Old 05-23-2007, 04:05 PM   #1
Oceanair
Oceanair is on a distinguished road
1996 SC2
Default Headlight Actuator Gear Replacement
I just finished replacing the stripped nylon actuator gear on my left headlight of my SC2. I initially was going to replace it with a brass gear that is available for approximately $45, but decided that the Napa Autoparts nylon gear would do just fine at a cost of $11. The Napa part number is BK6652137.
The hardest part of the entire job was removing and reinstalling the motor to the headlight assembly. It took me approximately 30 minutes to remove and 30 minutes to reinstall the repaired motor. The reason I went with the nylon gear is that my car is a '96 and I figured that it lasted 11 years so another 11 years will probably see either me or the car in a graveyard.
In addition to the adhesive recommended to reseal the gear housing, I used a generous amount of Marine Tex (like JB Weld) to overlap the seam to relieve some of the strain on the resealed seam so hopefully it will not pop apart. I clamped it together and let it dry overnight. So far, it works like a champ. It sure beats getting a new actuator, or going to the wrecking yard and getting a used one that possibly won't work.
Add to Oceanair's Reputation
Rate the quality of this post and help Oceanair reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Oceanair is offline   Reply With Quote
Headlight Motor Actuator Gear Replacement Oceanair S-Series Tech 12 03-03-2009 04:32 PM
Lock actuator replacement... kevo420 Vue Tech 2 08-19-2008 08:04 PM
Trunk Actuator Aftermarker Replacement cowrack S-Series Tech 4 01-14-2008 01:43 PM
door/lock actuator replacement... how to? mlambert77 S-Series Tech 0 09-07-2006 08:26 AM
tcc actuator replacement tombstone S-Series General 4 08-25-2006 10:38 PM
