Old 09-28-2017, 11:52 AM   #1
Murby
Murby is on a distinguished road
Default 2003 L200 Rear Brakes
Hi Folks,
The drivers side rear brake assembly on my wife's 2003 Saturn L200 sort of self destructed.. Looks like the wheel cylinder let loose and pinned the drum pads against the rotor or something.
Had to cut the brake drum to get the darn thing off since they didn't put jacking screw threads into it.
I'm in need of a parts diagram to show how it all goes back together.. I bought all new parts from the wheel cylinder to the pads, spring kit, and the brake drum..
Can someone help?
Add to Murby's Reputation
Rate the quality of this post and help Murby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Murby is offline   Reply With Quote
Old 09-28-2017, 12:05 PM   #2
Default Re: 2003 L200 Rear Brakes
It would be easier to use the opposite side for reference and mirror image as long as you don't disassemble the working side. Service manual drawings aren't as clear as photos and manuals no longer have photos. Googling for specific brakes may show an actual image of your rear brakes too.
Are your rear brakes disc or drums?
Old 09-28-2017, 04:52 PM   #3
Murby
The car has drums on the rear and getting the one side off was nearly impossible.. I had to cut the drum off with a slicer wheel..
They designed it so you couldn't put a bearing puller on the backside and no jacking screws to work with..
Old 09-28-2017, 05:25 PM   #4
Are you aware of an access hole on the backing plate to; insert a screwdriver in the access hole and push the park brake lever toward the outside of the drum to release the shoes from the adjuster. All star wheel adjusters allow manually adjusting them for brake shoe contact before and after putting drums on. When the drum retaining screw is removed, well worn drums have an inside lip that prevents drum removal so adjusting the star wheel to retract brakes allows clears the lip for drum removal.
Old 09-29-2017, 12:20 PM   #5
Murby
I tried that.. there's two of those rubber plugs.. one on each side and it didn't work...
Old 09-29-2017, 12:26 PM   #6
I can send you some pictures and information. Please send a p/m with an email address to send the info to.
294,000 miles-it keeps on rolling!
Add to pierrot's Reputation
2003 l200 brakes making grinding noise after lockup tfmc369 L-Series Tech 5 07-12-2011 10:23 AM
02 L200 - Noisy Rear Disc Brakes meano L-Series Tech 4 02-15-2011 11:47 AM
2003 L200 w/ rear drum brakes 99k miles tom1pa L-Series Tech 1 05-20-2010 10:49 AM
2003 L200 rear drum brakes 91000 miles etp26 L-Series Tech 5 06-21-2008 09:10 PM
Brakes for a 2003 L200 aken L-Series Tech 5 10-04-2005 05:12 PM
