Old 05-07-2007, 06:27 PM   #1
The Critic
The Critic is on a distinguished road
The Critic's Avatar
1996 SL2
Default Urgent!! Starter ???
It seems like my Saturn wants to start about once every twelve tries. It got a lot worse today.
I turn the key, and just hear the solenoid engage, once. Click.
That's all that happens. Each time I turn the key, that's all I get. Connection is fine at the battery, everything seems tight.
Is it really a starter???I'm about to run out right now and pick-up an Autolite Platinum starter and slap it on as I'm getting worried...
Thanks.
Add to The Critic's Reputation
Rate the quality of this post and help The Critic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The Critic is offline   Reply With Quote
Old 05-07-2007, 07:17 PM   #2
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Default Re: Urgent!! Starter ???
How's your charging system and battery? Do you have 12 volts going to the starter?
I'd say the starter solenoid is bad. Just get a reman and throw it in there.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 05-07-2007, 08:15 PM   #3
Ryan from Ohio
Ryan from Ohio is on a distinguished road
Why buy the whole starter?
Just buy the solenoid!
Take the starter OUT so you can have it tested. If the starter motor is good, just buy the $20 or less solenoid and install.
Add to Ryan from Ohio's Reputation
Rate the quality of this post and help Ryan from Ohio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ryan from Ohio is offline   Reply With Quote
Old 05-07-2007, 09:43 PM   #4
The Critic
The Critic's Avatar
1996 SL2
12.9 v- engine off
14.0 v- engine on
So I think my battery and alternator (somewhat new) are both OK.
They only sell the solenoid and starter motor as once piece. So it looks like I'll need to get a $143 Autolite Pro new one.
Old 05-07-2007, 11:39 PM   #5
kornphlake
kornphlake is on a distinguished road
1996 SL2
I've had two starters go bad, it was the starter definitely not the solenoid. The bearings go bad and bind up under heat, sometimes it'll loosen up as it cools sometimes it won't. When you have the starter tested listen for noisy bearings, most likely it will work just fine on the bench after getting jostled around during removal. Why buy a whole new starter when you only need bearings? Because like the solenoid bearings are integrated with the starter, neither the bearings or solenoid are user serviceable. Regardless of the problem you need a new starter.
Add to kornphlake's Reputation
Rate the quality of this post and help kornphlake reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kornphlake is offline   Reply With Quote
Old 05-08-2007, 01:00 AM   #6
The Critic
The Critic's Avatar
1996 SL2
Come to think about it, my problem only occurs after repeated starts after many short trips during the course of one day. If I allow the car to sit overnight, it starts fine. If it sits for say, four hours after a drive, it'll start fine. It's only when I go from the store to the school and to say, a restaurant, will it act up.
Any tips for starter r/r? What tools do I need? The instructions mention something about an "obstruction wrench." ???
Thanks.
Urgent question 01SL1SATURN S-Series General 10 11-02-2008 10:57 AM
Need Urgent Help!!!!!! Suspension, Help!!!!!!! 97sleeper S-Series Tech 5 12-28-2006 08:04 PM
Anyone have a used valvebody? URGENT alec_b S-Series Tech 6 10-19-2006 08:55 PM
Urgent Girafro S-Series Tech 8 12-06-2004 12:43 PM
URGENT: Help Needed! thewretched Miscellaneous Tech 4 08-02-2004 04:21 PM
