Old 10-31-2009, 04:10 AM   #1
silvervu
silvervu is on a distinguished road
silvervu's Avatar
2004 VUE 3.5L
1998 SW2
Default my flow direction control is stuck on chest level
my control knob even when turned to floor will only flow at the chest level selection,infact it won't flow anywhere else but the chest level position,any thoughts?
silvervu is offline   Reply With Quote
Old 10-31-2009, 10:25 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: my flow direction control is stuck on chest level
You might want to try the following HVAC calibration procedure:
Calibrate the mode door by simultaneously pushing the A/C and RECIRC buttons on the HVAC control module three times each, within two seconds of initial push (with ignition switch ON).
The A/C and RECIRC button LED's will flash while this calibration is taking place.
The calibration will take anywhere between 10 to 30 seconds depending on battery voltage.
The LED's will quit flashing when the calibration is complete.
Cycle the ignition and verify proper operation
Old 10-31-2009, 12:32 PM   #3
silvervu
silvervu's Avatar
2004 VUE 3.5L
1998 SW2
Thumbs Up Re: my flow direction control is stuck on chest level
Thank you grump,i will give it a go next time out.this forum is the best thing i've come across in a long while
Silvervu
Dynomax Cat flow direction? serenitythen S-Series Mods 1 04-02-2008 10:53 AM
Trying to get the air flow control off Damins S-Series General 2 09-29-2007 05:33 PM
94 SC2 - AC control doesn't change air flow direction wscreate S-Series Tech 0 05-05-2007 01:01 PM
Which direction does transmission fliud flow? mfabel S-Series Tech 4 04-21-2007 04:22 PM
Interior Fan Direction Control Broken- How to Fix? Leadsled Coupe S-Series Tech 0 01-26-2007 02:15 PM
