Old 09-19-2006, 12:58 PM   #1
delturcious
delturcious is on a distinguished road
delturcious's Avatar
Default Cruise control SLIPPING?
Here's a new one: I was driving up I-75 on Sunday to get my new header and engaged the cruise @ 72 like I always do. I glanced down after I set it, and my speed was stable. 30 seconds later, I was @ 65 I go through this a few more times, same effect. I know the cruise is engaging because the speed stays somewhat constant for a few seconds, but I decelerate at a MUCH slower rate than just by letting my foot off the gas.
After going through the first 150 or so posts that had "cruise control" in them, all I could find were some problems with a plastic piece that connects to the throttle cable close to the accelerator pedal. I highly doubt this is any type of electrical problem since it DOES engage-it just slows down. Is there anything else in particular (besides this plastic thing) that I should be looking for before I start pulling things apart?
Add to delturcious's Reputation
Rate the quality of this post and help delturcious reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
delturcious is offline   Reply With Quote
Old 09-19-2006, 01:21 PM   #2
Default Re: Cruise control SLIPPING?
Huh. That's just the opposite of the classic CC module failure, by which it accelerates the car above the set speed.
Add to madpogue's Reputation
Old 09-19-2006, 01:26 PM   #3
WingsOfSaturn
WingsOfSaturn's Avatar
How are your battery and alternator voltages? Once my CC started acting real funny and I did not have the time to really look into it. A few weeks later my battery died (bad cell). I replaced the battery and afterwards the CC worked just fine.
Is your rear defroster working? That died at the same time too, but started working after the new battery. Its all magic.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 09-19-2006, 01:44 PM   #4
delturcious
Odd, aint it?
Well the last time I checked the defroster was working, but I'll take a look at that this evening. The alternator is about 2yrs old, and the battery maybe 3? I'll take a multimeter to it tonight and see what it reads, but I haven't had any troubles with the battery/alternator in a really long time. I have a decently powered stereo that is always able to pull enough juice, but I'll definitely give that a looksie. Thanks for the idea!
Old 09-19-2006, 03:29 PM   #5
Hmm, is the powered stereo on when the CC is misbehaving? Have you tried it while the stereo is off?
Old 09-19-2006, 04:49 PM   #6
delturcious
No, but it's never been a problem before and at the time I was only using the amp on the front speakers (altec lansing 50w rms *2). I'll try it without that also, but it really doesn't seem like an electrical problem to me. Thanks again, and I'll post results later this evening.
Old 09-19-2006, 07:05 PM   #7
delturcious
Batt voltage off ~12V, batt voltage idle ~13V, give or take a volt since I have a cheap analog multimeter. It cranks hard and fast like always, so it doesn't seem to be a battery problem, but thanks for the suggestion. When the car's off, should there be any slack in the cable that goes from the cruise motor (solenoid?) to the accelerator pedal? There's maybe a couple millimeters. Obviously I can't test this when I'm going down the highway @ 70mph...
Old 09-21-2006, 07:14 AM   #8
BarnOwl
BarnOwl's Avatar
Run by a part store and have them check the alternator. 13 V is a little low. It may just be the accuracy of your meter but, it needs to be ruled out. If the cruise control is holding speed at all, I doubt it's the linkage to the pedal.
Add to BarnOwl's Reputation
Old 09-21-2006, 11:21 AM   #9
delturcious
I'll take it to Autozone or somewhere tonight and have them test it on the vehicle. You are right, it definitely needs to be ruled out. If it is the alternator, then I'm definitely glad my cruise went out before it REALLY died! Results to come. Thanks again!
Old 09-21-2006, 05:32 PM   #10
delturcious
According to Autozone and their little black box, my alternator and battery are a-ok. I tested out the cruise on the way there, and it held at 40mph. I didn't have time to get out on the interstate to try a faster speed, but I definitely will tomorrow evening. Maybe it holds at lower speeds but not at full highway speeds? Anything else it may be?
Old 09-21-2006, 05:46 PM   #11
davemac2
davemac2 is on a distinguished road
I'll take a wild guess and say maybe a vacuum leak because of a bad hose? Don't know what type of CC is on the Saturn though. Does your brake pedal feel normal?
davemc
Add to davemac2's Reputation
Rate the quality of this post and help davemac2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davemac2 is offline   Reply With Quote
Old 09-22-2006, 05:58 AM   #12
BarnOwl
BarnOwl's Avatar
The CC on a Saturn is nothing fancy. It's controlled by the PCM. There's a module under the dash that connects to the top part of the gas pedal. No vacumn lines or anything. If it's still not working, at this point, if this were my car, I'd be calling wrecking yards for a CC module. If it is working, I'd guess we ran the gremlin out of there.
Old 09-22-2006, 08:27 AM   #13
Gbody403
Gbody403 is on a distinguished road
Madpogue described the issue I had with my SC2. Sometimes the cruise would work fine. Other times it would accelerate, then rapidly disengage after the vehicle speed would reach about 8 mph above the cruise set point. This cycle would repeat itself and was very irritating. I was ready to replace the CC module but decided to pull the electrical connector and clean the contacts. This solved my problem. It has worked great since the cleaning.
Add to Gbody403's Reputation
Rate the quality of this post and help Gbody403 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gbody403 is offline   Reply With Quote
Old 09-22-2006, 03:26 PM   #14
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
i have the same problem with my car... and its beeh happening even after replacing the alternator with a high-output one. It mostly happens on longer trips (30 mins or more)
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 09-23-2006, 02:04 PM   #15
delturcious
That must've been what happened, because it works now Thanks for the help... if this happens again though a new CC module is going in.
Old 08-16-2009, 12:15 PM   #16
mjoekingz28
mjoekingz28 is on a distinguished road
What contacts are you talking about? Ive been through 3 pages of 8 so far in a 'cruise control' search and your example is the first Ive seen of exactly what happens to my sc2 1998 5spd.
I'll be crusing along at 70mph and look down and im going 80mph then it all a sudden disengages. what to do?
Add to mjoekingz28's Reputation
Rate the quality of this post and help mjoekingz28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjoekingz28 is offline   Reply With Quote
Old 08-16-2009, 04:18 PM   #17
adventureoflink
adventureoflink's Avatar
I know I just posted this in another thread, but I'd set my cruse to say, 60 or 65. I would then go up a hill (cut in the hill on southbound I-75, for example), it would lag by ~5mph (I'd be doing ~55mph but my cruise is set at 60), and then my RPM spikes up to 4000-4500 and holds it there until I get out of the grade (but I don't go any faster than what I've set my cruise to.) Once I'm out of the grade, I'm doing 60mph while staying within normal RPM range.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 08-16-2009, 05:10 PM   #18
First thing to do is clean the connector to the module on the column. Then verify the engine/transmission clutch is not slipping. If it is not a manual and if it is an automatic it sounds like its downshifting.
Old 08-16-2009, 05:29 PM   #19
adventureoflink
Alright.
I have an automatic, so it's probably downshifting then... that explains things.
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 08-16-2009, 06:06 PM   #20
try setting the cruise at 65 and see if it downshifts.
Cruise Control jwpaton Vue General 7 10-29-2008 08:02 PM
cruise control ? saturncrzy S-Series General 1 06-05-2008 09:24 PM
Cruise control Elementkng20 Ion General 0 05-19-2008 03:46 PM
Cruise Control Not so good on the control part? aph3x Outlook General 2 10-15-2007 08:39 PM
I've lost control of my cruise control stainlesswelder S-Series General 10 10-21-2006 12:18 AM
