Old 09-06-2002, 06:59 PM   #1
SoUp
SoUp is on a distinguished road
Default Door handle
How do I remove the outer door handle of my '97 SC1? I don't see anything to push when I lift the handle up. I'm trying to remove the outer skin of the door.
Add to SoUp's Reputation
Rate the quality of this post and help SoUp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SoUp is offline
Old 09-06-2002, 08:26 PM   #2
Default
Lift the handle up and look to the rear of the under side. You will see a push pin hold on clip. What this is is a pin with an expanding outer sheath and a centre push in pin. The centre pin when pushed in expands the outer sheath. What you have to do is pull out the centre pin (should have a cap on it so it will likey look like just one piece but look at the edges and you should see the cap edge) and the the outer sheath. When the entire pin is out then you should be able to tap the door handle forward and it will come off of the mechanism on the inside of the door.
Add to ssicarman's Reputation
ssicarman is offline
Old 09-07-2002, 09:40 AM   #3
SoUp
Default
The pins just don't seem to want to come out. I'm afraid I'm going to break them. They don't budge at all.
SoUp is offline
Old 09-07-2002, 01:58 PM   #4
SoUp
Default
The cap around the pin bends so easily. That's the part I'm afraid will break.
SoUp is offline
Old 09-07-2002, 02:55 PM   #5
SoUp
Default
Well the cap did indeed tear off from the pin. I don't know how to get it out now. I'm open to suggestions unless I'm just doing something wrong.
SoUp is offline
Old 09-08-2002, 01:24 AM   #6
Default
Two ways to go now. Use a very sharp (and strong) pick and push the point of the pick into the end of the pin and pry it out. Other way, just push the pin in and out of the outer part.
Old 09-08-2002, 02:17 AM   #7
Qlara
Qlara's Avatar
Idea
SoUp: Don't worry if you broke that Cap-rivet under the door handle, just try your best to get it out (with ssicarman description). Then go to Parts department to pick up couple of this cap NEW.....they're so cheap to replace.
Add to Qlara's Reputation
Qlara is offline
Old 09-24-2002, 02:25 PM   #8
SoUp
Default
Well they are being a real pain in the butt to get out. I want to take the outer door panels off so I can install an Autoloc door powerlock/keyless entry kit. Anyone know what kind of places would install the autoloc for me? Would the dealer? Unless someone lives near Huntsville, AL.
SoUp is offline
Old 09-24-2002, 03:40 PM   #9
2000 SL 1.9
2000 SL 1.9 is on a distinguished road
Default
did you check on autoloc's website for authorized dealers in your area?
Add to 2000 SL 1.9's Reputation
Rate the quality of this post and help 2000 SL 1.9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2000 SL 1.9 is offline
Old 10-01-2002, 06:06 PM   #10
SoUp
Default
Yep but they don't have any dealers close to me.
SoUp is offline
Door handle won't come off... wishihadacamaro S-Series Tech 11 11-26-2008 11:25 AM
What's holding in the power door lock buttons in the door handle? Smokey S-Series Tech 2 09-22-2006 04:52 PM
Door Handle saturnplastic Classifieds 3 12-20-2004 10:53 AM
Inside door panel removal? '93 SC2 -- specifically the door handle... benson500 S-Series Tech 5 12-06-2004 07:48 PM
Door Handle Help 97sw2 Miscellaneous Tech 2 01-06-2003 10:10 PM
