Old 10-13-2018, 02:43 PM   #1
saturnmommy
saturnmommy has a spectacular aura aboutsaturnmommy has a spectacular aura aboutsaturnmommy has a spectacular aura about
1997 SL1
Default Trunk leaking water
I have a 1997 Saturn SL1 and my trunk is leaking water. We just went through Tropical Storm Michael and I had a little more water in there than usual when it rains heavy so in trying to find some replacement weatherstripping I have hit a brick wall. I found the part number for it but everywhere I look it is a discontinued part. Does anyone have any idea what can be used as a replacement for this weatherstripping around the trunk? The original part number is listed as 21160164 but it is discontinued. I can't find any specs on the length, thickness etc.. of the weatherstripping but its original to the car and needs replacing. Any help would be appreciated. Thank you.
Add to saturnmommy's Reputation
Rate the quality of this post and help saturnmommy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnmommy is offline   Reply With Quote
Old 10-13-2018, 09:37 PM   #2
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Default Re: Trunk leaking water
It is most likely the seam underneath the quarter panel. Had this on our 1999 Sl2. You have to remove the quarter panel, scrape off the old dried seam sealer, then scuff, clean, and reapply new seam sealer and let it dry. It took me an afternoon at most, and it keeps the trunk perfectly dry.
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Old 10-14-2018, 12:33 PM   #3
DonP1
DonP1 has a spectacular aura aboutDonP1 has a spectacular aura aboutDonP1 has a spectacular aura about
Join the club LOL!
Add to DonP1's Reputation
Rate the quality of this post and help DonP1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DonP1 is offline   Reply With Quote
Old 10-14-2018, 03:31 PM   #4
odiaz1831
odiaz1831 is on a distinguished road
2003 ION-3 Sedan
Not saything is the best option, but my dad just punched a hole into his trunk. It had been leaking from the right side in his sc2. Im assuming it still leaks, but now it at least drains out? haha
Add to odiaz1831's Reputation
Rate the quality of this post and help odiaz1831 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
odiaz1831 is offline   Reply With Quote
Old 10-14-2018, 03:46 PM   #5
2 guides, one guy was rebuilding his S-Series to be good as if not better than new.
http://www.saturnfans.com/forums/sho...d.php?t=160654
http://autoleak.com/Water/Saturn-Tru...hp?topic=Water
Old 10-21-2018, 09:52 PM   #6
saturnmommy
1997 SL1
Awesome, thank you. After thinking about what you said we found the leak may indeed be from the seam as the weatherstrip does not look bad or worn. When we get time to lose the car for a day we will try this fix and may as well do both sides while we are at it. Thanks again for your advice.
Old 10-21-2018, 09:54 PM   #7
saturnmommy
1997 SL1
Thank you for showing those links. We think that seam is probably the cause and will be fixing it when we can have her out of commission for a day and the weather is good so things will dry. Thank you for your help.
Old 10-22-2018, 12:26 PM   #8
Saturn Night
Is the water building up in the small recessed sides of the trunk?
It may not be due to bad weather stripping, because my trunk doesn't even seal and it only leaks after hard rains.
So, I pulled my right quarter panel off the car(I love how we can literally just unbolt the body panels for inspecting the chassis).
The welding paste used at the factory had been retaining moisture, and the rust was under neath of it, which was leaking the water right behind the area where the tail lamps bolt into the body. It is rubber-based compound, so if you live in a humid climate or near the ocean, you will get corrosion in this area of the car.
The issue is caused by water getting under the plastic panels, where it gets trapped between the chassis and the panel.
Old 10-22-2018, 12:28 PM   #9
Saturn Night
Website will not let me rep you for this, but +1,000,000 for this one. i just typed the same thing, but i used a quick fix on mine, because I didn't know how to correctly fix the car at the time of my discovery.
Trunk Leaking MagickShadow S-Series General 7 07-10-2015 12:15 AM
ConsumerAffairs.com's Leaking Aura Trunk MJD112379 Aura General 0 09-19-2008 10:02 PM
Water Leaking what next jrb47 S-Series Tech 7 05-23-2008 10:49 AM
Trunk Leaking ur1crazymother S-Series General 9 03-01-2006 03:14 AM
Leaking trunk!? jakearoo S-Series General 6 01-22-2006 09:23 PM
