Old 09-25-2009, 12:09 AM   #1
myth8892
myth8892 is on a distinguished road
Default Water on floor behind drivers seat
Well besides stuff i need to do in the next month, I have discovered that there is alot of water behind the drivers seat on the floor, yet i do not see any leaks around or near the drivers side window.
It has only been raining the last few days and since i bought the car it has only rained 2 other times but not much, tonight after i got off work, i noticed water behind the drivers seat, the carpet is wet near the door area behind the seat yet i didn't see anything dripping from above, this was all while it was sitting all day today while it rained (not driven).
Was wondering if anyone has had this problem at all and maybe what i should look for or look at, it was near dark when i got off work so i cannot look at it for another day or 2 at best.
As far as i know this car has never been in an accident, seems to be really straight, weather stripping around door seems to be fine as far as i can tell.
Will try and look at it better this Saturday or have a body shop take a look at it to see if they can pinpoint the problem, but figured i would ask here as well first.
This vehicle is a 94 sc1 (2 door), It soaked the floor pretty good.
Add to myth8892's Reputation
Rate the quality of this post and help myth8892 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
myth8892 is offline   Reply With Quote
Old 09-25-2009, 12:41 AM   #2
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
Default Re: Water on floor behind drivers seat
Is it a sunroof car? If so, sunroof drains can do this. If you pull out the bottom of your back seat it could be full of water as well. Is the headliner wet at all?
Add to velleguy73's Reputation
Rate the quality of this post and help velleguy73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velleguy73 is offline   Reply With Quote
Old 09-25-2009, 12:42 AM   #3
Mgg4591
Mgg4591 is on a distinguished road
Mgg4591's Avatar
does your car have a sunroof? If so the sunroof drain tubing is most likley clogged with some debris.
Add to Mgg4591's Reputation
Rate the quality of this post and help Mgg4591 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mgg4591 is offline   Reply With Quote
Old 09-25-2009, 07:20 AM   #4
myth8892
Yeah thought about that last night, forgot to mention this has no sunroof,
I havent had the chance to really look at it during daylight hours, but it got pretty wet behind the seat yet did not see any type of dripping at all.
Old 09-25-2009, 09:37 AM   #5
For cars through '95, check this by Wolfman, in the How To library
Old 09-25-2009, 03:25 PM   #6
myth8892
Going to try wolfmans idea out, i bet or hope that will take care of the problem,
Today when i got into the car and it was still raining out, i did see a drip out of the corner of my eye from above, it has been raining almost non stop the last 4 days here in cincinnati ohio, sunday i believe it is supposed to stop, so going to try his idea and hope it fixes it.
Thanks for linking that to me
Old 09-25-2009, 05:04 PM   #7
You're welcome, and be sure to read that thread all the way down to the 'dollar bill' test for the warped door, too
water build up in rear seat floor? jmorgan3312 2008 Vue 9 01-05-2009 08:01 PM
water in drivers door captainjohn Aura General 1 03-13-2008 08:38 PM
water in passenger back seat floor jjd161 S-Series Tech 2 12-29-2007 09:55 PM
pass. seat track on drivers seat? fetchitfido S-Series Mods 4 10-04-2006 10:40 AM
L series drivers floor mat Three Rings L-Series Tech 4 07-15-2001 06:13 PM
