Old 05-03-2004, 11:01 PM   #1
nathy1979
nathy1979 is on a distinguished road
Dizzy emissions
i have a 95 sl1 with 130,000 miles on it, my question is are the "guarenteed to pass ' fuel systems cleaners good to get i have to go the the state inspection this month, the only problem i ll thing i will have is emissions any advice would be appreciated
nathy1979 is offline
Old 05-04-2004, 12:19 AM   #2
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default
I wouldn't recommend using one of those products. IF your car isn't passing emissions, there's a reason it's not. The solution won't be found in a bottle of fancy alcohol.
In preparing for your emissions inspection, check the condition of your wires, plugs (gapping too), PCV, EGR, air filter, and do an oil change. Running a bottle of Techron through your fuel system prior to your inspection makes sense too. Barring that your exhaust and cat are in good shape and the above mentioned are working fine, you should pass (with the exception of major engine problems that NOTHING will easily remedy).
I've gotten some old, clunky POS cars to pass the strict guidelines here in CA using these same guidelines. Good luck
SLeepr is offline
Old 05-04-2004, 09:36 AM   #3
Luke
Luke's Avatar
Default
Fm Sleeper
And I've found that if it fails, it is usually the Cat (High HC readings) on my 95SL2.
BTW, I'm taking it in for initial emission check during the middle of the month. Let's see.
Luke is offline
emissions EvilCody S-Series General 9 09-17-2004 04:54 AM
Ca emissions poorboy S-Series Tech 7 05-07-2004 06:14 PM
CA emissions Bigbadbert Miscellaneous Tech 3 03-27-2004 12:25 AM
Emissions are going up yellekkelurock Ion General 31 11-24-2003 04:04 PM
Emissions ym42 Miscellaneous Tech 4 11-24-2002 02:03 PM
