Old 07-14-2002, 03:59 AM   #1
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
Default 93 SC2 Vehicle Speed Sensor..how much to get put on?
Well, I seen that this part is $20 from DeHart. How much you think Saturn would charge to put it on? I do believe my speedometer is off, because I got a ticket for doing 55 in a 45...when I KNOW I was doing just about 45mph. SO, it only leads me that I have a fix-it ticket and NOT a speeding ticket.
Add to TIMSPEED's Reputation
Rate the quality of this post and help TIMSPEED reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TIMSPEED is offline
Old 07-14-2002, 08:21 AM   #2
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default
Easy way to check your speedometer -- wear a watch with a second hand, or use a stopwatch. Drive 60 mph, and in 1 minute, you should cover exactly 1 mile. However, don't use the odometer to gauge the mile, as it's linked to the speedometer. Use hwy mile markers on the side of the road, or use the distance between fwy off ramps, according to the signs.
Also, if you've changed the tires or wheels on your car away from the stock size, your speedometer/odometer will be inaccurate.
Other than that, if it is your VSS, search the board for topics. I think it's easy to replace, and if I remember correctly, it's threaded into the top of the transmission, just under the battery area.
Add to Heartbeat - '95 SL2's Reputation
Rate the quality of this post and help Heartbeat - '95 SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Heartbeat - '95 SL2 is offline
Old 07-14-2002, 08:29 PM   #3
wolfman
wolfman's Avatar
Default
A VSS off to the tune of 10mph would also probably be causing havoc with the PCM and setting SES light codes. Recommend you test the speedo in a "measured mile" FYI: Mile markers (those numbered green little "signs" along the hiway) are 1 mile apart exactly...a good way to test.
Add to wolfman's Reputation
wolfman is offline
Where is the vehicle speed sensor? 2sweetcheeks S-Series Tech 5 08-18-2016 04:01 AM
L300 Vehicle Speed Sensor Urbanrover L-Series Tech 2 03-22-2005 09:46 AM
Vehicle speed sensor. dday S-Series General 23 03-19-2005 11:27 AM
Vehicle speed sensor wire? BlueDevil Vue General 10 06-22-2004 02:03 PM
vehicle speed sensor (VSS) dohc 97 S-Series Tech 4 04-07-2002 05:31 PM
