Old 04-17-2009, 02:26 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default How do I know if my Inner Tie Rods are bad?
How can I tell if my inner tie rods are bad?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 04-17-2009, 02:32 PM   #2
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Default Re: How do I know if my Inner Tie Rods are bad?
Front wheels in the air. Check for any freeplay by moving each front wheel slightly side to side. If there is play it could be coming from the inner or outer. Inner tie rod play will be felt by shaking the tire and having your hand around the tie rod.
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 04-17-2009, 03:05 PM   #3
To test them properly you disconnect the outer tie rod ball joint and lift the inner rod to a horizontal position and let go. If it drops right down its ready to replace. there is supposed to be enough drag in the inner joint to allow it to hold position. The outer end will add additional weight so it may sag and still be good. If you can feel motion then its way bad.
Old 04-18-2009, 08:53 AM   #4
westwind999
1999 SW1
Also consider with the wheel jiggling method that the whole rack will move too. Sometimes it seems loose but the steering wheel is also moving. Oldnuc's method is much more accurate but a bit more time consuming.
Old 04-18-2009, 01:44 PM   #5
mr18436572
2000 SL2
Part of checking it with the jiggling method is to not let the steering wheel move. If there is play in either tie rod, it will be noticeable and felt as soon as you move the tire side to side SLIGHTLY
Tie rods popoquira S-Series General 5 06-03-2006 09:42 AM
Tie rods need your thoughts alfieferenzo84 S-Series General 6 01-14-2006 05:39 PM
Tie Rods need replacement ricksLS1 L-Series General 27 07-16-2005 09:07 PM
Tie Rods DaytonaSL2 S-Series General 2 06-13-2005 06:55 PM
Tie Rods? PBV Miscellaneous Tech 6 05-27-2003 11:17 AM
