Old 03-20-2019, 08:39 PM   #1
twigstick
twigstick is on a distinguished road
Default Key stuck in ignition and shifter stuck in park also wonít crank
Good day I have a 2007 Saturn ion that has been running very rough at idle changed the throttle body and pcm now the key is stuck in ignition and shifter stuck in park and wonít crank. I put the old pcm back in car and still wonít crank or let me take key out or shift out of park... any ideas how to solve this problem thank you in advance.
twigstick is offline   Reply With Quote
Old 03-20-2019, 09:39 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Key stuck in ignition and shifter stuck in park also wonít crank
It sounds like you may have an electrical problem (dead battery and/or bad alternator Connect some jumper cables to your car from another car. Then, try to remove the key.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles
2007 Chevy Equinox LT 195K miles
2018 Chrysler Pacifica Touring L 48K miles
Old 03-20-2019, 10:01 PM   #3
twigstick
Thanks Iíll check that out as my battery is dead I had booster cables to it but may not been on good
02 vue stuck in park Help! Luckysaturn13 Vue Tech 0 12-30-2016 03:07 PM
Key Gets Stuck In Ignition When In Park BlazinStreets Ion Tech 9 04-30-2012 12:46 AM
Shifter stuck in park... silverariana S-Series Tech 9 07-14-2011 01:15 PM
SC2 is stuck in park! tggroo7 S-Series Tech 7 03-12-2009 06:29 PM
Sw2 Stuck In Park! Donny S-Series Tech 6 12-05-2004 10:32 PM
