Old 12-05-2013, 06:43 PM   #1
tgparker2013
tgparker2013 is on a distinguished road
1997 SW1
1992 SL2
Default Saturn SW1 won't start
Somehow I think that I shorted the security system. I was trying to reprogram the RKE and I accidentally brushed the paperclip against one of the other pinson the OBDII port and shorted something. The RKE transmitter, and power locks don't work and the car won't start. Everything else with the car seems to be working. lights, radio, etc...
I remember there was a way to jumper the ins in the OBD2 port and the Check Engine Light would flash the code. Which pins should I jumper? Is there any way to test and see what's damaged via the OBD2 port??
I'm hoping that whatever I shorted was fused. I don't have a Saturn '97 SW1 fuse diagram & can't seem to locate which fuse protects the RKE or car security system or rke. I have removed the back seat and side panels and I can access the the RKE Car Security System unit. Is there a fuse there that protects the RKE. Any ideas?
Add to tgparker2013's Reputation
Rate the quality of this post and help tgparker2013 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tgparker2013 is offline   Reply With Quote
Old 12-05-2013, 06:49 PM   #2
Default Re: Saturn SW1 won't start
OBD-2 does not work by shorting pins.
You have popped a fuse. Check fuses in both fuse boxes. Check BODY fuse in inside fuse box and if the chime is not working then check the CHIME fuse.
Old 12-05-2013, 10:33 PM   #3
tgparker2013
1997 SW1
1992 SL2
Gee I really hope so that it was just the BODY fuse that I popped. I did check the inside fuses but they all looked ok. I'll check the inside fuses again and the outside fuses in the am. All I noticed was that the top dome light, the powerlocks, and the RKE, didn't work and the car wouldn't start. All other lights, and dashboard lights, fuel pump, and chime worked. Thanks for the suport!
Old 12-05-2013, 10:39 PM   #4
What year is this car? Never mind, found it.
Just replace the BODY fuse. When the dome lamp works you have fixed the problem.
Old 12-06-2013, 01:16 PM   #5
tgparker2013
1997 SW1
1992 SL2
Done! 10amp fuse replaced and everything works fine!
Thanks
Old 12-06-2013, 03:00 PM   #6
As I suspected,
My Saturn won't start! Orville1 S-Series Tech 5 01-30-2016 10:05 PM
96 Saturn SL1 No Start Kitt92 S-Series Tech 7 01-27-2012 08:27 PM
03 Saturn doesn't start periodically, but eventually does start Caveman1953 L-Series Tech 5 11-25-2011 10:15 PM
1995 Saturn SL2 Start Porblems- I NEED A SATURN EXPERT! JamesDator S-Series Tech 33 10-30-2007 05:11 PM
'93 Saturn LS2 will not start Lugnut7 L-Series Tech 0 10-24-2001 05:11 PM
