
![]() Driver side window doesn't work, the other three work. I took the console apart. Is it the switch or the motor in the door?? The light on the switch is still on so it still has power. Any suggestions?? John
#2 | ||||
![]() ...Get a test light and pull off the connector at the motor, hit the switch and see if it lights up , if it does , the motor is bad . No light, the switch is bad, that's a start, hope that helps, DC
#3 | ||||
![]() ok in side door panel off ! How do I get to switch ? Or should I take off out side door panel off ?
#4 | ||||
![]() The two wire circuits the go to the window motor are both by default connected to ground from the window switch, when the switch is pulled up the dark blue wire will be switch to positive power, when the switch is pushed down the brown wire will be switch to positive power. When the switch in operated the other wire will (should) continue to be grounded from the switch.
To test for ground connect the test light wire end to the positive terminal of the battery. test for power and ground with the wire connector disconnected from the window motor.
