Old 11-06-2018, 06:52 PM   #1
Pete28
Pete28 is on a distinguished road
Default 98 sl2 transmission coolant line issue?
First let me start by saying I am definitely not a mechanic. My daughters 98 had a bad radiator and transmission coolant lines. I replaced those and the thermostat and ects. So this morning my transmission is bone dry. My question is can you put the coolant lines in the wrong port? It ran awesome and no problems for a week. Maybe it's just a fluke?
Add to Pete28's Reputation
Rate the quality of this post and help Pete28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pete28 is offline   Reply With Quote
Old 11-07-2018, 10:31 AM   #2
Casper50
Casper50 will become famous soon enough
2001 SC1
2000 SL2
Default Re: 98 sl2 transmission coolant line issue?
Is it bone dry or just not registering on the dipstick? If you don't have transmission fluid in your coolant or coolant in your transmission fluid then you should be fine. There is no way to cross any lines and the only way to get those fluids to mix is if you have a bad trans cooler in the new radiator. If you were only a quart or two low on trans fluid I would top it off and keep an eye on it. Between replacing the lines and the cooler you will have some fluid loss.
Add to Casper50's Reputation
Rate the quality of this post and help Casper50 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Casper50 is offline   Reply With Quote
Old 11-07-2018, 05:36 PM   #3
Pete28
Hi Casper. Thanks for the reply. No fluid in the wrong place so I'm good there. I pulled the dipstick and it was bone dry. I added a quart and let it sit overnight. I'm going to check it again in a few minutes I just got out of work.
Old 11-07-2018, 07:47 PM   #4
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
I was never a fan of those snap in lines in the transmission. I doubt you are bone dry, I suspect you have a leak and at least two quarts leaked out. The dip stick does not go to the complete bottom of the transmission pan. To get a correct reading the car should be driven prior to warm it up, then to check the fluid you need to have the engine running with transmission in park to measure correctly. The valve body and torque converter all hold fluid, you cannot get an accurate reading with the engine cold and not running. If you where bone dry the car would not shift, I suspect you are down two - three quarts. Keep us posted.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 11-07-2018, 09:34 PM   #5
Pete28
So a bit of an update. Got back to work on the car and looking at it one of the clips was cracked in half so I really hope there is a way to get new ones as I haven't found them yet
The other concern I have is I pulled both lines off and I may have had them backwards as it seems one goes in easier. Also it gives me a bit more room between the transmission filter. There is also a possibility that I put the plastic clips on incorrectly. Any thoughts?
Old 11-07-2018, 09:53 PM   #6
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: 98 sl2 transmission coolant line issue?
21001873 GM
Amazon or eBay
1995 SL1 236,300 2005>2018
1997 SL1 69,000 21 yrs. and Legal!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-07-2018, 11:00 PM   #7
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
The white plastic clips are Dorman 800-005 Quick Disconnect clips, 5/16". They are also called, "retaining clips," on the same box.
Add to edlee's Reputation
Rate the quality of this post and help edlee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edlee is offline   Reply With Quote
Old 11-08-2018, 10:57 AM   #8
Casper50
2001 SC1
2000 SL2
There are a couple of good sources for the clips above. Even if you did manage to get the lines backwards it would only change the way that the fluid circulates through the cooler. It will flow either way just the same. If you aren't having any noticeable leaks then that probably isn't your reason for being low on fluid. Like said before if you were bone dry the car wouldn't move. Get the trans hot and check it with the engine running and in park. Adjust the fluid as needed. Then keep an eye on it to see if you have a problem. If you broke a clip then replace it with a suggestion from above.
Old 11-08-2018, 06:52 PM   #9
Pete28
Thank you everyone so much for all of your help. I have general auto knowledge and can figure most things out and I just keep on plugging away until I get it right. I'll get those lines and the transmission figured out this weekend and hopefully my new motor mounts will arrive tomorrow as I have to change all of them. I've never done them before but it looks to be pretty cut and dry. I'm not ashamed to say that youtube has been my teacher for my repairs so far. I really appreciate the help that you guys have given me so far it means a lot. Also a huge thank you for not knocking me doing it myself. I've had more than a few people tell me I should take it to a shop if I haven't done it before.
Old 11-12-2018, 09:11 AM   #10
Pete28
Morning folks! I am very happy to say that I got the transmission coolant line situation figured out. I was actually able to locate the clips I needed at one of the older parts places for next to nothing. Turns out I just hadn't pushed one of them in quite far enough. I called a buddy of mine and explained the situation and he came over and got it to go in like 2 seconds. Thank you so much everyone!
Old 11-13-2018, 09:26 PM   #11
SalemCat
SalemCat will become famous soon enough
Originally Posted by SRGW View Post
21001873 GM
Amazon or eBay
CHECK YOUR OIL!!
What are these ?
They do not resemble the plastic clips at all.
Add to SalemCat's Reputation
Rate the quality of this post and help SalemCat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SalemCat is offline   Reply With Quote
Transmission coolant line leaking theunpaidBill S-Series Tech 10 05-06-2016 04:55 AM
Radiator Transmission Coolant Line Tip rtfm17 S-Series Tech 3 12-11-2015 12:38 PM
Small transmission fluid leak from radiator transmission cooler line EvanVanVan S-Series Tech 5 10-13-2014 07:55 PM
'96 SL1 coolant line identification SaturnNovice S-Series Tech 8 02-25-2010 12:57 AM
Coolant Line removal Tanro S-Series Tech 6 11-13-2007 05:50 AM
