#1 |
![]() Join Date: Nov 2009
![]() ![]() Felt through the seat of the pants, particularly in the shotgun seat and quite softly through the wheel. I purchased all new tires (needed anyway) had them all balanced and had the tracking set up (it was a little out). The shimmy came back, cruising on the highway 60-70mph it disappears but on decelleration comes back but is not ALWAYS there. Sometimes it's noticable just a 15-20mph moving through heavy traffic. I wondered at first about an out of center disc but surely that would be noticed every time I applied the brakes? Only other thing that occurs to me is a worn strut or mount, external check doesn't show anything obvious. Mileage is 57k+ base model 2.2 engine Otherwise this is a great car (4244 mile round trip FL-CO-FL without missing a beat). Any suggestions to the mystery would be welcome. |
#2 | |
![]() Join Date: Jul 2009
2006 ION-3 Quad Coupe
![]() Quote:
Take the car to the place where you got the tires and ask them to check the balance of the tires installed, and if it was just 2, ask kindly if they will check the other 2. Balance weights can dislodge and get lost, so it is very possible. If not the wheels, check your bearings. Does the vibration increase a lot when you brake? Worn struts will cause extra vibration, but only when going over bumps etc. Badly balanced wheels WILL make the shock problem worse. Burnt rotors is another issue, but this will only show when braking. |
#3 |
![]() ![]() Front wheel bearings especially FWD is always a possible, the wheel passes the "hand wobble test" - I wonder if I kerbed it? I agree the brake/rotor is unlikely. Unfortunately, I'm condo living with no garage or space to work on it myself, thanks for the input, let's see what time may bring. |
Bookmarks |
Strange Clicking Front End Noise-SL series | horny-toad | S-Series General | 1 | 11-30-2007 05:39 PM |
bad vibes - help | duncan | S-Series Tech | 9 | 07-03-2007 05:53 AM |
End of the 97SL2 Front End Horror or is it? | jkrettlen97SL2 | S-Series General | 4 | 04-22-2006 07:19 AM |
Update 03/ION/Sedan front end to 05 front end? | 03IONSedan | Ion Tech | 8 | 06-08-2005 09:22 AM |
strange noise from rear-end ?? | sps SOHC | Miscellaneous Tech | 9 | 09-17-2004 09:41 AM |
