Old 10-10-2018, 11:46 PM   #5641
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SL2
Originally Posted by A2Saturn View Post
Had Big O Tires change out front and rear Monroe Quik-struts.
They were about 5 years old and 100k miles on them. Replaced under the Tenneco lifetime warranty. The newer ones are much quieter than the last set.
Getting ready for the trip I see.
Are the monroe ones any good? I need some soon for my old girl.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-11-2018, 08:22 PM   #5642
silentdude56k
silentdude56k is on a distinguished road
1994 SW2
I replaced my ~310k mile ( ) front and rears with the Monroe Quick-Struts in late June. They seem good to me - the ride is solid, the car sits a couple of inches higher off the ground, and I don't feel like I'm going to roll when I take a turn a little too fast.
Purple 1994 SW2 auto. 317k+ miles. Head gasket replaced due to an overheat at ~261k. Timing chain replaced for good measure. Passes California smog testing.
Add to silentdude56k's Reputation
Rate the quality of this post and help silentdude56k reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silentdude56k is offline   Reply With Quote
Old 10-11-2018, 10:18 PM   #5643
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
I'm pleased with the Quik-Struts. I took a 250 mile drive today, and noticed a better ride and handling. When crossing the expansion seams on the roads and bridges, I hardly even noticed. Other people on the forum have commented they like using KYB struts and Moog springs.
Add to A2Saturn's Reputation
Rate the quality of this post and help A2Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
A2Saturn is offline   Reply With Quote
Old 10-12-2018, 12:16 AM   #5644
Sid
Sid will become famous soon enough
Sid's Avatar
1996 SW2
Put in new front brake pads and rotors today. $65
96 SW2 5MT
Add to Sid's Reputation
Rate the quality of this post and help Sid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sid is offline   Reply With Quote
Old 10-12-2018, 05:10 AM   #5645
1996SW2
1996SW2 is on a distinguished road
1996SW2's Avatar
1996 SW2
2000 SW2
Pulled passenger seat from kids car (2000 SCW) to compare to the Stanky Ho's (2000 GOLDEN NUGGET SW2. seat slider. The boy will be 16 in Feb.
The Stanky Ho has gotten a top to bottom, inside and out 4-Day clean. Great car for $500. Just need to get tags, plate, brakes and she should be ready to roll to her forever home. Might be ours, might not.
I should have the interior 100% back in by this evening. I
Add to 1996SW2's Reputation
Rate the quality of this post and help 1996SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1996SW2 is offline   Reply With Quote
Old 10-16-2018, 07:16 AM   #5646
Waiex191
Waiex191's Avatar
I scraped my windows. Doesn't sound newsworthy, but after driving a Dodge Ram last winter I really appreciate the low height and size of the Saturn after a frost. It is easier to park too!
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-16-2018, 09:42 PM   #5647
nealt
nealt is on a distinguished road
nealt's Avatar
1997 SC2
1999 SC2
Finally replaced my flex pipe... welded it in. The wire mesh became loose after about 15 years... took about 5 more years for the flex pipe to fail and start making noise.
The OEM flex pipe was a much heavier gauge than the $20 flex pipe that I replaced it with.
Add to nealt's Reputation
Rate the quality of this post and help nealt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nealt is offline   Reply With Quote
Old 10-22-2018, 08:12 AM   #5648
bumpdraft
bumpdraft's Avatar
1998 SW2
Ground a rear tire round
https://imgur.com/a/IQwLGGc
Add to bumpdraft's Reputation
Old 10-22-2018, 01:20 PM   #5649
SLfun
SLfun will become famous soon enough
2006 ION Red Line
Changed the leaking valve cover for a metal one.
Changed the oil and filter.
Did some rust proofing.
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is online now   Reply With Quote
Old 10-27-2018, 11:19 AM   #5650
Waiex191
Waiex191's Avatar
Had my younger son bring us to driver's ed in the '98. He is getting the hang of shifting. I find that to be extremely gratifying.
Bryan Cotton
Old 10-27-2018, 05:09 PM   #5651
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
New member of the forum here! Got my 99 SL2 last week and am diving into the nitty gritty. Got the headliner foam for my car and cleaned the extremely dirty windshields. Also got new wipers and put in some Techron.
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
Add to jpags729's Reputation
Rate the quality of this post and help jpags729 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpags729 is offline   Reply With Quote
Old 10-28-2018, 11:15 PM   #5652
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
I repaired my abs and brake light . I just bought a replacement abs unit from junkyard found the best looking car in yard . Put in mine bleed the abs two modulator bleeder screws then the RR RL LR LL . DID THIS WITH my homemade pressure bleeder . Took care of a 700 dollar repair with a 20 dollar abs unit from donor car . BLEED IT A FEW TIMES CAUSE i dont care about 40 dollar fluid. Need my inspection done in 2 or 3months . I love my car. Also did synthentic oil change getting it ready for winter. Checked my a battery terminals fixed a negative terminal issue Where the bolt was loose and not solid connect and would cause my battery to cut out. So I went to oreily picked up a new bolt for $2.99 repair.
Also did a full brake job rears and fronts all new hardware drums and pads and hardware replaced .Bleed entire system with over a half gallon of fluid . Will do this yearly now on. So I never have another abs light again.Abs feels wonderful now.
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 10-29-2018, 07:47 AM   #5653
trottida
trottida's Avatar
Installed seat heaters in the front seats of the 99 SL2 yesterday. Added a fused circuit from the UHJB positive post and through the firewall using the existing grommet. I tapped into the switched brown F12 wire to control the circuit using a relay so they turn off with the key. Used the body ground point to the left of the radio for all the ground wires. I had to put the switches on the sides of the console this time as the Gen2 console doesn't have enough space near the shift boot. They are just forward of the shift tower and down about 1 1/2". Pulled the seat covers off the seats to install the heating pads; the 99 has a much easier configuration than the 01 SL1 seats in my other car. Looking forward to a toasty butt this winter!
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-29-2018, 10:20 PM   #5654
Waiex191
Waiex191's Avatar
I checked the oil in the '98 tonight. There was plenty:
The other oil reservoir was a couple diamonds from the bottom. One of these days I'll have to put the aluminum valve cover on.
Bryan Cotton
Old 10-30-2018, 01:26 PM   #5655
Zeebins
Zeebins's Avatar
Changed the teams fluid today. I thought it was still the original fluid in there but there wasn't a magnet on the filter. My dad said he's never changed it in the time he's owned the car so the original owner must have done it at some point, or Saturn did before my dad bought it. Either way, that's still 55K-80k on the same fluid.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 10-30-2018, 01:57 PM   #5656
Zeebins
Zeebins's Avatar
Teams fluid lol, trans fluid*
Powered by Plastic
Old 11-01-2018, 04:25 PM   #5657
bumpdraft
bumpdraft's Avatar
1998 SW2
Drove my new Michigan Defenders on the expressway for 100 miles.
They ain’t round enough for fancy expressway drivin’.
Un-drivable from 55mph to 65 mph. When traffic slowed to 60mph, I was never quite sure whether to accelerate or pull off the road.
https://imgur.com/a/eqzgtaa
More *@!^ tires await my bench sander
It would be great if tire manufactures sold tire “rounding” kits to consumers. They would be able to come up with something better than a bench sander with 40-grit
Old 11-02-2018, 11:02 AM   #5658
bumpdraft
bumpdraft's Avatar
1998 SW2
While grinding the tire round, I noticed the wheel was not set-up properly when it was “remanufactured” and re-painted.
https://imgur.com/a/5nY9d2y
To compound the problem, I requested stick-on wheel weights.
The combination of tire, wheel and wheel weights made the assembly un-drivable. With clip-on weights, it will probably be fine.
https://www.alltiresupply.com/produc...-series-coated
Old 11-03-2018, 12:05 AM   #5659
Zeebins
Zeebins's Avatar
Finally got a CD changer installed in my trunk today! When I first tried using it, it wouldn't read any CDs so I tried cleaning it with some compressed air and that seemed to help a little. It'll read discs now but seems to be really hit or miss with no rhyme or reason on the disc. Old, new, and burnt CD-Rs all work, but all also take their turn not working and giving an error. It might have to be taken apart and cleaned more but maybe it'll work itself out after some use. It hasn't been used in years. Really doesn't take up as much space as I though it would either. It fits nicely above my tools and things I keep in the back.
Now my Saturn can play radio, cassettes, CDs, hand have Bluetooth/aux with an adapter. I think that'll cover all the bases in terms of useful media formats lol
Also, huge thanks colonelhoghen44 for selling me his old one. Finding a changer on eBay was easy but since every car that had the changer mounted it a little differently, I probably never would have found the Saturn bracket for mounting it in the trunk.
Powered by Plastic
Old 11-03-2018, 12:40 PM   #5660
bumpdraft
bumpdraft's Avatar
1998 SW2
Ground the other (Pass Side) Michigan Defender to a “round” state.
And, bought some sharp 24-grit tire-grind belts so it doesn’t take 8-hours, like the driver’s side tire took
And some coated wheel weights for the Saturn O.E. alloy wheel because I can not expect a tire center to have an exact match to every rim profile at hand.
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
