Old 03-12-2005, 06:12 PM   #1
Imprezatron
Imprezatron is on a distinguished road
Dizzy Save my Saturn
Hey,
I have a 96 Saturn SL1. I have recently replaced plugs, wires, air-filter. Occasionally, and more frequently, after 20 plus minute trips the car will not restart for a couple of hours. Once started the car runs well. I will be replacing the the ects next week along with having the codes read. Is it possible that when replacing the wires the firing order was mixed up?
Any insights would be appreciated
THanks
Add to Imprezatron's Reputation
Rate the quality of this post and help Imprezatron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Imprezatron is offline
Old 03-12-2005, 08:09 PM   #2
adams80
adams80 is on a distinguished road
2000 SL2
1994 SW2
Default Re: Save my Saturn
Sure, I've done that before. So check your firing order, I think it should be 4-1-2-3 in all S-series.
Add to adams80's Reputation
Rate the quality of this post and help adams80 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adams80 is offline
Old 03-12-2005, 09:16 PM   #3
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
If your plug wires were, indeed, mixed up, wouldn't you be having a continual problem? It would seem rather strange for the car to "run well." I'd think it would be bucking like a horse.
Can you give a few more symptoms of what's happening when the car won't start? When you turn the key, are you getting any kind of response? Is it cranking but just not turning over? With your interior fan and radio off, can you hear the fuel pump kick on when you turn the key forward but not to the starting position? Have your lights been dimming at all? Any strange noises under the hood? How many miles on the car? Auto or Manual?
It's either an electrical issue or a fuel supply issue. You're either getting gas but no spark, or spark but no gas. (Or both.) Could be any of several sensors--including, perhaps, the ECTS you mentioned. Some additional info may help with the diagnosis.
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline
Old 03-12-2005, 10:14 PM   #4
Preachermannn
Preachermannn is on a distinguished road
1995 SC1
I agree 100 percent with Jambra - if you had messed up the firing order, the car would run very poorly, (especially as it's a four banger - mix up two wires and you're only running on two cylinders). I'm curious - does the motor turn over when you turn the key and just not start? Or does it not even want to turn over for a couple of hours? The reason I ask is that years ago, I had an old Plymouth. It would crank and run even in the coldest weather, (I loved that car). But, if you ran it for a couple of hours on a long trip and then stopped to eat, pee, or get gas, It wouldn't even turn over for a couple of hours. One trip I drove a straight 30 hours, not even shutting it off when I got gas so that I wouldn't get stranded. An old timer told me my pistons were "varnished." We filled the motor with Kerosene and let it sit for a couple of days, (refilling every day as the Kerosene would leak past the rings). Changed the oil, blew what was left of the Kerosene out the plug holes, and it ran like a champ. Then I got married and my wife wrecked that car - she never did like the relationship I had with that Plymouth .
Of all the things I've lost, I miss my mind the most!
Add to Preachermannn's Reputation
Rate the quality of this post and help Preachermannn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Preachermannn is offline
Old 03-12-2005, 11:26 PM   #5
IceQueen
IceQueen is on a distinguished road
Could be the ignition module. Sounds like it's bad. I think there's a ceramic piece/layer in there and once it gets hot, and you shut off the car, it has to cool down before the car will start again. Go to ABOUT.COM and type in ignition module and see if it resembles your problem. I don't know if the module on a Saturn is inside or outside the distributor. Anyone????
Add to IceQueen's Reputation
Rate the quality of this post and help IceQueen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IceQueen is offline
Old 03-13-2005, 12:02 AM   #6
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
Post Re: Save my Saturn
Ignition models are rock solid according to ssicarman. I'd take that as bible and replace that ects sensor. When it is bad the signals it sends to the PCM are all out of whack. The PCM, based on the bad input, can think the engine is at full operating temp when it is stone cold. So instead of getting a richer mixture to start your cold engine, you aren't getting squat.
If the wires were crossed significantly you wouldn't be going anywhere as pointed out before.
Get your codes read. Replace your ects. Clear the codes and see what happens.
Let us know how it turns out.
Add to peppermrj's Reputation
Rate the quality of this post and help peppermrj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
peppermrj is offline
Old 03-13-2005, 12:06 AM   #7
Tiger
Tiger's Avatar
The ignition module, with two replacable coils, is on the front of the block between the oil dipstick and transmission dipstick on my Saturn. There is a problem with corrosion were it mounts to the engine block becoming corroded. That is what happened in my case. It threw a code. The techs at the dealership told me how to clean it, saving $110. I have not heard of the issue of the ingnition module needing to cool down before the engine will start. I have heard of starters not working when hot if they are going out. So I am curious, when you say the car will not start, are you saying it will not turn over, or does it sound like it is not firing?
Add to Tiger's Reputation
Tiger is offline
Old 03-13-2005, 12:12 AM   #8
peppermrj
peppermrj's Avatar
Forgot to mention that IceQueen obviously nows about GM's. Your year saturn has DIS (distributorless ignition system). The ignition module does have some ground related issues that only require cleaning up the mounting bolts and plate.
Old 03-13-2005, 01:18 AM   #9
Tiger
Tiger's Avatar
I can appreciate IceQueen trying to be helpful. I have done my share of that to find out how different makes and or even the same model vary from year to year. That is the beauty of this forum. A lot of Saturn specific info has been posted. After a while, it is sinking in (thank God). I am curious to see how this turns out. My recently replaced ECTS was cracking. It seems it is not a matter of if, but when, the original design ECTS will fail on these cars.
Tiger is offline
Old 03-13-2005, 01:45 AM   #10
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Do a fuel pump leakdown test. I would bet the farm your fuel pump isn't holding pressure and needs to be replaced. Seen a lot of that on '96's.
Add to SaturnTech's Reputation
Rate the quality of this post and help SaturnTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech is offline
Old 03-13-2005, 10:40 PM   #11
Chris101
Chris101 is on a distinguished road
Chris101's Avatar
Imprezatron, I had that exact problem when my ECT went bad. It didn't take hours for me, it was maybe a half hour to an hour.
Add to Chris101's Reputation
Rate the quality of this post and help Chris101 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chris101 is offline
Old 03-14-2005, 01:03 PM   #12
Imprezatron
Hey,
Thanks so much for all the responses. Just out of curiosity i intentionally mixed up the firing order and the car didn't run any differently. No hesitation, no backfiring, it ran fine for a 10 minute test trip. I'm having the codes read today at noon so Ill have a little more to go on. Regarding the firing order, which side do you count No. 1 cylinder from? the serpentine? Just wan't to be sure
SaturnTech: Is there a place on this site that describes how the leakdown test is done? Or another website possibly?
Tiger: The car turns over well and will stumble a little, but it really doesn't seem like its firing well.
The car is an automatic with 175,000 on the clock. Again, all these problems are occuring after a minimum of a 30 minute trip.
Thanks Dave
Old 03-14-2005, 01:50 PM   #13
ym42
ym42 is on a distinguished road
Any SES codes? SES light? My guess check ECTS!
Add to ym42's Reputation
Rate the quality of this post and help ym42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ym42 is offline
Old 03-14-2005, 05:40 PM   #14
Chris101
Chris101's Avatar
Once again, this was the same problem I was having before I had to change my ECTS. I would have to let it sit for, at the most an hour, and when I came out to start it, I would have to put the throttle down about 1/2 so it would start after it spuddered. It's only a $15- $20 part, and is quite easy to install. I would start with that.
Chris101 is offline
Old 03-14-2005, 06:03 PM   #15
SaturnTech
SaturnTech's Avatar
To perform the leakdown test you hook up a fuel pressure gauge, turn the key to the RUN position (fuel pressure goes up to start the car) and then turn the kay back off. Wait approx. 15 mins. the fuel pressure should stay the same, if it's dropping, you have yourself a bum fuel pump.
Old 03-14-2005, 06:30 PM   #16
peppermrj
peppermrj's Avatar
Information Re: Save my Saturn
In regards to the firing order, when a coil fires, it fires both cylinders.However only 1 cylinder is on the compession stroke. The other is on the exhaust stroke. Switching those 2 wires would have no effect.
Good hunting.
Old 03-14-2005, 06:51 PM   #17
peppermrj
peppermrj's Avatar
Rot row.
Old 03-22-2005, 12:08 AM   #18
Imprezatron
Happy Re: Save my Saturn
Hi, and thanks to everyone who submitted any advice, it helped alot. Along with everything I already mentioned, I replaced the ects with the brass one from the dealer. The old one was indeed split. I put the new one in and the problems persisted. Turns out the harness going to the sensor was heat corroded and had to be changed. Since that was done the car has run beautifully. Drove it 600 kms to go skiing this past weekend and had no problems. The excellent fuel mileage has returned as well. Viva little Saturn!
Thanks again.
Dave
Old 03-22-2005, 09:27 AM   #19
Razorbak
Razorbak's Avatar
Imprezatron, glad you got the problem solved. Congratulations!
For future reference, the #1 cylinder is at the front of the engine, which is on the passenger's side of the engine bay, where the serpentine belt runs, on front wheel drive vehicles. (FWD vehicles have transversely mounted engines, running side-to-side, parallel with the drive axles, versus rear wheel drive vehicles, which are mounted front-to-back, perpendicular to the drive axles.) So the cylinder numbers (& firing order) are counted from the passenger's side of the engine bay on S-Series cars.
Add to Razorbak's Reputation
Razorbak is offline
Saturn was Supposed To Save GM BobbyP General Saturn Discussion 19 08-05-2009 10:20 PM
What Can You Do to Help Save Saturn? Charlie General Saturn Discussion 50 02-26-2009 02:06 PM
This will save Saturn DAS General Saturn Discussion 50 06-08-2007 06:05 AM
This Saturn Couldn't Save Her. white95SL1 General Saturn Discussion 2 08-01-2006 12:18 AM
We Can Save Saturn!!!! dennis marshall General Saturn Discussion 59 07-18-2003 10:31 PM
