Old 12-23-2013, 03:16 PM   #81
RobertGary1
Default Re: just did my timing belt/water pump with PICS!
Originally Posted by BlueHeron View Post
Thanks, must have been a computer cliche. They were not there before. Is the Aisin kit only available for the Red Line model? How many people replaced their seals when doing this job? Thanks
The link I provided above is not redline. I noticed the price has dropped even more. It's really a steal at this point.
Just inspect for oil leaks around the cam. I didn't both replacing them.
-Robert
Old 12-23-2013, 09:28 PM   #82
BlueHeron
BlueHeron is on a distinguished road
Amazon is saying it doesn't fit the 2004 vue 3.5. Rockauto indicates that that exact part number is for the Redline. I'm just crossing by t's and dotting my eyes, but is there no difference? Thanks
Add to BlueHeron's Reputation
Rate the quality of this post and help BlueHeron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlueHeron is offline   Reply With Quote
Old 12-23-2013, 10:50 PM   #83
RobertGary1
Hmmm. It matches for my 2006 fwd vue. Maybe it's different for the 2004??
Old 12-23-2013, 11:00 PM   #84
RobertGary1
Hmmm, I clicked on the 'See vehicles this fits' and scrolled down to Saturn and got...
Saturn Vue 2004 3.5L V6 Interference Engine: With
Interference engine
Saturn Vue 2005 3.5L V6 Interference Engine: With
Interference engine
Saturn Vue 2006 3.5L V6 Interference Engine: With
Interference engine
Saturn Vue 2007 3.5L V6 Interference Engine: With
Interference engine
http://www.amazon.com/gp/product/com...arId=003&i=150
(scroll to bottom, it should show Saturn's this fits)
-Robert
Old 12-23-2013, 11:41 PM   #85
far2grumpy
far2grumpy's Avatar
Interference engine
Interference engine
Interference engine
Interference engine
-Robert
I happened upon a few differences in 3.5 starting with 2006 model year a few weeks ago - and then promptly forgot about them.
The shape of timing belt drive sprocket teeth were changed for one thing and I'm sort of surprised that vendors are supplying the same belt for both designs.
I hope ssicarman tunes in and offers his expert advice.
I've attached two thumbnails - the first lists significant differences (new head bolts, new timing belt drive sprocket, new PCM and new valve retaining hardware), and the second has illustrations for drive sprockets.
I try to visit forum daily but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 12-24-2013, 12:59 AM   #86
BlueHeron
I see it listed down below, but above if I switch between 2004 and 2006 it tells you no good for 2004. Thanks for the diagram. I will just go with gates, I have had good luck with all their products and it is slightly cheaper. Anyone have a cheaper lead on the 50mm crankbolt remover tool?
Old 12-27-2013, 12:03 AM   #87
skylanedriver21
skylanedriver21 is on a distinguished road
skylanedriver21's Avatar
I bought my 50mm crankbolt remover tool from an eBay seller. In September of 2013, the going rate for a new tool was $25 US, when you factor in the shipping. I've since loaned it out . When you do this job, start by trying that crankbolt. If you can't break it loose (plenty of suggestions on this site, and other Honda V6 platforms), you aren't going anywhere - you'll just have a lot of parts off and nothing to show for it.
I have pictures of the tool and my setup in my gallery, but I don't have the posting privilege yet.
Add to skylanedriver21's Reputation
Rate the quality of this post and help skylanedriver21 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skylanedriver21 is offline   Reply With Quote
Old 03-13-2014, 10:58 AM   #88
BlueHeron
Finally getting around to replacing the timing belt. Wow, the crank bolt was on there tight. I used a 3/4 ratchet with a 3 foot cheater bar. If I didn't have a pit or lift to do this I would have sol.
Old 04-03-2014, 04:59 PM   #89
SuperDad
SuperDad is on a distinguished road
is the crank bolt reserve threaded, and regular threaded ?
Add to SuperDad's Reputation
Rate the quality of this post and help SuperDad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SuperDad is offline   Reply With Quote
Old 04-03-2014, 06:54 PM   #90
far2grumpy
far2grumpy's Avatar
Turn right to tighten and left to loosen.
Old 04-03-2014, 09:37 PM   #91
BrianTheK
BrianTheK is on a distinguished road
That was a good suggestion elsewhere to try to loosen the crank bolt first. Here's what I did: I used the tool to hold the crankshaft pulley. I put a 1/2 inch drive breaker bar onto the tool and rested the breaker bar against the front motor mount. I then used a 3/4 inch drive socket on the crank bolt with an extension going outside the car with resting on a jackstand. I then used a cheater bar on the bolt (4 feet long). That broke it loose.
Add to BrianTheK's Reputation
Rate the quality of this post and help BrianTheK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BrianTheK is offline   Reply With Quote
Old 05-21-2014, 04:06 PM   #92
timp
timp is on a distinguished road
Hey guys,
I'm preparing to do this job on my 2004 Vue. Unfortunately, I'm unable to see the pictures on the original post of this thread:
I've used a multitude of internet browsers and two PCs to view the post, but none of the combinations I've tried allow me to see the pictures. Is anybody still able to see the pictures? If so, would you be willing to save and email them to me, perhaps?
Thank you for any help you can provide me.
Tim
Add to timp's Reputation
Rate the quality of this post and help timp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timp is offline   Reply With Quote
Old 05-21-2014, 08:11 PM   #93
keller34
keller34 has a spectacular aura aboutkeller34 has a spectacular aura about
Originally Posted by timp View Post
Hey guys,
Tim
Same here, I can't see the pics. Said something about write access on the server...lol. Looks like I am ready also along with my Compressor...YAY!(sarcasm)
Add to keller34's Reputation
Rate the quality of this post and help keller34 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
keller34 is offline   Reply With Quote
Old 05-21-2014, 08:14 PM   #94
BrianTheK
I don't see pics either. Sorry, the original poster would have to send them.
Old 05-21-2014, 08:39 PM   #95
Chazberry
Chazberry's Avatar
1995 SW2
I'm uploading links in this and the next 2 posts.
Add to Chazberry's Reputation
Old 05-21-2014, 08:44 PM   #96
Chazberry
Chazberry's Avatar
1995 SW2
Next 5 . . .
Old 05-21-2014, 08:47 PM   #97
Chazberry
Chazberry's Avatar
1995 SW2
Last 4 . . .
Old 05-21-2014, 09:14 PM   #98
keller34
Thanks a ton.
Old 05-21-2014, 09:16 PM   #99
Chazberry
Chazberry's Avatar
1995 SW2
Originally Posted by keller34 View Post
Thanks a ton.
You're welcome. Let us know how it goes.
Old 05-25-2014, 10:04 AM   #100
timp
Thanks a ton.
Ditto! Thanks millions Chazberry!
New Water Pump/Timing Belt - 90K danf L-Series Tech 6 03-14-2007 06:04 PM
water pump or timing chain? 96SaturnSc1cp S-Series General 8 05-02-2006 08:23 PM
Water pump/timing belt on 03 VUE FWD V6 johnbasler Vue Tech 5 01-10-2006 11:35 AM
Did the Timing Belt and water pump today... what a ripoff!! marmaduke L-Series General 3 07-15-2005 11:59 PM
LS2 Water Pump and the timing belt RicksVue L-Series Tech 2 04-09-2005 04:23 PM
