Old 11-29-2009, 03:56 PM   #1
Default code 41....'95 SL2
So far about all I can find for torubleshooting it is swapping parts sorta randomly. I do have 2 pair of coils I can try, 2nd set of wires, 2nd set of plugs and 1 other ICM.
Anything else I can try?
Not really noticing a problem other then a ton of smoke out the tailpipe, 0 power below ~4.5k rpm and an occasional hiccup/hesitation when the PCM thinks it's going to change gear (it can't...that's what the 5spd swap was for )
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
01 SL2 Code P0301 guzzel S-Series General 8 08-04-2009 07:33 PM
'92 SL2 code 82 amond75 S-Series Tech 3 08-11-2006 07:58 PM
po 717 code on SL2 jdragas S-Series Tech 3 01-13-2006 10:41 AM
95 SL2, SES Code 32 and Coolant Code 84? gkainz S-Series Tech 15 04-04-2005 10:43 PM
