Old 12-25-2009, 09:06 PM   #1
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
1994 SL2
Default Radio
I just got a factory tape player w/ equilizer and it works
but when uninstallling my Alpine unit that came in the car I saw that the conector only had 3 prongs instead of 4 is this a problem (the one that's missing is circled)
also how do you take off the cubbard thing off of the alpine unit?
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Add to Saturninin's Reputation
Rate the quality of this post and help Saturninin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturninin is offline   Reply With Quote
Old 12-25-2009, 09:30 PM   #2
Saturninin
Saturninin's Avatar
1994 SL2
Default Re: Radio
okay got the alpine out of the cassing for S-series
just need 2 know about the 3 prong if that is a problem
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
95 SC2 ~128
Past
96 SW2, 98 SL2
Old 12-25-2009, 11:55 PM   #3
Spaz
Spaz will become famous soon enoughSpaz will become famous soon enough
Spaz's Avatar
Default Re: Radio
The OEM connector has only 3 "prongs" as you call it. Here's a photo of it.
Add to Spaz's Reputation
Rate the quality of this post and help Spaz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spaz is offline   Reply With Quote
Old 12-26-2009, 12:12 AM   #4
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
Default Re: Radio
It's been a while but if I remember correctly, that fourth connector is for remote radio control (like steering wheel mounted controls)? Of course, the S's don't have that option so there is no connection on the OEM harness for it.
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh!
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
off-track is offline   Reply With Quote
Old 12-26-2009, 12:21 AM   #5
Saturninin
Saturninin's Avatar
1994 SL2
Default Re: Radio
okay thanks both of you, I was just woundering becasue the car that I pulled it out of the conector had the four prong so I was just woundering if the dumb@s that had my car before me screwed up the radio with everything else that she screwed up, but okay thanks so much
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
95 SC2 ~128
Past
96 SW2, 98 SL2
Old 12-26-2009, 06:33 PM   #6
Tofutti
Tofutti is on a distinguished road
2002 SL
1994 SW2
Default Re: Radio
Interestingly enough, GM used this same set of connectors in the full size pickups at least back in '88 to maybe '94?/95? (whenever they changed the interior designs). At that time, the actual stereo was basically directly above your right shin as you sat in the driver's seat, under the dash, (over the gas petal). If that particular connector is in-fact used for a remote controller, that makes sense as the "stereo" that sits in the dash above the heater controls in those trucks was just a control panel. I believe you are perfectly right and most aftermarket harness adapters I've seen come through with that set of connectors detachable from the rest in case they're not used/needed.
Add to Tofutti's Reputation
Rate the quality of this post and help Tofutti reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tofutti is offline   Reply With Quote
Old 12-26-2009, 07:55 PM   #7
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Default Re: Radio
I believe that on the saturn s-series cars, the 4th prong is there for the optional CD changer. The AUX button on the EQ radio is for CD changer.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 12-26-2009, 09:53 PM   #8
Saturninin
Saturninin's Avatar
1994 SL2
Default Re: Radio
ah so i should of cheaked for the changer in the 1 in the JY, oh well i can go back sometime lol
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
95 SC2 ~128
Past
96 SW2, 98 SL2
Old 12-27-2009, 10:55 AM   #9
andy_95sl2
andy_95sl2's Avatar
Default Re: Radio
The s-series cars are not pre-wired for all options. If you get the CD changer, you'll have to remove the interior wire harness out of the car (takes about 3 hours to do properly) and replace yours with it, or you'd have to make your own hook-up.
Old 12-27-2009, 11:29 AM   #10
Sky King
Sky King is on a distinguished road
Sky King's Avatar
1999 SC2
Default Re: Radio
Quite correct. In 1995, the year the interior was upgraded to the second generation interior, an optional trunk mounted CD changer was offered. The extra connector was for that. The 1995 SL-2 we still have, we ordered and bought new. I specifically asked to have the CD harness included but did NOT want their changer as they were VERY proud of it. I later purchased an aftermarket trunk mounted changer.
Not quite right. In my 99 SC-2, while it had the radio with the EQ, (which does control the CD changer) it did not have the trunk changer OR the harness. That harness WAS, (at least at one time), available from Saturn through the parts department. I did order the harness and installed it. It was not difficult. The additional harness was separate and only had to be routed from the console to the trunk. Since it was separate, it did NOT replace the existing harness, just in addition to it. Had the harness been specified when the car was ordered, it WOULD have been incorporated in the existing radio harness. But again, the changer harness CAN be added without having to remove the existing harness. That is of course depending on whether or not you can still get it.
1999 SC-2 280,000 miles -mine now also dead, RIP
1995 SL-2 296,000 miles - my wifes totaled, RIP
1993 Chevrolet S-10 Pick-up - mine
2003 Harley Davidson Low Rider - mine
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sky King is offline   Reply With Quote
Can I replace my 01 SL1 CD/Radio with a newer GM Stock radio? SuperCujo S-Series General 46 01-27-2009 10:13 PM
96 SL SOHC radio wire to light on clock/radio turner dddaaa S-Series Tech 1 06-21-2008 04:53 PM
MP3 Factory Radio into a standard radio Vue baisley Vue General 9 01-04-2008 11:36 AM
Sirius radio FM interface with car radio firefox23508 Vue General 0 04-11-2007 01:48 PM
Need factory radio harness/plug for SAAS CD/Cass/FM/AM radio JButler1983 L-Series General 2 12-03-2006 05:48 PM
