Old 11-29-2009, 10:32 AM   #1
imthegr8_1
imthegr8_1 is on a distinguished road
Default head gasket, or condensation?
went to check my oil yesterday, and there was milk under my oil fill cap. I instantly thought it was a head gasket. It may still be, but im hoping not. The oil was low(barely on the stick) and i no longer am running my PCV valve as i have replaced it with a breather so the crankcase wouldn't build up pressure and blow out my valve cover gasket again(bad rings i assume). The last few morning have been under 30* and i have not had this car in the winter before now. No white exhaust smoke(except for first start in the morning, in the cold), no oil in my AF, dipstick came out clean as the milkshake was just under my cap....any ideas?
Add to imthegr8_1's Reputation
Rate the quality of this post and help imthegr8_1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
imthegr8_1 is offline   Reply With Quote
Old 11-29-2009, 10:45 AM   #2
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Default Re: head gasket, or condensation?
It's probably just condensation. It will dissappear by itself if you take it on a longer ride. Short trips won't burn it off.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 11-29-2009, 01:37 PM   #3
acman
acman has a spectacular aura aboutacman has a spectacular aura aboutacman has a spectacular aura about
1999 SC1
Before the introduction of PCV systems in the early 1960s, road draft systems were used. The road draft system was simply a vent tube that routed engine blow-by gases from the engine to a tube that ran from the engine to the back of the car, like an engine exhaust pipe.
The motivation for equipping engines with PCV systems was to prevent blow-by gases, primarily hydrocarbons (unburned fuel) from entering the atmosphere. It was the first automotive emissions control device.
PCV systems are simple systems that really help keep the oil clean by removing, among other things, water vapor.
The crankcase "pressure" you write about is caused by cylinder ring leakage, blow-by, and has nothing to do with the PCV system. The condensation you observed in your engine is due to the disconnected PCV system.
Reinstall the PCV system and drive the car until oil consumption becomes too severe to deal with, and then rebuild or replace the engine.
1997 SL2, 5 speed
1999 SL1, Automatic
Add to acman's Reputation
Rate the quality of this post and help acman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acman is offline   Reply With Quote
Old 11-29-2009, 01:54 PM   #4
imthegr8_1
with the PCV installed, the motor would hiss after i turned it off unless i took the cap off..and it would shoot the cap into my hand...im already looking for another motor to rebuild so i can drop it in one weekend...thatnks for the info though...much appreciated
Old 11-29-2009, 03:15 PM   #5
76oldsguy
76oldsguy is on a distinguished road
How long does it run before the 'hiss' starts after shut down? If it is building that much pressure it is killing your engine quicker. Have you done the 'MMO' or 'seafoam' soak yet? I would reinstall the pvc valve. Run a compression test and let us know. It is possable it could be valve guids as you stated it has some smoke on start-up but it is up in the air till a compression test is done.
98 sl2 DOHC Auto 147,000 miles.
76 Olds 442 Auto78,000 miles.
95 sw2 DOHC Auto 200,000 miles
Add to 76oldsguy's Reputation
Rate the quality of this post and help 76oldsguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
76oldsguy is offline   Reply With Quote
Old 11-29-2009, 03:48 PM   #6
imthegr8_1
it'll hiss and build some pretty good pressure after 10 seconds of idling...lol
Old 11-29-2009, 04:25 PM   #7
imthegr8_1
forgot to mention...the shortest trip this car makes in a day is 20 miles...i live in BFE...got the car on the road in late Sept. and have over 6k miles on it already...will be rolling over 200k shortly
coolant leak...head gasket, cracked head, or water pump? BRIAN41920 S-Series Tech 13 01-11-2013 03:18 PM
SOHC Alternator bracket oil puddle - head or head gasket? comanche S-Series Tech 10 09-28-2009 04:42 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 02:42 AM
Head gasket, head bolts and other head related foolishness… Quagmire S-Series Tech 9 09-12-2007 09:08 PM
cracked head,valve cover gasket or cam gasket leaking ???how to tell !! maestro S-Series General 11 06-04-2006 03:26 AM
