Old 11-11-2004, 12:16 AM   #1
Azrael_02
Azrael_02 is on a distinguished road
Azrael_02's Avatar
2009 VUE Red Line
2004 ION Red Line
Default 99 SL2 Body Parts Help
Hello All,
Well, after leaving my car parked in the street, I discovered some hit my car and left without telling me. Everything mechanically is fine, but it looks like I am gonna need a replacement for the driver's side fender. I've been looking around the net for replacement parts, but I was wondering if any of you could help me locate replacement parts. (Trusted places/ recommendations) Is it easy to remove the old and install the new fender? Thanks
Add to Azrael_02's Reputation
Rate the quality of this post and help Azrael_02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Azrael_02 is offline
Old 11-11-2004, 08:02 AM   #2
jegster
jegster is on a distinguished road
jegster's Avatar
Default Re: 99 SL2 Body Parts Help
Check with http://www.msrecycling.com/ up in Sacramento.
Jeff
http://www.cardomain.com/id/jegstersl2
Add to jegster's Reputation
Rate the quality of this post and help jegster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jegster is offline
Old 11-11-2004, 11:11 AM   #3
myoung
myoung is on a distinguished road
myoung's Avatar
Originally Posted by Azrael_02
Hello All,
It's not the easiest thing to do, but it's definately not the hardest. I've done it on a first gen SL2 and a second gen SC2... I'm guessing that your car will be more like my SC2, where you'll have to remove the plastic pushpins from the rocker panel and slide it towards the back tire so it'll pop off, at which point you'll be able to get to the two bolts at the bottom. I'm not completely sure of that though.
Add to myoung's Reputation
Rate the quality of this post and help myoung reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
myoung is offline
Old 11-11-2004, 11:19 AM   #4
myoung
myoung's Avatar
ok so I was a little right... here's the official GM method of doing it:
1. Remove the front wheelhouse panel outer fasteners.
2. Remove the front and middle fasteners on the rocker panel cover to lower the front end of the rocker panel cover.
3. Remove the bottom rear fender bolts.
4. Remove the windshield frame fill panel applique by removing the bolt, then sliding it upward.
6. Remove the bolt from the rear upper corner of the fender to the front body hinge pillar.
7. Remove the bolts from the fender flange to the upper motor compartment rail.
8. Remove the 2 fender-to-fender reinforcement bracket bolts.
9. Remove the fender.
Installation Procedure
1. If the fender is replaced: Install the Saturn emblem. Install the rubber seals to the fender rear flange.
2. Position the fender on the motor compartment side rail.
3. Align the fender to the door and hood.
4. Install the fender to the front body hinge pillar bolt. Notice: Refer to Fastener Notice in Cautions and Notices.
5. Install the anti-flutter bumper. Tighten Tighten the fender-to-front body hinge pillar bolt to 10 Nm (89 lb in).
6. Install the bolts from the fender flange to the upper motor compartment side rail, bottom rear fender to support, and fender-to-fender reinforcement bracket. Tighten
Tighten the fender-to-upper motor compartment side rail to 10 Nm (89 lb in).
7. Position the front fascia and slide it into place.
8. Install the windshield frame filler panel applique.
9. Install the front of the rocker panel cover with plastic fasteners.
10. Install the front wheelhouse panel outer fasteners.
END
I can email the document to you with pictures and stuff.... it was just to big to post here.
myoung is offline
Old 11-12-2004, 12:44 AM   #5
Azrael_02
Azrael_02's Avatar
2009 VUE Red Line
2004 ION Red Line
thanks for the help
98 SL2 body parts query dreamliner77 S-Series General 4 03-05-2006 05:04 PM
I need body parts for 93 Sl2 PLEASE! iceman_15200 Classifieds 0 11-26-2005 09:06 PM
WTB: blue body parts (SL2) from '93-'95 and possibly '92 geartooth94 Classifieds 2 10-20-2005 05:32 PM
WTB: 95 SL2 Body Parts blackeagle1 Classifieds 3 05-25-2005 12:38 AM
FS: 97 SL2 body parts sl2vt Classifieds 7 08-30-2003 07:13 AM
