Old 10-14-2009, 02:34 AM   #1
Tofutti
Tofutti is on a distinguished road
2002 SL
1994 SW2
Question Wiper motor erratic behavior
So here's one; '99 SC1 with wiper delay. The wipers will function as intended when the car and/or outside temp is relatively warm. However, in colder temperatures and when the vehicle is cold the wipers will always turn on when I tell them to but will shut off when and where (in the windshield) they feel like it. When I hit mist, they should only wipe once or twice, but they'll go for a couple minutes then stop in the middle of the windshield, etc. I remember having an '88 Silverado that did the same thing and I remember pulling the wiper motor apart and finding that there was a disk with metal fingers that contacted it in various places and by cleaning the contact points and by bending the fingers down a 'lil more, I got it to work properly for a while. Eventually I just tapped in to the motor itself and put it on a toggle switch.... I haven't even looked at this system closely yet to see if it's similar. I'm guessing being GM, it probably is. Anyway, just wondering if there's any quick fixes that you folks can think of before I go tearing into this and rewiring it.
Add to Tofutti's Reputation
Rate the quality of this post and help Tofutti reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tofutti is offline   Reply With Quote
Old 10-14-2009, 08:08 AM   #2
stevestar99
stevestar99 will become famous soon enoughstevestar99 will become famous soon enough
Default Re: Wiper motor erratic behavior
Nope. Get tearing
Add to stevestar99's Reputation
Rate the quality of this post and help stevestar99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stevestar99 is offline   Reply With Quote
Old 10-14-2009, 03:12 PM   #3
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
Could be your wiper switch too.. I've seen those go bad. Same symptoms..
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLCraig is offline   Reply With Quote
Old 10-14-2009, 04:07 PM   #4
dcp
dcp is on a distinguished road
dcp's Avatar
I would first take a look at richpin06a u-tube videos.He has a very good information on lubeing the wiper arms.Good luck
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline   Reply With Quote
Old 12-25-2009, 06:33 PM   #5
Tofutti
2002 SL
1994 SW2
Old post update: Lubed wiper arms, no difference. I never heard the wiper motor struggling anyway, but was far easier than tearing into the motor assembly and is never a bad thing to do for any vehicle anyway. If/when it warms up a little bit here, I'll just wire in a toggle switch directly. Been there, done that. Oh well.
Happy holidays to all!
Old 12-31-2009, 07:00 PM   #6
TomM96
My '97SW2 shield wiper just transitioned to 'bonkers' last week:
First hint- When driver attempts to employ the 'wipe, low speed' function to clean up after a wash job ... the wash becomes constant , and maintains ops when control lever is shifted to 'wipe, high' location.
Second hint- When driver attempts to motor along innocently in clear weather , the wiper unilaterally initiates ops ... intermittently .
A recall/free wiper circuit board was issued for '94+'95 {and some other years} of GM pickups/suburbans. The backyard mechanic fix - which worked for me - was to inspect the wiper control circuit-board where the harness connector terminals are; cracks around the terminal base(s) only need to be resoldered to restore normal ops.
I drove a '94 at work , which resourcefully had figured how to only function when the ambient conditions were 'dry'; my '95 was acquired used with an intermittent condition.
Add to TomM96's Reputation
Old 01-21-2010, 12:43 AM   #7
Qcboy
Qcboy is on a distinguished road
I fix the same problem on my 96 SL1 maybe every 2 years since i have the car. I read a lot of post that explain how to change the motor to correct the problem but in fact, for my car, the correction is only to clean the connector of the motor wiper with a good contact cleaner. I lub the joins of the linkage kit too to prevent a jam of it cause it's a hard job to put it out and change it...
Hope this will help
Add to Qcboy's Reputation
Rate the quality of this post and help Qcboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Qcboy is offline   Reply With Quote
wiper motor gregory_t S-Series Tech 3 01-08-2008 11:22 AM
Wiper motor Geronimo S-Series Tech 4 10-06-2007 09:08 PM
96 SL Wiper Motor 96saturnslowner S-Series Tech 1 03-06-2007 09:20 PM
Wiper blades odd behavior.. misdirection S-Series General 3 02-24-2007 01:04 AM
Idiot lights flashing and erratic gas gauge behavior loguesmith L-Series Tech 9 03-28-2006 11:36 AM
