Old 10-06-2010, 01:50 AM   #1
saturndetails
saturndetails is on a distinguished road
Default 2003 Ion 2 4-Door Excessive Tire Wear
I don't think I've put a single set of tires on my car that wore evenly. I've had alignments, the works and the edges always wear thin coupled with a "thudding" when driving. I've had everything inspected, aligned and replaced, still happens. Any ideas? I'm very conscious of tire pressure and maintain it as I should according to the owners manual.
Add to saturndetails's Reputation
Rate the quality of this post and help saturndetails reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturndetails is offline   Reply With Quote
Old 10-06-2010, 11:31 AM   #2
lgodave
lgodave will become famous soon enough
2003 ION-3 Sedan
Default Re: 2003 Ion 2 4-Door Excessive Tire Wear
Assuming your driving style and tire rotations are "normal"... I've got nothing.
Have you had all your tire work done by a single shop?
Maybe a second or third opinion from different Tire Shops are in order?
It's possible there is something the original shop overlooked or their equipment has screwed up...
Care to share the types of tires you've driven on this vehicle? Summer/Winter/All-Season...
Add to lgodave's Reputation
Rate the quality of this post and help lgodave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lgodave is offline   Reply With Quote
Old 10-06-2010, 12:11 PM   #3
saturndetails
I've been to several different shops and the answer is always the same. I buy lower to mid-grade all season radials.
Old 10-06-2010, 08:53 PM   #4
lgodave
2003 ION-3 Sedan
I'd suggest looking at tirerack.com and see if you can find the various different kinds of all season tires you've used on this vehicle and see if reviews/surveys might give you clues as to what kind of wear others have seen.
After that... check the warranty coverage on your current set... you might want to try making a claim. If the shops/paperwork can backup that the vehicle is not the problem... then you might have a case that the tires are junk.
Old 10-09-2010, 04:52 PM   #5
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
You know what? The edges wear thin on my car too. I put this down to the awful suspension on these cars. Lowering and a mild torsion upgrade does wonders for these cars and can be done for 400 to 500. Very worthwhile investment. The bodies roll too much and cause wearing on the outside of the tires. Icreasing tire pressure slightly can help a bit(going from 30PSI to 32PSI say). Slowing down in corners more than you do will help a lot.
Add to chilipepper1327's Reputation
Rate the quality of this post and help chilipepper1327 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chilipepper1327 is offline   Reply With Quote
Old 10-09-2010, 05:25 PM   #6
lgodave
2003 ION-3 Sedan
Good point about tweaking the PSI (I think my Goodyear Tripletreds were recommended at 32 PSI (instead of 30) by my local shop).
That along with regular tire rotations and the other tips you suggested might help a lot.
Now to start thinking about your suggestion of suspension upgrades on my ION.
Old 10-09-2010, 10:16 PM   #7
2006 ion2
2007 ION-2 Sedan
My ion has stock suspension, with a rear anti sway bar, and not only does it not roll at all, but out does not wear my tires unevenly. I do ruin nitrogen in my tires, and this run it 2-4psi higher, but the stock suspension is not that bad, if you know the weaknesses to fix. Lowering is not necessary, the bar brings it into balance just fine.
Add to 2006 ion2's Reputation
Old 10-10-2010, 07:57 AM   #8
chilipepper1327
Don't knock lowering until you have tried it! Center of gravity is lowered and that makes one hell of a difference!
Old 10-10-2010, 12:48 PM   #9
2006 ion2
2007 ION-2 Sedan
don't underestimate the effects of the bar.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 10-10-2010, 01:52 PM   #10
2006 ion2
2007 ION-2 Sedan
2007 Saturn Ion 2
Old 10-11-2010, 09:47 AM   #11
chilipepper1327
I didn't and wouldn't.
Excessive Tire Wear NCarolina L-Series General 58 10-04-2009 07:56 AM
Excessive Wear Contract POOLDIVER64 General Saturn Discussion 8 10-19-2007 08:46 PM
Excessive heat underneath spare tire well? mellissam Vue General 1 07-21-2006 11:08 PM
Tire wear... acr2001 S-Series General 14 02-07-2006 10:16 AM
2003 L300 Excessive Creaks & Rattles Ryan L300 L-Series General 10 04-27-2004 08:07 PM
