Old 04-12-2007, 08:37 PM   #1
Goth18
Goth18 is on a distinguished road
Default Sc1 SuperChip?
I've been looking for a super chip or something along those lines for awhile now with no luck. I'm mainly just looking for something to increase my redline and my top speed. Anybody know where i can find something that will do this for me?
Thanks, Aaron
Add to Goth18's Reputation
Rate the quality of this post and help Goth18 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Goth18 is offline   Reply With Quote
Old 04-12-2007, 08:47 PM   #2
Default Re: Sc1 SuperChip?
Nothing can "increase the redline", as the redline is a SAFETY factor (i.e. when you rev above it, you break the engine). The best way to increase performance is to drive a DOHC car.
And there's no "superchip" for the S-car. A stand-alone PCM is the only way to improve engine control electronics.
Add to madpogue's Reputation
Old 04-12-2007, 08:48 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
Thanks, Aaron
You can increase the redline to 6500 rpm and top speed to 124 mph by swapping a 1993-2002 SC1 for a 1991-92 SC or 1993-2002 SC2
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 04-12-2007, 09:03 PM   #4
Goth18
Could you please explain this a little better to me please?
Thanks, Aaron
Old 04-12-2007, 09:37 PM   #5
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: Sc1 SuperChip?
Thanks, Aaron
I think he means to keep it factory. -it is a saturn....
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-12-2007, 10:25 PM   #6
Uzzy
Uzzy's Avatar
2002 SC1
Thanks, Aaron
The PCM for the Saturns cannot be altered the way other cars can. In order to change Powertain control, you need to get a new PCM. Look aournd www.differentracing.com they should have some answers there. eRic's ideas is probably the best way to get what you want.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 04-13-2007, 10:10 AM   #7
wolfman
wolfman's Avatar
No such animal. Saturn has never released the proprietary software that runs its PCMs. Some claim to have been able to "hack" them. Personally, I would not trust the operating system and computer of my car to some computer geek in a basement somewhere...but its your car...
Add to wolfman's Reputation
Old 04-13-2007, 11:04 AM   #8
Tanro
Tanro is on a distinguished road
1991 SC
There is however an auto sc pcm swap. Higher topseed and i think no reve limiter.
VTEC All of the lag but none of the boost. Its basically like waiting to have really bad sex.
http://sattie.1111mb.com/index.html
Add to Tanro's Reputation
Rate the quality of this post and help Tanro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tanro is offline   Reply With Quote
Old 04-13-2007, 03:05 PM   #9
cssprophet
cssprophet is on a distinguished road
True, but you don't really want to increase/remove the rev limiter because, well, as has been said, it's there for a reason -- plus there isn't really any power that high up. On the note of the auto PCM, there was a certain thread where someone mentioned the negative results from that swap. Something to do with the way the PCM from the auto handles fuel/timing when you let off the throttle as opposed to the way the PCM from the manual does. Suffice it to say, it's likely you could experience a performance deficit, and certainly no gain. I'll try to find the thread (if you wish to research on your own, search for something like "auto PCM swap"; you'll get loads of threads to answer your questions about the PCM swap and how there's no chip or magical pixie dust for our cars), though.
EDIT: Here is the thread I mentioned: http://www.saturnfans.com/forums/sho...=auto+pcm+swap. The post of interest is the third one from the top (also the last one... hmmm...), by Low Saturn.
Add to cssprophet's Reputation
Rate the quality of this post and help cssprophet reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cssprophet is offline   Reply With Quote
Old 04-13-2007, 03:43 PM   #10
Low Saturn
Low Saturn's Avatar
2000 SC2
Hehe, I was just about to post that.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
-2000 SC2
-2001 Chevrolet Suburban
Superchip??? scott2683 Vue General 0 03-13-2009 11:24 PM
Replacing 95' SC1 headlights with 97' SC1 headlights Dreamimage S-Series Mods 1 06-19-2007 03:55 PM
Superchip For A Sky Yet ?? Dose Eany One Know wilsonchick20 Sky Mods 7 09-05-2006 02:00 PM
What is the difference between a 94 sc1 and say a 95/96 sc1?? scrt69 General Saturn Discussion 6 07-08-2003 07:19 PM
Jet or Superchip? phattysattysl2 Mods and Performance 6 09-24-2002 12:23 AM
