Old 09-20-2017, 09:25 PM   #1
ashlogfarms
ashlogfarms is on a distinguished road
Default 2003 Ion cooling fan viberation
My daughters car - the cooling fan in viberating like crazy when on. There appears to be mounting screws in the top of the radiator that are missing and allowing the entire radiator assembly to viberation. It almost looks impossible to get screws in but the fan vibration seems to still exist even if screws were in and secure. Is excessive viberation an indicator of a bad fan? Thoughts?
Add to ashlogfarms's Reputation
Rate the quality of this post and help ashlogfarms reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ashlogfarms is offline   Reply With Quote
Old 09-21-2017, 02:23 AM   #2
Default Re: 2003 Ion cooling fan viberation
Some cooling fans are almost impossible to examine due to limited space in the engine area. Below are some info to help. It appears the fan blades have a circular ring as part of its assembly to keep blades from flexing - a rigid assembly. Examine it for damage. If its damaged and replacement is needed, I can post or send replacement procedures thru private email (pm me with an email address). Fan blade assembly is either from online sites or junk yards.
Old 09-21-2017, 11:07 AM   #3
pierrot has much to be proud ofpierrot has much to be proud ofpierrot has much to be proud ofpierrot has much to be proud ofpierrot has much to be proud ofpierrot has much to be proud ofpierrot has much to be proud ofpierrot has much to be proud of
The cooling fan replacements which are available as OE, or aftermarket new parts are only provided as complete assemblies - shroud, motor, and fan. If you choose to pick a wrecking yard part from a self serve yard then be careful with the removal of the clip which attaches the fan to the motor. It is NLA from the factory so it appears that you'd have to reuse that part either from your car or the donor. The link below shows the picture of the parts breakdown schematic along with prices and availability.
https://www.wholesalegmpartsonline.c...category=19524
Below are RockAuto.com's selection of replacement fans assemblies.
http://www.rockauto.com/en/catalog/s...r+conditioning
280,000 miles-it keeps on rolling!
Add to pierrot's Reputation
2003 l200 cooling fan !!!! 339svq L-Series Tech 1 06-23-2011 04:49 PM
2003 Ion Cooling mtb777 Ion Tech 0 08-02-2010 05:03 PM
Cooling fan relays? L200/2003 hacadacalopolis L-Series Tech 3 04-10-2010 10:49 PM
2003 V6 AWD Front Cooling Fan Question hilarski Vue General 10 03-02-2009 02:20 PM
Viberation Between 40-65 Mph AURAXEX2 Aura General 56 03-05-2008 01:00 PM
